Не стартует mysql на centos. лог прилагается
Как лечить такое? вот такое в логе: 160408 15:02:39 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160408 15:02:39 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead. 160408 15:02:39 InnoDB: Initializing buffer pool, size = 8.0M 160408 15:02:39 InnoDB: Completed initialization of buffer pool InnoDB: Log scan progressed past the checkpoint lsn 88 2587510113 160408 15:02:39 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 88 2587577081 InnoDB: Probable data corruption on page 4 InnoDB: Original record PHYSICAL RECORD: n_fields 128; 2-byte offsets; info bits 48 0: len 0; hex ; asc ;; 1: len 0; hex ; asc ;; 2: len 0; hex ; asc ;; 3: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 4: len 30; hex 0038555f00860a000380008601000180008608000880008fc08880800000; asc 8U_ ;...(truncated); 5: len 30; hex ad28201f1c0905040004d80f1f0600000000000038555f00860a00038000; asc ( 8U_ ;...(truncated); 6: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 7: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 8: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 9: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 10: len 30; hex 28098000000000000554261e160905040003300d145a0000000000003855; asc ( T& 0 Z 8U;...(truncated); 11: len 0; hex ; asc ;; 12: SQL NULL, size 0 ; 13: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 14: SQL NULL, size 3562 ; 15: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 16: SQL NULL, size 18446744073709546923 ; 17: SQL NULL, size 0 ; 18: len 8; hex 0008800086080008; asc ;; 19: SQL NULL, size 1536 ; 20: SQL NULL, size 18446744073709550072 ; 21: len 8; hex 0008800086080008; asc ;; 22: SQL NULL, size 1540 ; 23: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 24: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 25: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 26: len 0; hex ; asc ;; 27: len 0; hex ; asc ;; 28: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 29: len 30; hex 5f00860a000380008601000180008608000880008fc08880800000000000; asc _ ;...(truncated); 30: len 30; hex 8000800000018000000000006baf0000055628201f1c0905040003a00f16; asc k V( ;...(truncated); 31: len 30; hex 261e160905040002f80d12fc00000000000038555a00860c000880008608; asc & 8UZ ;...(truncated); 32: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 33: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 34: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 35: len 30; hex f528098000000000000554261e160905040003300d145a00000000000038; asc ( T& 0 Z 8;...(truncated); 36: len 0; hex ; asc ;; 37: SQL NULL, size 0 ; 38: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 39: SQL NULL, size 3564 ; 40: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 41: SQL NULL, size 18446744073709546923 ; 42: SQL NULL, size 0 ; 43: len 8; hex 0008800086080008; asc ;; 44: SQL NULL, size 1536 ; 45: SQL NULL, size 18446744073709550072 ; 46: len 8; hex 0008800086080008; asc ;; 47: SQL NULL, size 1540 ; 48: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 49: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 50: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 51: len 0; hex ; asc ;; 52: len 0; hex ; asc ;; 53: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 54: len 30; hex 0a000380008601000180008608000880008fc088808000000000006ba628; asc k (;...(truncated); 55: len 30; hex 55f5f5280d8000000000000557261e160905040002580d0f140000000000; asc U ( W& X ;...(truncated); 56: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 57: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 58: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 59: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 60: len 30; hex f5f528098000000000000554261e160905040003300d145a000000000000; asc ( T& 0 Z ;...