Падает MySQL
Всем привет) Заранее простите если не в правильном месте я создаю топик, если не правильно попрошу модераторов перенести в соответствующий радел. Появилась 1 проблема, падает MySQL, у меня VDS на Debian. Вот первые mysql-errors логи: 160409 12:07:45 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 12:07:45 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:07:45 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 12:07:45 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 12:07:45 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 28064 ... 160409 12:07:45 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:07:45 [Note] Plugin 'FEDERATED' is disabled. 160409 12:07:45 InnoDB: The InnoDB memory heap is disabled 160409 12:07:45 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 12:07:45 InnoDB: Compressed tables use zlib 1.2.7 160409 12:07:45 InnoDB: Using Linux native AIO 160409 12:07:45 InnoDB: Initializing buffer pool, size = 1000.0M 160409 12:07:45 InnoDB: Completed initialization of buffer pool 160409 12:07:45 InnoDB: highest supported file format is Barracuda. InnoDB: Log scan progressed past the checkpoint lsn 456291970 160409 12:07:45 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 456293033 160409 12:07:46 InnoDB: Starting an apply batch of log records to the database... InnoDB: Progress in percents: 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 InnoDB: Apply batch completed 160409 12:07:47 InnoDB: Waiting for the background threads to start 160409 12:07:48 InnoDB: 5.5.46 started; log sequence number 456293033 160409 12:07:48 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 12:07:48 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 12:07:48 [Note] Server socket created on IP: '0.0.0.0'. 160409 12:07:50 [Note] Event Scheduler: Loaded 0 events 160409 12:07:50 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) 160409 12:07:55 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/cache_store' is marked as crashed and should be repaired 160409 12:07:55 [Warning] Checking table: './atlantic_forum/cache_store' 160409 12:07:55 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/sessions' is marked as crashed and should be repaired 160409 12:07:55 [Warning] Checking table: './atlantic_forum/sessions' 160409 12:07:56 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/task_manager' is marked as crashed and should be repaired 160409 12:07:56 [Warning] Checking table: './atlantic_forum/task_manager' 160409 12:07:57 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/search_sessions' is marked as crashed and should be repaired 160409 12:07:57 [Warning] Checking table: './atlantic2_forum/search_sessions' 160409 12:08:25 [Note] /usr/sbin/mysqld: Normal shutdown 160409 12:08:25 [Note] Event Scheduler: Purging the queue. 0 events 160409 12:08:25 InnoDB: Starting shutdown... 160409 12:08:26 InnoDB: Shutdown completed; log sequence number 456293033 160409 12:08:26 [Note] /usr/sbin/mysqld: Shutdown complete 160409 12:08:26 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 160409 12:08:27 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 12:08:27 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:08:27 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 12:08:27 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 12:08:27 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 31196 ... 160409 12:08:27 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:08:27 [Note] Plugin 'FEDERATED' is disabled. 160409 12:08:27 InnoDB: The InnoDB memory heap is disabled 160409 12:08:27 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 12:08:27 InnoDB: Compressed tables use zlib 1.2.7 160409 12:08:27 InnoDB: Using Linux native AIO 160409 12:08:28 InnoDB: Initializing buffer pool, size = 1000.0M 160409 12:08:28 InnoDB: Completed initialization of buffer pool 160409 12:08:28 InnoDB: highest supported file format is Barracuda. 160409 12:08:28 InnoDB: Waiting for the background threads to start 160409 12:08:29 InnoDB: 5.5.46 started; log sequence number 456293033 160409 12:08:29 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 12:08:29 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 12:08:29 [Note] Server socket created on IP: '0.0.0.0'. 160409 12:08:29 [Note] Event Scheduler: Loaded 0 events 160409 12:08:29 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) Killed Как я заметил упал он из за повреждённых табелей, я вписал запрос в phpmyadmin(для каждой таблицы): Код: sql 1. Думал исправилось, но нет, опять mysql упал, с немного отличающими логами. 