Can't open and lock privilege tables: Table 'mysql.host' doesn't exist +
устанавливал второй раз в жизни. сегодня пробовал ставить под две разные винды версии 5.0, 5.1, и последнюю в разных комбинациях: руками, через инсталлятор по умолчанию, с выбором. во всех версиях 1) зависает конфигуратор 2) при запуске сервера получаю Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist на текущей xp, что бы пользоваться запускаю как Код: plaintext 1. 2. # Example MySQL config file for medium systems. # # This is for a system with little memory (32M - 64M) where MySQL plays # an important part, or systems up to 128M where MySQL is used together with # other programs (such as a web server) # # You can copy this file to # /etc/my.cnf to set global options, # mysql-data-dir/my.cnf to set server-specific options (in this # installation this directory is C:\mysql\data) or # ~/.my.cnf to set user-specific options. # # In this file, you can use all long options that a program supports. # If you want to know which options a program supports, run the program # with the "--help" option. # The following options will be passed to all MySQL clients [client] #password = your_password port = 3306 socket = /tmp/mysql.sock # Here follows entries for some specific programs # The MySQL server [mysqld] basedir=C:/bin/Mysql datadir=C:/bin/Mysql/db port = 3306 socket = /tmp/mysql.sock skip-locking key_buffer = 16M max_allowed_packet = 1M table_cache = 64 sort_buffer_size = 512K net_buffer_length = 8K read_buffer_size = 256K read_rnd_buffer_size = 512K myisam_sort_buffer_size = 8M # Don't listen on a TCP/IP port at all. This can be a security enhancement, # if all processes that need to connect to mysqld run on the same host. # All interaction with mysqld must be made via Unix sockets or named pipes. # Note that using this option without enabling named pipes on Windows # (via the "enable-named-pipe" option) will render mysqld useless! # #skip-networking # Disable Federated by default skip-federated # Replication Master Server (default) # binary logging is required for replication log-bin=mysql-bin # required unique id between 1 and 2^32 - 1 # defaults to 1 if master-host is not set # but will not function as a master if omitted server-id = 1 # Replication Slave (comment out master section to use this) # # To configure this host as a replication slave, you can choose between # two methods : # # 1) Use the CHANGE MASTER TO command (fully described in our manual) - # the syntax is: # # CHANGE MASTER TO MASTER_HOST=<host>, MASTER_PORT=<port>, # MASTER_USER=<user>, MASTER_PASSWORD=<password> ; # # where you replace <host>, <user>, <password> by quoted strings and # <port> by the master's port number (3306 by default). # # Example: # # CHANGE MASTER TO MASTER_HOST='125.564.12.1', MASTER_PORT=3306, # MASTER_USER='joe', MASTER_PASSWORD='secret'; # # OR # # 2) Set the variables below. However, in case you choose this method, then # start replication for the first time (even unsuccessfully, for example # if you mistyped the password in master-password and the slave fails to # connect), the slave will create a master.info file, and any later # change in this file to the variables' values below will be ignored and # overridden by the content of the master.info file, unless you shutdown # the slave server, delete master.info and restart the slaver server. # For that reason, you may want to leave the lines below untouched # (commented) and instead use CHANGE MASTER TO (see above) # # required unique id between 2 and 2^32 - 1 # (and different from the master) # defaults to 2 if master-host is set # but will not function as a slave if omitted #server-id = 2 # # The replication master for this slave - required #master-host = <hostname> # # The username the slave will use for authentication when connecting # to the master - required #master-user = <username> # # The password the slave will authenticate with when connecting to # the master - required #master-password = <password> # # The port the master is listening on. # optional - defaults to 3306 #master-port = <port> # # binary logging - not required for slaves, but recommended #log-bin=mysql-bin # Point the following paths to different dedicated disks #tmpdir = /tmp/ #log-update = /path-to-dedicated-directory/hostname # Uncomment the following if you are using BDB tables #bdb_cache_size = 4M #bdb_max_lock = 10000 # Uncomment the following if you are using InnoDB tables #innodb_data_home_dir = C:\mysql\data/ #innodb_data_file_path = ibdata1:10M:autoextend #innodb_log_group_home_dir = C:\mysql\data/ #innodb_log_arch_dir = C:\mysql\data/ # You can set .._buffer_pool_size up to 50 - 80 % # of RAM but beware of setting memory usage too high #innodb_buffer_pool_size = 16M #innodb_additional_mem_pool_size = 2M # Set .._log_file_size to 25 % of buffer pool size #innodb_log_file_size = 5M #innodb_log_buffer_size = 8M #innodb_flush_log_at_trx_commit = 1 #innodb_lock_wait_timeout = 50 [mysqldump] quick max_allowed_packet = 16M [mysql] no-auto-rehash # Remove the next comment character if you are not familiar with SQL #safe-updates [isamchk] key_buffer = 20M sort_buffer_size = 20M read_buffer = 2M write_buffer = 2M [myisamchk] key_buffer = 20M sort_buffer_size = 20M read_buffer = 2M write_buffer = 2M [mysqlhotcopy] interactive-timeout создать базу, выбрать её создать таблицу, внести в неё строчку, извлечь эту строчку, расконектится, присоединиться, выбрать базу, опять извлечь строчку -- все удается. Но таки хочется убрать ошибку. Что делать? второй вопрос - какой ado провайдер брать? ... |
| 31.05.2016, 15:20 |
tchingiz1) зависает конфигуратор 2) при запуске сервера получаю Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't existПо обоим признакам есть ощущение, что MySQL ставится не с нуля, а поверх другой версии. Другой базы/другого конфига нигде не валяется? Что в логах MySQL ? ... |
| 31.05.2016, 19:26 |
где их смотреть? ... |
| 31.05.2016, 20:05 |
сутя по указанным путям c:/bin/Mysql/data файл <ИмяКомпьютера>.err ... |
| 01.06.2016, 05:57 |
Alex_Ustinovсутя по указанным путям c:/bin/Mysql/data файл <ИмяКомпьютера>.err в смысле тут нет таких файлов ---------- ls -1l C:\bin\Mysql\data\ total 0 drwxr-xr-x 1 agp Отсутствует 0 May 31 13:40 mysql drwxr-xr-x 1 agp Отсутствует 0 May 31 13:40 test ------------- ... |
| 02.06.2016, 14:10 |
tchingiz, ну а вообще по всему компу поискать файлы *.err ? ... |
| 02.06.2016, 14:24 |
нашел такие логи \в Код: plaintext 1. Сейчас там ничего не появляется ... |
| 02.06.2016, 14:26 |
из той версии майскл запустился и его лог автор160602 14:25:52 [Note] C:\Documents and Settings\Гость\Рабочий стол\DENWER WebServers\usr\local\mysql5\bin\mysqld.exe: ready for connections. Version: '5.0.45-community-nt' socket: '' port: 3306 MySQL Community Edition (GPL) ... |
| 02.06.2016, 14:29 |
как вы его запускаете непонятно. Сначала удалите старый. "Службу" остановите старую и удалите В Факе есть тема по установке за 5 минут. Уберите из "видимости" пути (в PATH ) к старому серверу ... |
| 02.06.2016, 14:49 |
и там разница между запуском 5,0 и 5,1 Возможно вы думаете что запускаете 5,1 а на самом деле идет запуск 5,0 ... |
| 02.06.2016, 14:54 |
| 02.06.2016, 15:05 |
Alex_Ustinovкак вы его запускаете непонятно. Сначала удалите старый. "Службу" остановите старую и удалите В Факе есть тема по установке за 5 минут. Уберите из "видимости" пути (в PATH ) к старому серверу увы ни моя инсталляция и старая не видны по path PATH= d:\bin\cygwin\bin; c:\bin;C:\Program Files\MiKTeX 2.8\miktex\bin; C:\Inprise\vbroker\bin; C:\WINDOWS\system32; C:\WINDOWS; C:\WINDOWS\System32\Wbem; C:\Program Files\MATLAB\R2011a\runtime\win32; C:\Program Files\MATLAB\R2011a\bin; C:\PROGRA~1\Borland\Delphi6\Bin; C:\PROGRA~1\Borland\Delphi6\Projects\Bpl; D:\PROGRA~1\Borland\Delphi6\Bin; D:\PROGRA~1\Borland\Delphi6\Projects\Bpl в службах нет ничего содержащего слово SQL Запущены следующие службы Windows: DeskSaverService DHCP-клиент DNS-клиент ESET Service