(truncated); 61: len 0; hex ; asc ;; 62: SQL NULL, size 0 ; 63: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 64: SQL NULL, size 3566 ; 65: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 66: SQL NULL, size 18446744073709546923 ; 67: SQL NULL, size 0 ; 68: len 8; hex 0008800086080008; asc ;; 69: SQL NULL, size 1536 ; 70: SQL NULL, size 18446744073709550072 ; 71: len 8; hex 0008800086080008; asc ;; 72: SQL NULL, size 1540 ; 73: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 74: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 75: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 76: len 0; hex ; asc ;; 77: len 0; hex ; asc ;; 78: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 79: len 30; hex 80008601000180008608000880008fc088808000000000006ba528201f1c; asc k ( ;...(truncated); 80: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 81: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 82: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 83: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 84: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 85: len 30; hex 55f5f528098000000000000554261e160905040003300d145a0000000000; asc U ( T& 0 Z ;...(truncated); 86: len 0; hex ; asc ;; 87: SQL NULL, size 0 ; 88: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 89: SQL NULL, size 3568 ; 90: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 91: SQL NULL, size 18446744073709546923 ; 92: SQL NULL, size 0 ; 93: len 8; hex 0008800086080008; asc ;; 94: SQL NULL, size 1536 ; 95: SQL NULL, size 18446744073709550072 ; 96: len 8; hex 0008800086080008; asc ;; 97: SQL NULL, size 1540 ; 98: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 99: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 100: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 101: len 0; hex ; asc ;; 102: len 0; hex ; asc ;; 103: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 104: len 30; hex 01000180008608000880008fc088808000000000006ba428201f1c090504; asc k ( ;...(truncated); 105: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 106: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 107: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 108: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 109: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 110: len 30; hex 1255f5f528098000000000000554261e160905040003300d145a00000000; asc U ( T& 0 Z ;...(truncated); 111: len 0; hex ; asc ;; 112: SQL NULL, size 0 ; 113: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 114: SQL NULL, size 3570 ; 115: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 116: SQL NULL, size 18446744073709546923 ; 117: SQL NULL, size 0 ; 118: len 8; hex 0008800086080008; asc ;; 119: SQL NULL, size 1536 ; 120: SQL NULL, size 18446744073709550072 ; 121: len 8; hex 0008800086080008; asc ;; 122: SQL NULL, size 1540 ; 123: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 124: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 125: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 126: len 0; hex ; asc ;; 127: len 0; hex ; asc ;; InnoDB: Error: record field 5 len 18446744073709547509 InnoDB: on that page. InnoDB: Cannot find the dir slot for record PHYSICAL RECORD: n_fields 128; 2-byte offsets; info bits 48 0: len 0; hex ; asc ;; 1: len 0; hex ; asc ;; 2: len 0; hex ; asc ;; 3: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 4: len 30; hex 0038555f00860a000380008601000180008608000880008fc08880800000; asc 8U_ ;...(truncated); 5: len 30; hex ad28201f1c0905040004d80f1f0600000000000038555f00860a00038000; asc ( 8U_ ;...(truncated); 6: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 7: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 8: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 9: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 10: len 30; hex 28098000000000000554261e160905040003300d145a0000000000003855; asc ( T& 0 Z 8U;...