MySQL installing failed
Пробую установить MySQL, но полдня и больше уже ничего не получается Кто-нибудь может оказать помощь? Картинку приложил В log пишет следующее Beginning configuration step: Writing configuration file Ended configuration step: Writing configuration file Beginning configuration step: Updating Windows Firewall rules Attempting to delete a Windows Firewall rule with command: netsh.exe advfirewall firewall delete rule name="Port 3306" protocol=TCP localport=3306 “¤ «Ґл Їа ўЁ« : 1. ЋЉ. Adding a Windows Firewall rule for MYSQL80 on port 3306. Attempting to add a Windows Firewall rule with command: netsh.exe advfirewall firewall add rule name="Port 3306" protocol=TCP localport=3306 dir=in action=allow ЋЉ. Successfully added the Windows Firewall rule. Ended configuration step: Updating Windows Firewall rules Beginning configuration step: Adjusting Windows service Attempting to grant Network Service require filesystem permissions. Granted permissions. Adding new service New service added Ended configuration step: Adjusting Windows service Beginning configuration step: Initializing Database Attempting to run MySQL Server with --initialize-insecure option... Starting process for MySQL Server 8.0.11... Starting process with command: C:\Program Files (x86)\MySQL(2)\bin\mysqld.exe --defaults-file="C:\ProgramData\MySQL\MySQL Server 8.0\my.ini" --console --initialize-insecure=on... 2018-07-03T12:02:33.210916Z 0 [ERROR] [MY-011071] [Server] Unknown suffix '.' used for variable 'lower_case_table_names' (value '0.0') 2018-07-03T12:02:33.210972Z 0 [ERROR] [MY-011071] [Server] C:\Program Files (x86)\MySQL(2)\bin\mysqld.exe: Error while setting value '0.0' to 'lower_case_table_names' 2018-07-03T12:02:33.211004Z 0 [ERROR] [MY-010119] [Server] Aborting 2018-07-03T12:02:33.211074Z 0 [Note] [MY-010120] [Server] Binlog end Process for mysqld, with ID 5368, was run successfully and exited with code 1. Failed to start process for MySQL Server 8.0.11. Database initialization failed. Ended configuration step: Initializing Database ... |
| 03.07.2018, 15:05 |
anton62018-07-03T12:02:33.210916Z 0 [ERROR] [MY-011071] [Server] Unknown suffix '.' used for variable 'lower_case_table_names' (value '0.0')Правильно, допустимые значения 0, 1 или 2. Поправьте конфиги и перезапустите настройку. ... |
| 03.07.2018, 15:29 |
)) Ура, решение.... Но как это сделать, подскажите, пожалуйста!!!!!!!!!!!!!!!!!!!!!!!!!!!! ... |
| 03.07.2018, 15:31 |
Что "как сделать"? как открыть текстовый файл, найти в нём строку и откорректировать её? ну блин ваще... ... |
| 03.07.2018, 15:40 |
А как он называется и где он находится, если подскажете, то не настолько все и "вообще"... ... |
| 03.07.2018, 15:42 |
где эти конфиги... смотрю в конфиги - вижу фиги... ... |
| 03.07.2018, 15:47 |
Кто-нибудь может не прокламировать, а помочь на этом форуме... ... |
| 03.07.2018, 15:56 |
anton6где эти конфиги https://dev.mysql.com/doc/refman/8.0/en/windows-installation-layout.html Так что в C:\ProgramData\MySQL\MySQL Server 8.0\, my.ini называется... если иное не указано в строке запуска сервиса. ... |
| 03.07.2018, 16:05 |
Не знаю, открыл я my.ini решил найти lower_case - ничего не нашел... ... |
| 03.07.2018, 16:14 |
Вот где он ... |
| 03.07.2018, 16:15 |
anton6решил найти lower_case - ничего не нашел...Ты или тупой, или тролль. Строка номер 134. ... |
| 03.07.2018, 16:41 |
Начал переустанавливать Сначала было так ... |
| 03.07.2018, 17:20 |
Потом в самой папке ... |
| 03.07.2018, 17:21 |
Я зашел в этот ini... Нашел, где lower_case поменял на lower_case_table_names=1.0 ... |
| 03.07.2018, 17:25 |
Нажал Back в installer потом Next и Execute Получил ту же самую ошибку Зашел в ini Увидел, что там lower_case_table_names=0.0 И что с этим делать...? ... |
| 03.07.2018, 17:27 |
Причем пересохранялся, закрывал, открывал, проверял там = 1.0 После выполнения Execute - опять 0.0 ... |
| 03.07.2018, 17:29 |
start [/forum/topic.php?desktop=1&fid=47&tid=1829752]: |
198ms |
63ms |
| others: | 240ms |
| total: | 540ms |