160409 19:13:46 mysqld_safe Number of processes running now: 0 160409 19:13:46 mysqld_safe mysqld restarted 160409 19:13:47 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 19:13:47 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 19:13:47 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 19:13:47 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 14185 ... 160409 19:13:47 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 19:13:47 [Note] Plugin 'FEDERATED' is disabled. 160409 19:13:47 InnoDB: The InnoDB memory heap is disabled 160409 19:13:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 19:13:47 InnoDB: Compressed tables use zlib 1.2.7 160409 19:13:47 InnoDB: Using Linux native AIO 160409 19:13:47 InnoDB: Initializing buffer pool, size = 1000.0M 160409 19:13:48 InnoDB: Completed initialization of buffer pool Killed 160409 19:13:48 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 160409 20:52:11 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 20:52:11 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 20:52:11 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 20:52:11 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 20:52:11 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 17346 ... 160409 20:52:11 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 20:52:11 [Note] Plugin 'FEDERATED' is disabled. 160409 20:52:11 InnoDB: The InnoDB memory heap is disabled 160409 20:52:11 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 20:52:11 InnoDB: Compressed tables use zlib 1.2.7 160409 20:52:11 InnoDB: Using Linux native AIO 160409 20:52:11 InnoDB: Initializing buffer pool, size = 1000.0M 160409 20:52:11 InnoDB: Completed initialization of buffer pool 160409 20:52:11 InnoDB: highest supported file format is Barracuda. InnoDB: Log scan progressed past the checkpoint lsn 465561681 160409 20:52:11 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 465563579 160409 20:52:12 InnoDB: Starting an apply batch of log records to the database... InnoDB: Progress in percents: 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 InnoDB: Apply batch completed 160409 20:52:12 InnoDB: Waiting for the background threads to start 160409 20:52:13 InnoDB: 5.5.46 started; log sequence number 465563579 160409 20:52:13 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 20:52:13 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 20:52:13 [Note] Server socket created on IP: '0.0.0.0'. 160409 20:52:14 [Note] Event Scheduler: Loaded 0 events 160409 20:52:14 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) 160409 20:52:15 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/cache_store' is marked as crashed and should be repaired 160409 20:52:15 [Warning] Checking table: './atlantic_forum/cache_store' 160409 20:52:15 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/task_manager' is marked as crashed and should be repaired 160409 20:52:15 [Warning] Checking table: './atlantic_forum/task_manager' 160409 20:52:16 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/core_like_cache' is marked as crashed and should be repaired 160409 20:52:16 [Warning] Checking table: './atlantic2_forum/core_like_cache' 160409 20:52:16 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/reputation_cache' is marked as crashed and should be repaired 160409 20:52:16 [Warning] Checking table: './atlantic2_forum/reputation_cache' 160409 20:52:28 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/reputation_totals' is marked as crashed and should be repaired 160409 20:52:28 [Warning] Checking table: './atlantic2_forum/reputation_totals' 160409 20:52:38 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/search_sessions' is marked as crashed and should be repaired 160409 20:52:38 [Warning] Checking table: './atlantic2_forum/search_sessions' Killed 160409 22:51:47 mysqld_safe Number of processes running now: 0 160409 22:51:47 mysqld_safe mysqld restarted 160409 22:51:47 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 22:51:47 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 22:51:47 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 22:51:47 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 23877 ... 160409 22:51:47 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 22:51:47 [Note] Plugin 'FEDERATED' is disabled. 160409 22:51:47 InnoDB: The InnoDB memory heap is disabled 160409 22:51:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 22:51:47 InnoDB: Compressed tables use zlib 1.2.7 160409 22:51:47 InnoDB: Using Linux native AIO 160409 22:51:48 InnoDB: Initializing buffer pool, size = 1000.0M Killed 160409 22:51:48 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended Я указал большую часть логов вдруг всё связано, даже старые ошибки остались... В чём может быть причина? MySQL падает примерно раз в день, ранее не было этих проблем. Есть и другие логи таких как mysql-queries.log и mysql-slow-queries.log если они понадобятся я готов их выложить тут. Спасибо заранее) ... |