(truncated); 11: len 0; hex ; asc ;; 12: SQL NULL, size 0 ; 13: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 14: SQL NULL, size 3562 ; 15: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 16: SQL NULL, size 18446744073709546923 ; 17: SQL NULL, size 0 ; 18: len 8; hex 0008800086080008; asc ;; 19: SQL NULL, size 1536 ; 20: SQL NULL, size 18446744073709550072 ; 21: len 8; hex 0008800086080008; asc ;; 22: SQL NULL, size 1540 ; 23: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 24: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 25: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 26: len 0; hex ; asc ;; 27: len 0; hex ; asc ;; 28: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 29: len 30; hex 5f00860a000380008601000180008608000880008fc08880800000000000; asc _ ;...(truncated); 30: len 30; hex 8000800000018000000000006baf0000055628201f1c0905040003a00f16; asc k V( ;...(truncated); 31: len 30; hex 261e160905040002f80d12fc00000000000038555a00860c000880008608; asc & 8UZ ;...(truncated); 32: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 33: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 34: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 35: len 30; hex f528098000000000000554261e160905040003300d145a00000000000038; asc ( T& 0 Z 8;...(truncated); 36: len 0; hex ; asc ;; 37: SQL NULL, size 0 ; 38: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 39: SQL NULL, size 3564 ; 40: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 41: SQL NULL, size 18446744073709546923 ; 42: SQL NULL, size 0 ; 43: len 8; hex 0008800086080008; asc ;; 44: SQL NULL, size 1536 ; 45: SQL NULL, size 18446744073709550072 ; 46: len 8; hex 0008800086080008; asc ;; 47: SQL NULL, size 1540 ; 48: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 49: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 50: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 51: len 0; hex ; asc ;; 52: len 0; hex ; asc ;; 53: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 54: len 30; hex 0a000380008601000180008608000880008fc088808000000000006ba628; asc k (;...(truncated); 55: len 30; hex 55f5f5280d8000000000000557261e160905040002580d0f140000000000; asc U ( W& X ;...(truncated); 56: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 57: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 58: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 59: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 60: len 30; hex f5f528098000000000000554261e160905040003300d145a000000000000; asc ( T& 0 Z ;...(truncated); 61: len 0; hex ; asc ;; 62: SQL NULL, size 0 ; 63: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 64: SQL NULL, size 3566 ; 65: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 66: SQL NULL, size 18446744073709546923 ; 67: SQL NULL, size 0 ; 68: len 8; hex 0008800086080008; asc ;; 69: SQL NULL, size 1536 ; 70: SQL NULL, size 18446744073709550072 ; 71: len 8; hex 0008800086080008; asc ;; 72: SQL NULL, size 1540 ; 73: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 74: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 75: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 76: len 0; hex ; asc ;; 77: len 0; hex ; asc ;; 78: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 79: len 30; hex 80008601000180008608000880008fc088808000000000006ba528201f1c; asc k ( ;...(truncated); 80: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 81: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 82: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 83: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 84: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 85: len 30; hex 55f5f528098000000000000554261e160905040003300d145a0000000000; asc U ( T& 0 Z ;...