timestamp
хочу добавить инфу в базу данных CREATE TABLE sites ( site_id mediumint(9) NOT NULL auto_increment, site_url varchar(127) NOT NULL, upddate timestamp(14), username varchar(32), password varchar(32), port smallint(6), locked tinyint(1) DEFAULT '0' NOT NULL, stopped tinyint(1) DEFAULT '0' NOT NULL, PRIMARY KEY (site_id) ); пишет ошибку You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '(14), username varchar(32), password varchar(32), port smallint(6), ' at line 4 почему? ... |
| 02.12.2015, 22:54:13 |
start [/forum/topic.php?desktop=1&fid=47&tid=1832426]: |
41ms |
32ms |
| others: | 195ms |
| total: | 311ms |