| 10.04.2016, 13:03 |
Падает MySQL
В системных логах есть что-нибудь по теме? Не настроен ли на сервере отстрел процессов по отжиранию памяти, CPU и т.п.? ... |
| 10.04.2016, 20:30 |
Падает MySQL
vkle, Недавно упал весь VDS, хостеры сказали "ваш впс отключила программа контроля активности, вы используете процесс на 100% длительное время, так же у вас есть отказы в ресурсах, скорее всего на вашем сервере аномальная активность." В общем, я в шоке... Системные логи /var/log/syslog.2 вижу были последний раз записаны вчера, наверное в них нет подсказки где проблема. http://pastebin.com/icYPgnkG ... |
| 10.04.2016, 22:24 |
Падает MySQL
Nike555Всем привет) Заранее простите если не в правильном месте я создаю топик, если не правильно попрошу модераторов перенести в соответствующий радел. Появилась 1 проблема, падает MySQL, у меня VDS на Debian. Вот первые mysql-errors логи: 160409 12:07:45 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 12:07:45 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:07:45 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 12:07:45 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 12:07:45 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 28064 ... 160409 12:07:45 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:07:45 [Note] Plugin 'FEDERATED' is disabled. 160409 12:07:45 InnoDB: The InnoDB memory heap is disabled 160409 12:07:45 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 12:07:45 InnoDB: Compressed tables use zlib 1.2.7 160409 12:07:45 InnoDB: Using Linux native AIO 160409 12:07:45 InnoDB: Initializing buffer pool, size = 1000.0M 160409 12:07:45 InnoDB: Completed initialization of buffer pool 160409 12:07:45 InnoDB: highest supported file format is Barracuda. InnoDB: Log scan progressed past the checkpoint lsn 456291970 160409 12:07:45 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 456293033 160409 12:07:46 InnoDB: Starting an apply batch of log records to the database... InnoDB: Progress in percents: 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 InnoDB: Apply batch completed 160409 12:07:47 InnoDB: Waiting for the background threads to start 160409 12:07:48 InnoDB: 5.5.46 started; log sequence number 456293033 160409 12:07:48 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 12:07:48 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 12:07:48 [Note] Server socket created on IP: '0.0.0.0'. 160409 12:07:50 [Note] Event Scheduler: Loaded 0 events 160409 12:07:50 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) 160409 12:07:55 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/cache_store' is marked as crashed and should be repaired 160409 12:07:55 [Warning] Checking table: './atlantic_forum/cache_store' 160409 12:07:55 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/sessions' is marked as crashed and should be repaired 160409 12:07:55 [Warning] Checking table: './atlantic_forum/sessions' 160409 12:07:56 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/task_manager' is marked as crashed and should be repaired 160409 12:07:56 [Warning] Checking table: './atlantic_forum/task_manager' 160409 12:07:57 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/search_sessions' is marked as crashed and should be repaired 160409 12:07:57 [Warning] Checking table: './atlantic2_forum/search_sessions' 160409 12:08:25 [Note] /usr/sbin/mysqld: Normal shutdown 160409 12:08:25 [Note] Event Scheduler: Purging the queue. 0 events 160409 12:08:25 InnoDB: Starting shutdown... 160409 12:08:26 InnoDB: Shutdown completed; log sequence number 456293033 160409 12:08:26 [Note] /usr/sbin/mysqld: Shutdown complete 160409 12:08:26 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 160409 12:08:27 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 12:08:27 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:08:27 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 12:08:27 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 12:08:27 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 31196 ... 