Перестал запускаться сервер СУБД MySQL
В ОС ALT Linux перестал запускаться сервер СУБД MySQL 5.7.28. При попытке его перезапуска командой # /etc/init.d/mysqld restart выдаётся следующий результат: Sending TERM signal to mysqld: Service mysqld is not running.[93G[[1m[33mPASSED[39;49m[0;10m] Waiting for mysqld to actually shut down: [93G[ [1m[32mDONE[39;49m[0;10m ] Adjusting environment for mysqld: [93G[ [1m[32mDONE[39;49m[0;10m ] Starting mysqld service: 2020-07-13T09:03:48.388005Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details). 2020-07-13T09:03:48.388429Z 0 [Warning] Can't create test file /db/k-93-77-81-76.lower-test 2020-07-13T09:03:48.409559Z 0 [Note] mysqld (mysqld 5.7.28-alt1) starting as process 6189 ... 2020-07-13T09:03:48.683335Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them. 2020-07-13T09:03:48.683395Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory. 2020-07-13T09:03:48.684782Z 0 [Warning] CA certificate /db/ca.pem is self signed. 2020-07-13T09:03:48.684857Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory. 2020-07-13T09:03:48.685144Z 0 [Note] Server hostname (bind-address): '*'; port: 3306 2020-07-13T09:03:48.685232Z 0 [Note] IPv6 is available. 2020-07-13T09:03:48.685257Z 0 [Note] - '::' resolves to '::'; 2020-07-13T09:03:48.685427Z 0 [Note] Server socket created on IP: '::'. 2020-07-13T09:03:48.685539Z 0 [ERROR] Another process with pid 1326 is using unix socket file. 2020-07-13T09:03:48.685552Z 0 [ERROR] Unable to setup unix socket lock file. 2020-07-13T09:03:48.689395Z 0 [ERROR] Aborting 2020-07-13T09:03:48.689688Z 0 [Note] Binlog end Initialization of mysqld failed: 0 [93G[[1m[31mFAILED[39;49m[0;10m] Выполнение команды # systemctl status mysqld приводит к аналогичному результату: mysqld.service - MySQL database server Loaded: loaded (/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled) Drop-In: /etc/systemd/system/mysqld.service.d -- user.conf Active: failed (Result: exit-code) since Sun 2020-07-12 14:59:02 EEST; 1min 17s ago Process: 1305 ExecStart=/usr/sbin/mysqld -C $CHSET $OPT (code=exited, status=1/FAILURE) Process: 747 ExecStartPre=/etc/chroot.d/mysql.all (code=exited, status=0/SUCCESS) Process: 738 ExecStartPre=/bin/sh -c if [ ! -d /var/lib/mysql/db/mysql ]; then /usr/sbin/mysqld -C $CHSET --initialize-insecure --user=mysql; fi (code=exited, status=0/SUCCESS) Main PID: 1305 (code=exited, status=1/FAILURE) Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.091879Z 0 [Note] IPv6 is available. Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.091900Z 0 [Note] - '::' resolves to '::'; Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.092098Z 0 [Note] Server socket created on IP: '::'. Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.103944Z 0 [ERROR] Another process with pid 1326 is using unix socket file. Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.104000Z 0 [ERROR] Unable to setup unix socket lock file. Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.104058Z 0 [ERROR] Aborting Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.129962Z 0 [Note] Binlog end Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com mysqld[1305]: 2020-07-12T11:59:02.200663Z 0 [Note] /usr/sbin/mysqld: Shutdown complete Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com systemd[1]: mysqld.service: Main process exited, code=exited, status=1/FAILURE Jul 12 14:59:02 k-93-77-81-76.dynamic-FTTB.kharkov.provider.com systemd[1]: mysqld.service: Failed with result 'exit-code'. При этом команда # ps -aux показывает, что среди выполняющихся в системе процессов процесса с pid 1326 (содержимым файла mysql.sock.lock ) нет: USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND root 1 0.0 0.3 31168 7176 ? Ss 11:45 0:03 /sbin/init root 2 0.0 0.0 0 0 ? S 11:45 0:00 [kthreadd] root 3 0.0 0.0 0 0 ? S 11:45 0:01 [ksoftirqd/0] root 5 0.0 0.0 0 0 ? S< 11:45 0:00 [kworker/0:0H] root 7 0.1 0.0 0 0 ? S 11:45 0:07 [rcu_sched] root 8 0.0 0.0 0 0 ? S 11:45 0:00 [rcu_bh] root 9 0.0 0.0 0 0 ? S 11:45 0:00 [migration/0] root 10 0.0 0.0 0 0 ? S< 11:45 0:00 [lru-add-drain] root 11 0.0 0.0 0 0 ? S 11:45 0:00 [watchdog/0] root 12 0.0 0.0 0 0 ? S 11:45 0:00 [cpuhp/0] root 13 0.0 0.0 0 0 ? S 11:45 0:00 [kdevtmpfs] root 14 0.0 0.0 0 0 ? S< 11:45 0:00 [netns] root 15 0.0 0.0 0 0 ? S 11:45 0:00 [khungtaskd] root 16 0.0 0.0 0 0 ? S 11:45 0:00 [oom_reaper] root 17 0.0 0.0 0 0 ? S< 11:45 0:00 [writeback] root 18 0.0 0.0 0 0 ? S 11:45 0:00 [kcompactd0] root 19 0.0 0.0 0 0 ? S< 11:45 0:00 [crypto] root 21 0.0 0.0 0 0 ? S< 11:45 0:00 [kintegrityd] root 22 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 23 0.0 0.0 0 0 ? S< 