HID Input Service Machine Debug Manager NVIDIA Display Driver Service Plug and Play Windows Audio Автоматическое обновление Беспроводная настройка Брандмауэр Windows/Общий доступ к Интернету (ICS) Веб-клиент Вторичный вход в систему Диспетчер логических дисков Диспетчер очереди печати Диспетчер подключений удаленного доступа Диспетчер учетных записей безопасности Журнал событий Запуск серверных процессов DCOM Защищенное хранилище Инструментарий управления Windows Клиент отслеживания изменившихся связей Маршрутизация и удаленный доступ Модуль поддержки NetBIOS через TCP/IP Обозреватель компьютеров Определение оборудования оболочки Планировщик заданий Протокол HTTP SSL Рабочая станция Сервер Сетевые подключения Система событий COM+ Служба загрузки изображений (WIA) Служба обнаружения SSDP Служба регистрации ошибок Служба сетевого расположения (NLA) Служба шлюза уровня приложения Службы IPSEC Службы криптографии Телефония Темы Уведомление о системных событиях Удаленный вызов процедур (RPC) Команда выполнена успешно. ... |
| 02.06.2016, 15:33 |
tchingizв службах нет ничего содержащего слово SQLНу так это только запущенные службы. А MySQL, видимо, если есть в виде службы, то в этот момент был не запущен. Кстати, MySQL может и просто как exe-файл запускаться, без создания службы, если надо. ... |
| 02.06.2016, 16:07 |
miksoft, он так и запускает - консольно mysqld-nt --console --skip-grant-tables tchingiz, имейте ввиду mysqld-nt - запуск 5.0 mysqld - запуск 5.1 и поищите my.ini сколько их там у вас, может быть указать явно в строке запуска --default-config.... ... |
| 02.06.2016, 16:13 |
miksofttchingizв службах нет ничего содержащего слово SQLНу так это только запущенные службы. А MySQL, видимо, если есть в виде службы, то в этот момент был не запущен. Кстати, MySQL может и просто как exe-файл запускаться, без создания службы, если надо. :)) оставновленные я тоже посмотрел, просто их список в текстовый файл я не умею складывать. без создания службы я его и запускаю (ту версию, которую поставил сам, когда не знал, что он уже стоит). Ок, дополнительная мысль, в автостарт завтра загляну. ... |
| 02.06.2016, 19:58 |
в каталоге datadir=C:/bin/Mysql/db нет подкаталога C:/bin/Mysql/db/mysql total 20485 -rwxr-x---+ 1 agp Отсутствует 5242880 Jun 3 15:40 ib_logfile0 -rwxr-x---+ 1 agp Отсутствует 5242880 May 31 13:46 ib_logfile1 -rwxr-x---+ 1 agp Отсутствует 10485760 Jun 3 15:40 ibdata1 -rwxr-x---+ 1 agp Отсутствует 98 May 31 13:46 mysql-bin.000001 -rwxr-x---+ 1 agp Отсутствует 98 May 31 13:47 mysql-bin.000002 -rwxr-x---+ 1 agp Отсутствует 98 Jun 3 15:34 mysql-bin.000024 -rwxr-x---+ 1 agp Отсутствует 117 Jun 3 15:40 mysql-bin.000025 -rwxr-x---+ 1 agp Отсутствует 475 Jun 3 15:38 mysql-bin.index drwxrwx---+ 1 agp Отсутствует 0 Jun 3 13:29 ssss drwxrwx---+ 1 agp Отсутствует 0 Jun 3 13:29 ssss1 drwxrwx---+ 1 agp Отсутствует 0 Jun 3 13:30 ssss132 drwxrwx---+ 1 agp Отсутствует 0 May 31 13:53 test drwxrwx---+ 1 agp Отсутствует 0 May 31 13:58 test2 в каталоге datadir=C:/bin/Mysql/data есть total 20483 -rwxr-x---+ 1 agp Отсутствует 5242880 Jun 3 15:41 ib_logfile0 -rwxr-x---+ 1 agp Отсутствует 5242880 Jun 3 15:40 ib_logfile1 -rwxr-x---+ 1 agp Отсутствует 10485760 Jun 3 15:41 ibdata1 drwxrwx---+ 1 Администраторы SYSTEM 0 May 31 13:40 mysql <-------------------- -rwxr-x---+ 1 agp Отсутствует 98 Jun 3 15:40 mysql-bin.000001 -rwxr-x---+ 1 agp Отсутствует 117 Jun 3 15:41 mysql-bin.000002 -rwxr-x---+ 1 agp Отсутствует 38 Jun 3 15:40 mysql-bin.index drwxrwx---+ 1 Администраторы SYSTEM 0 May 31 13:40 test если datadir содержит mysql то все хорошо, можно без опции --skip-grant-tables ... |
| 03.06.2016, 15:49 |
tchingiz, Если среди ранее установленных баз нет нужных данных, то предлагаю все максимально вычистить, а затем с нуля ставить. Это выйдет быстрее и надежнее, чем разбираться где какой файл от какой версии. ... |
| 03.06.2016, 15:59 |
start [/forum/topic.php?desktop=1&fid=47&tid=1831702]: |
186ms |
46ms |
| others: | 285ms |
| total: | 562ms |