160409 12:08:27 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 12:08:27 [Note] Plugin 'FEDERATED' is disabled. 160409 12:08:27 InnoDB: The InnoDB memory heap is disabled 160409 12:08:27 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 12:08:27 InnoDB: Compressed tables use zlib 1.2.7 160409 12:08:27 InnoDB: Using Linux native AIO 160409 12:08:28 InnoDB: Initializing buffer pool, size = 1000.0M 160409 12:08:28 InnoDB: Completed initialization of buffer pool 160409 12:08:28 InnoDB: highest supported file format is Barracuda. 160409 12:08:28 InnoDB: Waiting for the background threads to start 160409 12:08:29 InnoDB: 5.5.46 started; log sequence number 456293033 160409 12:08:29 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 12:08:29 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 12:08:29 [Note] Server socket created on IP: '0.0.0.0'. 160409 12:08:29 [Note] Event Scheduler: Loaded 0 events 160409 12:08:29 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) Killed Как я заметил упал он из за повреждённых табелей, я вписал запрос в phpmyadmin(для каждой таблицы): Код: sql 1. Думал исправилось, но нет, опять mysql упал, с немного отличающими логами. 160409 19:13:46 mysqld_safe Number of processes running now: 0 160409 19:13:46 mysqld_safe mysqld restarted 160409 19:13:47 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 19:13:47 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 19:13:47 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 19:13:47 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 14185 ... 160409 19:13:47 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 19:13:47 [Note] Plugin 'FEDERATED' is disabled. 160409 19:13:47 InnoDB: The InnoDB memory heap is disabled 160409 19:13:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 19:13:47 InnoDB: Compressed tables use zlib 1.2.7 160409 19:13:47 InnoDB: Using Linux native AIO 160409 19:13:47 InnoDB: Initializing buffer pool, size = 1000.0M 160409 19:13:48 InnoDB: Completed initialization of buffer pool Killed 160409 19:13:48 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended 160409 20:52:11 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql 160409 20:52:11 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 20:52:11 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 20:52:11 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 20:52:11 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 17346 ... 160409 20:52:11 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 20:52:11 [Note] Plugin 'FEDERATED' is disabled. 160409 20:52:11 InnoDB: The InnoDB memory heap is disabled 160409 20:52:11 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 20:52:11 InnoDB: Compressed tables use zlib 1.2.7 160409 20:52:11 InnoDB: Using Linux native AIO 160409 20:52:11 InnoDB: Initializing buffer pool, size = 1000.0M 160409 20:52:11 InnoDB: Completed initialization of buffer pool 160409 20:52:11 InnoDB: highest supported file format is Barracuda. InnoDB: Log scan progressed past the checkpoint lsn 465561681 160409 20:52:11 InnoDB: Database was not shut down normally! InnoDB: Starting crash recovery. InnoDB: Reading tablespace information from the .ibd files... InnoDB: Restoring possible half-written data pages from the doublewrite InnoDB: buffer... InnoDB: Doing recovery: scanned up to log sequence number 465563579 160409 20:52:12 InnoDB: Starting an apply batch of log records to the database... InnoDB: Progress in percents: 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 InnoDB: Apply batch completed 160409 20:52:12 InnoDB: Waiting for the background threads to start 160409 20:52:13 InnoDB: 5.5.46 started; log sequence number 465563579 160409 20:52:13 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306 160409 20:52:13 [Note] - '0.0.0.0' resolves to '0.0.0.0'; 160409 20:52:13 [Note] Server socket created on IP: '0.0.0.0'. 