Создаётся большая нагрузка на сервере и сайтом дублируются запросы вида. mysql> show proc
КАК РЕШИТЬ ЭТУ ЗАДАЧУ????? Создаётся больная нагрузка на сервере и сайтом дублируются запросы вида. mysql> show processlist; +-----+---------+-----------+------+---------+------+----------------------+------------------------------------------------------------------------------------------------------+ | Id | User | Host | db | Command | Time | State | Info | +-----+---------+-----------+------+---------+------+----------------------+------------------------------------------------------------------------------------------------------+ | 12 | dizuser | localhost | diz | Query | 599 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 149 | dizuser | localhost | diz | Query | 395 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 150 | dizuser | localhost | diz | Query | 557 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 151 | dizuser | localhost | diz | Query | 358 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 172 | dizuser | localhost | diz | Query | 420 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 173 | dizuser | localhost | diz | Query | 90 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 180 | dizuser | localhost | diz | Query | 284 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | 183 | dizuser | localhost | diz | Query | 275 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 187 | dizuser | localhost | diz | Query | 245 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 190 | dizuser | localhost | diz | Query | 230 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 192 | dizuser | localhost | diz | Query | 224 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 193 | dizuser | localhost | diz | Query | 90 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 202 | dizuser | localhost | diz | Query | 77 | Copying to tmp table | SELECT p.*, u.nickname as author, u.login, u.is_deleted, | | 206 | dizuser | localhost | diz | Query | 31 | Copying to tmp table | SELECT c.*, IFNULL(u.nickname, 0) as nickname, IFNULL(u.login, 0) as login, | | 209 | root | localhost | NULL | Query | 0 | NULL | show processlist | +-----+---------+-----------+------+---------+------+----------------------+------------------------------------------------------------------------------------------------------+ 15 rows in set (0.00 sec) Как найти и убрать эти дублирующие запросы? ... |
| 22.01.2020, 22:01 |
А чё искать-то? начало запроса тебе показали - вполне достаточно для поиска. ... |
| 22.01.2020, 22:18 |
| 23.01.2020, 13:17 |
AlexProfit Как найти и убрать эти дублирующие запросы? ... |
| 23.01.2020, 20:54 |
start [/forum/topic.php?desktop=1&fid=47&tid=1828774]: |
27ms |
34ms |
| others: | 236ms |
| total: | 343ms |
