Триггер выдает ошибку
Помогите разобраться, почему не работает триггер (Выбивает #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 3 ) CREATE TRIGGER `ORDERING` BEFORE INSERT ON `orders` FOR EACH ROW BEGIN IF (SELECT COUNT(id_orders) FROM orders WHERE id_cl=NEW.id_cl)=3 THEN UPDATE clients SET discount='5%' WHERE id_clients=NEW.id_cl; END IF; IF(SELECT discount FROM clients WHERE id_clients=NEW.id_cl)='5%' THEN SET NEW.oplata=TRUNCATE((SELECT price_product FROM products WHERE id_products=NEW.id_prod)*0.95,2); ELSE SET NEW.oplata=TRUNCATE((SELECT price_product FROM products WHERE id_products=NEW.id_prod),2); END IF; IF (SELECT COUNT(id_orders) FROM orders WHERE id_cl=NEW.id_cl)=8 THEN UPDATE clients SET discount='10%' WHERE id_clients=NEW.id_cl; END IF; IF(SELECT discount FROM clients WHERE id_clients=NEW.id_cl)='10%' THEN SET NEW.oplata=TRUNCATE((SELECT price_product FROM products WHERE id_products=NEW.id_prod)*0.90,2); ELSE SET NEW.oplata=TRUNCATE((SELECT price_product FROM products WHERE id_products=NEW.id_prod),2); END ... |
| 01.05.2017, 15:45 |
start [/forum/topic.php?desktop=1&fid=47&tid=1830712]: |
163ms |
38ms |
| others: | 202ms |
| total: | 441ms |