160409 20:52:14 [Note] Event Scheduler: Loaded 0 events 160409 20:52:14 [Note] /usr/sbin/mysqld: ready for connections. Version: '5.5.46-0+deb7u1-log' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian) 160409 20:52:15 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/cache_store' is marked as crashed and should be repaired 160409 20:52:15 [Warning] Checking table: './atlantic_forum/cache_store' 160409 20:52:15 [ERROR] /usr/sbin/mysqld: Table './atlantic_forum/task_manager' is marked as crashed and should be repaired 160409 20:52:15 [Warning] Checking table: './atlantic_forum/task_manager' 160409 20:52:16 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/core_like_cache' is marked as crashed and should be repaired 160409 20:52:16 [Warning] Checking table: './atlantic2_forum/core_like_cache' 160409 20:52:16 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/reputation_cache' is marked as crashed and should be repaired 160409 20:52:16 [Warning] Checking table: './atlantic2_forum/reputation_cache' 160409 20:52:28 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/reputation_totals' is marked as crashed and should be repaired 160409 20:52:28 [Warning] Checking table: './atlantic2_forum/reputation_totals' 160409 20:52:38 [ERROR] /usr/sbin/mysqld: Table './atlantic2_forum/search_sessions' is marked as crashed and should be repaired 160409 20:52:38 [Warning] Checking table: './atlantic2_forum/search_sessions' Killed 160409 22:51:47 mysqld_safe Number of processes running now: 0 160409 22:51:47 mysqld_safe mysqld restarted 160409 22:51:47 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead. 160409 22:51:47 [Warning] The syntax '--log' is deprecated and will be removed in a future release. Please use '--general-log'/'--general-log-file' instead. 160409 22:51:47 [Warning] The syntax '--log-slow-queries' is deprecated and will be removed in a future release. Please use '--slow-query-log'/'--slow-query-log-file' instead. 160409 22:51:47 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0+deb7u1-log) starting as process 23877 ... 160409 22:51:47 [Warning] Using unique option prefix myisam-recover instead of myisam-recover-options is deprecated and will be removed in a future release. Please use the full name instead. 160409 22:51:47 [Note] Plugin 'FEDERATED' is disabled. 160409 22:51:47 InnoDB: The InnoDB memory heap is disabled 160409 22:51:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins 160409 22:51:47 InnoDB: Compressed tables use zlib 1.2.7 160409 22:51:47 InnoDB: Using Linux native AIO 160409 22:51:48 InnoDB: Initializing buffer pool, size = 1000.0M Killed 160409 22:51:48 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended Я указал большую часть логов вдруг всё связано, даже старые ошибки остались... В чём может быть причина? MySQL падает примерно раз в день, ранее не было этих проблем. Есть и другие логи таких как mysql-queries.log и mysql-slow-queries.log если они понадобятся я готов их выложить тут. Спасибо заранее) ....как в старон анекдоте, у нас не старана баранов а Страна Советов. Так что заранее пардон за советы, они могут быть не в тему.... но попробуем... 1. Apr 8 03:56:53 vm621799 kernel: Out of memory in UB: OOM killed process 2880 (mysqld) score 0 vm:1445276kB, rss:193428kB, swap:0kB OOM killed -- встречал такое, где-то есть параметер сервера о регулировании памяти. Если памяти достаточно или память "стабильна", то mysql резервирует память "мягко-оптимистично". Однако если после резервации операционка загрузит эту "полу-зарезервированую" память сама то mysql конкретно обломается при попытке адресации туда и будет убит с записью "OOM killed". Лечится путем запрешения "мягкой резервации памяти". Кажется это параметер кернеля линукся...а может параметер mysql. поишите гугле на темы "mysql OOM killed" ... |
| 10.04.2016, 22:45 |
Падает MySQL
2. Apr 9 03:51:06 vm621799 rsyslogd: [origin software="rsyslogd" swVersion="5.8.11" x-pid="1603" x-info=" http://www.rsyslog.com%22%5D]http://www.rsyslog.com"] rsyslogd was HUPed в другом варианте, я видел как неправильно-настроеный logrotate (или rsync?) зависали конкретно потому что не смогли закрыть открытый лог файл. В результате процесс грузил CPU на 100% и монитору пришлось убивать процесс нафик... лечится правильной настройкой или заменой процесса смены лога или изменением процесса бекап/синхронизации. ... |
| 10.04.2016, 22:51 |
Падает MySQL
Nike555ваш впс отключила программа контроля активности, вы используете процесс на 100% длительное времяХм... А что, по условию договора нельзя по своему усмотрению использовать выделенные ВПСке ресурсы? ... |
| 10.04.2016, 23:49 |
Падает MySQL
