MySQL не стартует после обновления
Добрый день. Обновлял на генте мир(давно не обновлялсо), среди прочего обновился мускуль до 5.6 При попытке старта появилась ошибка: Код: sql 1. 2. 3. 4. 5. сообщение в логах: mysqld.err2017-03-03 13:21:02 4063 [Warning] No argument was provided to --log-bin, and --log-bin-index was not used; so replication may break when this MySQL server acts as a master and has his hostname changed!! Please use '--log-bin=mysqld-bin' to avoid this problem. 2017-03-03 13:21:02 4063 [Note] InnoDB: Using atomics to ref count buffer pool pages 2017-03-03 13:21:02 4063 [Note] InnoDB: The InnoDB memory heap is disabled 2017-03-03 13:21:02 4063 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins 2017-03-03 13:21:02 4063 [Note] InnoDB: Memory barrier is not used 2017-03-03 13:21:02 4063 [Note] InnoDB: Compressed tables use zlib 1.2.11 2017-03-03 13:21:02 4063 [Note] InnoDB: Using Linux native AIO 2017-03-03 13:21:02 4063 [Note] InnoDB: Not using CPU crc32 instructions 2017-03-03 13:21:02 4063 [Note] InnoDB: Initializing buffer pool, size = 128.0M 2017-03-03 13:21:02 4063 [Note] InnoDB: Completed initialization of buffer pool 2017-03-03 13:21:02 4063 [ERROR] InnoDB: Space id in fsp header 1416128883,but in the page header 824195850 10:21:02 UTC - mysqld got signal 11 ; This could be because you hit a bug. It is also possible that this binary or one of the libraries it was linked against is corrupt, improperly built, or misconfigured. This error can also be caused by malfunctioning hardware. We will try our best to scrape up some info that will hopefully help diagnose the problem, but since we have already crashed, something is definitely wrong and this may fail. key_buffer_size=16777216 read_buffer_size=262144 max_used_connections=0 max_threads=151 thread_count=0 connection_count=0 It is possible that mysqld could use up to key_buffer_size + (read_buffer_size + sort_buffer_size)*max_threads = 133629 K bytes of memory Hope that's ok; if not, decrease some variables in the equation. Thread pointer: 0x0 Attempting backtrace. You can use the following information to find out where mysqld died. If you see no messages after this, something went terribly wrong... stack_bottom = 0 thread_stack 0x30000 /usr/sbin/mysqld(my_print_stacktrace+0x57)[0x84c2ef7] /usr/sbin/mysqld(handle_fatal_signal+0x3c1)[0x8266451] /lib/libz.so.1(adler32_z+0x11f)[0xb777b4bf] /lib/libz.so.1(adler32+0x2b)[0xb777b79b] /usr/sbin/mysqld[0x854917b] /usr/sbin/mysqld[0x85e5544] /usr/sbin/mysqld[0x862adf2] /usr/sbin/mysqld[0x85998e9] /usr/sbin/mysqld[0x84ebe67] /usr/sbin/mysqld(_Z24ha_initialize_handlertonP13st_plugin_int+0x41)[0x81b6bf1] /usr/sbin/mysqld[0x82e7204] /usr/sbin/mysqld(_Z11plugin_initPiPPci+0x948)[0x82eb828] /usr/sbin/mysqld(_Z11mysqld_mainiPPc+0x83d)[0x81b024d] /usr/sbin/mysqld(main+0x1b)[0x818faeb] /lib/libc.so.6(__libc_start_main+0xf4)[0xb71bb5c4] /usr/sbin/mysqld[0x81a4d9c] The manual page at http://dev.mysql.com/doc/mysql/en/crashing.html contains information that should help you find out what is causing the crash. где искать причины? ... |
| 03.03.2017, 13:18 |
unrecovered, По-хорошему нужно было сделать дамп базы, обновиться, создать новую базу и накатить дамп. Теперь попробуйте так: https://dev.mysql.com/doc/refman/5.6/en/upgrading.html In-Place Upgrade: Involves shutting down the old MySQL version, replacing the old MySQL binaries or packages with the new ones, restarting MySQL on the existing data directory, and running mysql_upgrade. Разумеется, предварительно нужно скопировать в сторонку хотя бы то, что осталось. ... |
| 03.03.2017, 15:19 |
start [/forum/topic.php?desktop=1&fid=47&tid=1830871]: |
194ms |
| others: | 235ms |
| total: | 487ms |