(truncated); 86: len 0; hex ; asc ;; 87: SQL NULL, size 0 ; 88: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 89: SQL NULL, size 3568 ; 90: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 91: SQL NULL, size 18446744073709546923 ; 92: SQL NULL, size 0 ; 93: len 8; hex 0008800086080008; asc ;; 94: SQL NULL, size 1536 ; 95: SQL NULL, size 18446744073709550072 ; 96: len 8; hex 0008800086080008; asc ;; 97: SQL NULL, size 1540 ; 98: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 99: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 100: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 101: len 0; hex ; asc ;; 102: len 0; hex ; asc ;; 103: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 104: len 30; hex 01000180008608000880008fc088808000000000006ba428201f1c090504; asc k ( ;...(truncated); 105: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 106: len 30; hex 800086080008800080001255f5f5280d8000000000000557261e16090504; asc U ( W& ;...(truncated); 107: len 30; hex 200d13f600000000000038555a00860c0008800086080008800080001255; asc 8UZ U;...(truncated); 108: len 30; hex 05040004b00f1dfd00000000000038555f00860a00038000860100018000; asc 8U_ ;...(truncated); 109: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 110: len 30; hex 1255f5f528098000000000000554261e160905040003300d145a00000000; asc U ( T& 0 Z ;...(truncated); 111: len 0; hex ; asc ;; 112: SQL NULL, size 0 ; 113: len 30; hex 0008800086080008800080001255f5f5280d8000000000000557261e1609; asc U ( W& ;...(truncated); 114: SQL NULL, size 3570 ; 115: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 116: SQL NULL, size 18446744073709546923 ; 117: SQL NULL, size 0 ; 118: len 8; hex 0008800086080008; asc ;; 119: SQL NULL, size 1536 ; 120: SQL NULL, size 18446744073709550072 ; 121: len 8; hex 0008800086080008; asc ;; 122: SQL NULL, size 1540 ; 123: len 30; hex 860c0008800086080008800080001255f5f528118000000000000558261e; asc U ( X& ;...(truncated); 124: len 30; hex 00860a000380008601000180008608000880008fc088808000000000006b; asc k;...(truncated); 125: len 30; hex 000000000000000000000000000000000000000000000000000000000000; asc ;...(truncated); 126: len 0; hex ; asc ;; 127: len 0; hex ; asc ;; InnoDB: Error: record field 5 len 18446744073709547509 InnoDB: on that page! 160408 15:02:40 InnoDB: Page dump in ascii and hex (16384 bytes): len 16384; hex 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; asc < c X :JmE 1 " "b" ! n m J ' J " infimum supremum ( 8UN G( 8UN H( 8UN I( ( 8UN J( 0 ) 8UN K( 8 ^ 8UN L( @ 8UN M( H 8UN N( P 8UN O( X 2 8UN P( ` g 8UN Q( h 8UN R( p 8UN S( x 8UN T( ; 8UN U( 8UP G( 8UP H( 8UP I( 8UP J( D 8UP K( y 8UP L( 8UP M( 8UP N( 8UP O( M 8UP P( 8UP Q( 8UP R( 8UP S( ! 8UP T( V 8UP U( 8UP V( 8UP W( 8UP X( * 8UP Y( _ 8UP Z( ( 8UP [( 0 8UP \( 8 8UP ]( @ 3 8UP ^( H h 8UP _( P 8UP `" X 8 8U` k G" ` j 8U` k H" h 8U` k I" p 8U` k J" x 8U` k K" 2 8U` k L" d 8U` k M" 8U` k N" 8U` k O" 8U` k P" , 8U` k Q" ^ 8U` k R" 8U` k S" 8U` k T" 8U` k U& U 8UY U ' G& 8UY U ' H& & 8UY U ' I& X 8UY U ' J& 8UY U ' K& 8UY U ' L& 8UY U ' M& 8UY U ' N& R 8UY U ' O& 8UY U ' P& 8UY U ( Q& ( 8UY U ( R& 0 8UY U ( S& 8 L 8UY U ( T& @ ~ 8UY U ( U& H 8UY U ( V& P 9VY U ( W& X 8UY U ( X& ` F 8UY U ( Y& h x 8UY U ( Z& p 8UY U ( [& x 8UY U ( \& 8UY U ( ]& @ 8UY U ( ^& r 8UY U ( _& 8UY U ( `& 8UY U (! a& 8UY U (# b" 8U` k c" 8U` k d& 8UZ U ' G& 8UZ U ' H& 8UZ U ' I& 4 8UZ U ' J& f 8UZ U ' K& 8UZ U ' L& 8UZ U ' M& 8UZ U ' N& . 8UZ U ' O& ` 8UZ U ( P& 8UZ U ( Q& 8UZ U ( R& 8UZ U ( S& ( ( 8UZ U ( T& 0 Z 8UZ U ( U& 8 8UZ U ( V& @ 8UZ U ( W& H 8UZ U ( X& P " 8UZ U ( Y& X T 8UZ U ( Z& ` 8UZ U ( [& h 8UZ U ( \& p 8UZ U ( ]& x 8UZ U ( ^& N 8UZ U ( _& 8UZ U (! `( p 8UN V" 8U` k V( 8UN W" 8U` k W( L 8UN X" N 8U` k X( 8UN Y" 8U` k Y( 8UN Z" 8U` k Z( 8UN [" 8U` k [( 8UN \" 8U` k \( O 8UN ]" Q 8U` k ]( 8UN ^" 8U` k ^( 8UN _" ( 8U` k _( 0 8UN `" 8 8U` k `" @ : 8U` k d a" H 8U` k a" P Q 8U` k c b" X 8U` k b( ` 8UP a( h 8UP b( p l 8U_ k ( x 8U_ k ( 8U_ k ( 8U_ k ( ) 8U_ k ( ^ 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( 2 8U_ k ( g 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( ; 8U_ k ( p 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( D 8U_ k ( y 8U_ k ( " 8U_ k ( 8U_ k ( ((K 8U_ k ( 0 !M 8U_ k ( 8 ! 8U_ k ( @ ! 8U_ k ( H ! 8U_ k ( P "! 