javajdbc....как в старон анекдоте, у нас не старана баранов а Страна Советов. Так что заранее пардон за советы, они могут быть не в тему.... но попробуем... 1. Apr 8 03:56:53 vm621799 kernel: Out of memory in UB: OOM killed process 2880 (mysqld) score 0 vm:1445276kB, rss:193428kB, swap:0kB OOM killed -- встречал такое, где-то есть параметер сервера о регулировании памяти. Если памяти достаточно или память "стабильна", то mysql резервирует память "мягко-оптимистично". Однако если после резервации операционка загрузит эту "полу-зарезервированую" память сама то mysql конкретно обломается при попытке адресации туда и будет убит с записью "OOM killed". Лечится путем запрешения "мягкой резервации памяти". Кажется это параметер кернеля линукся...а может параметер mysql. поишите гугле на темы "mysql OOM killed" По гуглил, и понял что может помочь: 1) Сделать оптимизацию всех табелей через phpmyadmin 2) увеличить эти значения в my.cnf key_buffer_size (> 1.4G) query_cache_size (> 32M) table_cache (> 64) innodb_buffer_pool_size (>= 22G) 3) Добавить в my.cnf: performance_schema = off Да, скорее всего поможет второй вариант, но это не думаю что решит проблему (если только у меня в VDS-е не выставлены корректно они), да но с этим вариантом я не могу найти точную причину (т.е. какой сайт/база провоцирует такое) Вот мой my.cnf http://pastebin.com/hMvL6LGH (прошу посмотреть, если там всё норм, и стоит ли увеличить те параметры?) Вот как выглядит мой logrotate.conf из /etc/ http://pastebin.com/ABV9XKeA vkleХм... А что, по условию договора нельзя по своему усмотрению использовать выделенные ВПСке ресурсы? Вы о каких именно ресурсов имеете введу? Я решил на данный момент отключать сайты и включить их по 2-ум, возможно таким способом я найду в каком сайте проблема. Спасибо заранее) ... |
| 11.04.2016, 14:33 |
Падает MySQL
авторЛечится путем запрешения "мягкой резервации памяти". лечится уменьшением буферов в настройках. ... |
| 11.04.2016, 15:31 |
Падает MySQL
ScareCrowавторЛечится путем запрешения "мягкой резервации памяти". лечится уменьшением буферов в настройках. ...то про что я рассказывал, лечится запрешением как указано... ... |
| 11.04.2016, 18:44 |
Падает MySQL
javajdbcScareCrowпропущено... лечится уменьшением буферов в настройках. ...то про что я рассказывал, лечится запрешением как указано... Можно пожалуйста по подробнее что и как мне сделать это?) Просто я ранее таких изменении не делал) ... |
| 11.04.2016, 19:01 |
Падает MySQL
Nike555javajdbcпропущено... ...то про что я рассказывал, лечится запрешением как указано... Можно пожалуйста по подробнее что и как мне сделать это?) Просто я ранее таких изменении не делал) Во первых, никто не доказал что у вас имено в этом проблема. У меня один раз было такое, поменял настройки линукса и все ОК. Поможет ли вам -- бабушка надвое сказала. OOM killed может быть следствием какой-то другой бяки... Если таки дело в этом, то надо выставить в настройках линукса: vm.overcommit_memory = 2 (почитайте Гугле как это делается, а не специалист) Если вы на расшареном сервере, то вас, скорее всего, не подпустят поменять эти настройки. В таком случае меняйте поставшика или работаейте как предложил ScareCrow -- уменьшать буфера. ... |
| 11.04.2016, 19:26 |
Падает MySQL
javajdbcNike555пропущено... Можно пожалуйста по подробнее что и как мне сделать это?) Просто я ранее таких изменении не делал) Во первых, никто не доказал что у вас имено в этом проблема. У меня один раз было такое, поменял настройки линукса и все ОК. Поможет ли вам -- бабушка надвое сказала. OOM killed может быть следствием какой-то другой бяки... Если таки дело в этом, то надо выставить в настройках линукса: vm.overcommit_memory = 2 (почитайте Гугле как это делается, а не специалист) Если вы на расшареном сервере, то вас, скорее всего, не подпустят поменять эти настройки. В таком случае меняйте поставшика или работаейте как предложил ScareCrow -- уменьшать буфера. Вы про? (из my.cnf) key_buffer_size (> 1.4G) innodb_buffer_pool_size (>= 22G) Просто откуда я читал на оборот писаль что надо увеличить размер )) А что насчёт добавление в my.cnf? performance_schema = off Добавить или нет(лично я не знаю, но видел пост что может помочь)? ... |
| 11.04.2016, 20:57 |
Падает MySQL
Nike555, Тут примерно такое дело: Если (виртуальная) машина имеет гарантированое количество памяти, то имеет смысл ее забивать почти до предела буферами. например -- увеличивать key_buffer_size и innodb_buffer_pool_size Однако если количества памяти НЕ гарантировано, например на обшем сервере, то чем меньше буферов, тем меньше опасности OOM killed (если вообше в этом причина). performance_schema = off --- ну наверно на эту схему, на сбор статистики, тратятся ресурсы, на которых можно секономить.... ... |
| 12.04.2016, 02:49 |
Падает MySQL
