Проблема при подключении к БД
Коллеги добрый вечер! Нужно помощь имеется сервер Zabbix+MySQL\MariaDb база данных, после не понятного аварийного выключения сервера не стартует база данных ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (111 "Connection refused"). к сожалению резервных копий базы нет, есть ли возможность как то выйти из положения не потеряв базу. Log MySQL 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: innodb_empty_free_list_algorithm has been changed to $ 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Using mutexes to ref count buffer pool pages 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: The InnoDB memory heap is disabled 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memor$ 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Compressed tables use zlib 1.2.8 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Using Linux native AIO 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Using SSE crc32 instructions 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Initializing buffer pool, size = 128.0M 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Completed initialization of buffer pool 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Highest supported file format is Barracuda. 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Starting crash recovery from checkpoint LSN=477152925$ 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Restoring possible half-written data pages from the d$ InnoDB: 1 transaction(s) which must be rolled back or cleaned up InnoDB: in total 0 row operations to undo InnoDB: Trx id counter is 85571840 2020-04-18 6:30:02 140113915100544 [Note] InnoDB: Starting final batch to recover 487 pages from redo l$ 2020-04-18 06:30:02 7f6eb27fa700 InnoDB: Error: page 18372 log sequence number 47727719171 InnoDB: is in the future! Current system log sequence number 47715394842. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.6/en/forcing-innodb-recovery.html InnoDB: for more information. 2020-04-18 06:30:02 7f6eb3ffd700 InnoDB: Error: page 9007 log sequence number 47728116466 InnoDB: is in the future! Current system log sequence number 47715394842. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.6/en/forcing-innodb-recovery.html InnoDB: for more information. 2020-04-18 06:30:02 7f6eb2ffb700 InnoDB: Error: page 644 log sequence number 47715644975 InnoDB: is in the future! Current system log sequence number 47715394842. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.6/en/forcing-innodb-recovery.html InnoDB: for more information. 2020-04-18 06:30:02 7f6eb27fa700 InnoDB: Error: page 16385 log sequence number 47728607343 InnoDB: is in the future! Current system log sequence number 47715394842. InnoDB: Your database may be corrupt or you may have copied the InnoDB InnoDB: tablespace but not the InnoDB log files. See InnoDB: http://dev.mysql.com/doc/refman/5.6/en/forcing-innodb-recovery.html InnoDB: for more information. ... |
| 18.04.2020, 20:16 |
И сервер написал, где читать, и форум подсветил... выполнено? ... |
| 18.04.2020, 21:03 |
Да пытался сделать, но не получилось. ... |
| 18.04.2020, 21:20 |
05.ru пытался сделать 05.ru не получилось ... |
| 18.04.2020, 21:34 |
На подобие как в этой статье https://linux-notes.org/ispravlyaem-povrezhdenny-e-innodb-tablitsy/ ... |
| 18.04.2020, 21:59 |
БД запускается при значении innodb_force_recovery = 6 вот при создании дампа возникли проблемы и т.д. ... |
| 18.04.2020, 22:52 |
start [/forum/topic.php?desktop=1&fid=47&tid=1828626]: |
56ms |
27ms |
| others: | 243ms |
| total: | 359ms |