8U_ k ( X "V 8U_ k ` g 8U_ k & h t 8UY U () e k 8UP a( h 8UP b( p l 8U_ k ( x 8U_ k ( 8U_ k ( 8U_ k ( ) 8U_ k ( ^ 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( 2 8U_ k ( g 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( ; 8U_ k ( p 8U_ k ( 8U_ k ( 8U_ k ( 8U_ k ( D 8U_ k ( y 8U_ k ( 8U_ k ( 8U_ k ( u( ! 8U_ k ( 0 !M 8U_ k ( 8 ! 8U_ k ( @ ! 8U_ k ( H ! 8U_ k ( P "! 8U_ k ( X "V 8U_ k ( ` " 8U_ k & h t 8UY U () e k + f t t t t t t t t t t t t t t t t t t t t t t t t t t t t t t t t t t e X :Jm;InnoDB: End of page dump 160408 15:02:40 InnoDB: Page checksum 3377346840, prior-to-4.0.14-form checksum 1455939637 InnoDB: stored checksum 2721898851, prior-to-4.0.14-form stored checksum 88 InnoDB: Page lsn 88 2587511405, low 4 bytes of lsn at page end 2587511405 InnoDB: Page number (if stored to page already) 4, InnoDB: space id (if created with >= MySQL-4.1.1 and stored already) 0 InnoDB: Page may be an update undo log page InnoDB: Page may be an index page where index id is 4294967295 0 160408 15:02:40 InnoDB: Assertion failure in thread 140679506110432 in file page/page0page.c line 133 InnoDB: We intentionally generate a memory trap. InnoDB: Submit a detailed bug report to http://bugs.mysql.com. InnoDB: If you get repeated assertion failures or crashes, even InnoDB: immediately after the mysqld startup, there may be InnoDB: corruption in the InnoDB tablespace. Please refer to InnoDB: http://dev.mysql.com/doc/refman/5.1/en/forcing-innodb-recovery.html InnoDB: about forcing recovery. 12:02:40 UTC - mysqld got signal 6 ; This could be because you hit a bug. It is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. We will try our best to scrape up some info that will hopefully help diagnose the problem, but since we have already crashed, something is definitely wrong and this may fail. key_buffer_size=16384 read_buffer_size=262144 max_used_connections=0 max_threads=151 thread_count=0 connection_count=0 It is possible that mysqld could use up to key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 49909 K bytes of memory Hope that's ok; if not, decrease some variables in the equation. Thread pointer: 0x0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... stack_bottom = 0 thread_stack 0x20000 /usr/libexec/mysqld(my_print_stacktrace+0x29) [0x8509d9] /usr/libexec/mysqld(handle_fatal_signal+0x483) [0x6a3f13] /lib64/libpthread.so.0(+0xf500) [0x7ff27fbb9500] /lib64/libc.so.6(gsignal+0x35) [0x7ff27e1f48e5] /lib64/libc.so.6(abort+0x175) [0x7ff27e1f60c5] /usr/libexec/mysqld(page_dir_find_owner_slot+0x1e3) [0x79bfa3] /usr/libexec/mysqld(page_cur_insert_rec_low+0x47d) [0x799bad] /usr/libexec/mysqld(page_cur_parse_insert_rec+0x4eb) [0x79a55b] /usr/libexec/mysqld() [0x787a0d] /usr/libexec/mysqld(recv_recover_page+0x34f) [0x7894cf] /usr/libexec/mysqld(buf_page_io_complete+0x548) [0x74a888] /usr/libexec/mysqld() [0x74fae0] /usr/libexec/mysqld(buf_read_page+0x225) [0x750465] /usr/libexec/mysqld(buf_page_get_gen+0x393) [0x749943] /usr/libexec/mysqld(ibuf_data_init_for_space+0x1e4) [0x776f44] /usr/libexec/mysqld(fil_ibuf_init_at_db_start+0x2a) [0x7617ea] /usr/libexec/mysqld(dict_boot+0x90c) [0x7ebd2c] /usr/libexec/mysqld(innobase_start_or_create_for_mysql+0x11f6) [0x7c8236] /usr/libexec/mysqld() [0x72f61b] /usr/libexec/mysqld(ha_initialize_handlerton(st_plugin_int*)+0x31) [0x697961] /usr/libexec/mysqld() [0x7175ab] /usr/libexec/mysqld(plugin_init(int*, char**, int)+0x6e4) [0x7198a4] /usr/libexec/mysqld() [0x5bf202] /usr/libexec/mysqld(main+0x1b3) [0x5c1af3] /lib64/libc.so.6(__libc_start_main+0xfd) [0x7ff27e1e0cdd] /usr/libexec/mysqld() [0x5098f9] The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains information that should help you find out what is causing the crash. 160408 15:02:40 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended ... |
| 08.04.2016, 15:05 |
start [/forum/topic.php?desktop=1&fid=47&tid=1831936]: |
38ms |
25ms |
| others: | 899ms |
| total: | 992ms |