javajdbc, Хостеры подтвердили, что это OOM Killed Apr 10 17:22:42 vm621799 kernel: Out of memory in UB: OOM killed process 10974 (mysqld) score 0 vm:1519648kB, rss:221956kB, swap:0kB Apr 10 17:22:47 vm621799 kernel: Out of memory in UB: OOM killed process 24949 (mysqld) score 0 vm:1500180kB, rss:152868kB, swap:0kB Apr 10 17:22:48 vm621799 kernel: Out of memory in UB: OOM killed process 25009 (mysqld) score 0 vm:1270964kB, rss:106096kB, swap:0kB Apr 10 20:33:16 vm621799 kernel: Out of memory in UB: OOM killed process 26049 (mysqld) score 0 vm:1510424kB, rss:201560kB, swap:0kB Ввел команду "top" в в консольке и увидел что mysql занимает ~9.5% (вроде как плохо) и по немного увеличивается попробовал выключить все сайты, но нагрузка на mysql осталась... значит проблема не в самих сайтов, а именно в базе что то не то? Или я не правильно понял? Также посмотрел 1 решение, но хотел бы у вас спросить, стоит поставить?: sysctl -w vm.oom_kill_allocating_task=0 echo 50 > /proc/sys/vm/overcommit_ratio echo 0 > /proc/sys/vm/overcommit_memory вот какая нагрузка идёт на буффер http://prntscr.com/arescg Вот часть моего my.cnf http://prntscr.com/arevw2 вот характеристики моего VDS http://prntscr.com/argdk6 может тут мне надо поставить на read_buffer_size, key_buffer, innodb_buffer_pool_size значение по больше? Если да, какие значения по советуйте? ... |
| 12.04.2016, 22:17 |
Падает MySQL
Nike555, OK, тогда идем дальше. 1. Если вы контролируете рут, то добавьте фаил /etc/sysctl.d/10-no-overcommit.conf с линиями vm.overcommit_memory = 2 vm.overcommit_ratio = 98 перегрузите сервер и проследите что происходит. Заметте - "2" -- вообше запретить оверкомит, а не "0" когда и системы есть право решения. Возможно на другом Линуксе это надо делать по другому. 2. Если вы НЕ контролируете рут и сервер в целом, то я не в курсе как контролировать оверкомит. 3. поставьте и прогоните програмку из этого сайта http://mysqltuner.com/ Кроме всего прочего она вам подсчитает сколько Памяти ваш мыскл может теоретически захватить. Этот скрипт выдает рекомендации -- можете сами им аккуратно следовать -- если что непонятно. Выдайте результат скрипта сюда. 4. Кстати, возможно ScareCrow права, если правильно настроить буфера то играться с overcommit может и не нужно. Вам надо сделать свои тесты. (в моем случае буфера были вполне настроены но ООМ-киллед исправил только overcommit=2) 5. ну и вообше кроме-кроме всего прочего, изучать почему нагрузка большая нужно полюбому. СЛоу-квери-лог и процесслист -- ваши друзья... ... |
| 12.04.2016, 23:24 |
Падает MySQL
Nike555вот какая нагрузка идёт на буффер http://prntscr.com/arescg Вот часть моего my.cnf http://prntscr.com/arevw2 вот характеристики моего VDS http://prntscr.com/argdk6 может тут мне надо поставить на read_buffer_size, key_buffer, innodb_buffer_pool_size значение по больше? Если да, какие значения по советуйте? ...как раз http://mysqltuner.com/ вам и подскажет... ... |
| 12.04.2016, 23:27 |
Падает MySQL
Nike555javajdbc, Ввел команду "top" в в консольке и увидел что mysql занимает ~9.5% (вроде как плохо) и по немного увеличивается попробовал выключить все сайты, но нагрузка на mysql осталась... значит проблема не в самих сайтов, а именно в базе что то не то? Или я не правильно понял? Это - нормально. Очень много ерунды написано про "оптимизацию", но по факту настройка стандартного сайта сводится к ограничению плодовитости процессов php и достижению таким образом стабильности. Вам нужно настроить так чтобы и mysql потреблял достаточно и на кеш файлов хватало и остальные процессы не разрастались. Сейчас самые умные хостеры в шаблонах сразу устанавливают nginx, а значение MaxClients в apache ограничено скромным значением. в зависимости от размера памяти. Сделайте и вы так. То есть на ваши параметры (800мб ОЗУ) надо допустим MaxClients 15 , а innodb_buffer_pool_size значительно уменьшить. Допустим, 200мб. Остальное трогать ПОКА не нужно, что бы там ни писал mysqltuner. ... |
| 13.04.2016, 11:34 |
Падает MySQL
Всем спасибо за помощь :) Не отвечал в теме так долго потому что хостеры исправили/настроили это (вроде как, надеюсь). Как они это сделали, молчат(я их спросил), но главное что проблема решилась. Именно 13 числа они сделали эти изменения, и того дня mysql не разу не упал. 13 числа вечером mysql занял 13.5 % памяти, 14 числа 13.4 %, сейчас 13.8 % (но думаю и это хороший показатель). Ещё раз благодарю за помощь) ... |
| 15.04.2016, 12:54 |
start [/forum/topic.php?desktop=1&fid=47&tid=1831896]: |
78ms |
33ms |
| others: | 204ms |
| total: | 355ms |