11:45 0:00 [kblockd] root 24 0.0 0.0 0 0 ? S< 11:45 0:00 [md] root 25 0.0 0.0 0 0 ? S< 11:45 0:00 [devfreq_wq] root 26 0.0 0.0 0 0 ? S< 11:45 0:00 [watchdogd] root 27 0.0 0.0 0 0 ? S 11:45 0:00 [kswapd0] root 28 0.0 0.0 0 0 ? S< 11:45 0:00 [vmstat] root 38 0.0 0.0 0 0 ? S< 11:45 0:00 [kthrotld] root 40 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 41 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 42 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 43 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 44 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 45 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 46 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 47 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 48 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 49 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 50 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 51 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 52 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 53 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 54 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 55 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 56 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 57 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 58 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 59 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 60 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 61 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 62 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 63 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 65 0.0 0.0 0 0 ? S< 11:45 0:00 [charger_manager] root 120 0.0 0.0 0 0 ? S< 11:45 0:00 [ata_sff] root 121 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_0] root 122 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_0] root 123 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_1] root 124 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_1] root 125 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_2] root 127 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_2] root 131 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_3] root 136 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_3] root 138 0.0 0.0 0 0 ? S 11:45 0:00 [kworker/u8:2] root 139 0.0 0.0 0 0 ? S 11:45 0:00 [kworker/u8:3] root 141 0.0 0.0 0 0 ? S< 11:45 0:00 [ttm_swap] root 159 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 202 0.0 0.0 0 0 ? S 11:45 0:00 [jbd2/sda6-8] root 203 0.0 0.0 0 0 ? S< 11:45 0:00 [ext4-rsv-conver] root 227 0.0 0.0 0 0 ? S< 11:45 0:00 [ipv6_addrconf] root 240 0.0 0.0 0 0 ? S< 11:45 0:00 [kworker/0:1H] root 244 0.0 0.0 0 0 ? S 11:45 0:00 [kauditd] root 252 0.0 4.0 166584 81556 ? Ss 11:45 0:01 /lib/systemd/systemd-journald root 257 0.0 0.0 0 0 ? S< 11:45 0:00 [iprt-VBoxWQueue] root 280 0.0 0.2 19004 4332 ? Ss 11:45 0:01 /lib/systemd/systemd-udevd root 364 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_4] root 365 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_4] root 366 0.0 0.0 0 0 ? S 11:45 0:00 [scsi_eh_5] root 367 0.0 0.0 0 0 ? S< 11:45 0:00 [scsi_tmf_5] root 369 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 370 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 374 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 375 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 376 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 377 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 378 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 379 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 380 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 381 0.0 0.0 0 0 ? S< 11:45 0:00 [bioset] root 451 0.0 0.0 0 0 ? S 11:45 0:00 [jbd2/sda8-8] root 452 0.0 0.0 0 0 ? S< 11:45 0:00 [ext4-rsv-conver] root 473 0.0 0.0 0 0 ? S 11:45 0:00 [jbd2/sda2-8] root 474 0.0 0.0 0 0 ? S< 11:45 0:00 [ext4-rsv-conver] root 557 0.0 0.3 38948 6500 ? Ssl 11:45 0:00 /usr/libexec/accounts-daemon root 558 0.0 0.2 10656 5092 ? Ss 11:45 0:00 /lib/systemd/systemd-logind root 559 0.0 0.0 2004 1056 ? Ss 11:45 0:00 /usr/sbin/acpid -f -n root 560 0.0 0.3 21636 6196 ? Ssl 11:45 0:00 /usr/bin/guile18 -s /usr/sbin/alteratord message+ 562 0.0 0.2 7004 4112 ? Ss 11:45 0:00 /bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation _avahi 564 0.0 0.1 6552 2988 ? Ss 11:45 0:00 avahi-daemon: running [k-93-77-81-76.local] root 565 0.0 0.3 50508 7944 ? Ssl 11:45 0:00 /usr/sbin/ModemManager root 567 0.0 0.3 49132 6984 ? Ssl 11:45 0:00 /usr/libexec/upower/upowerd _avahi 598 0.0 0.0 6552 316 ? S 11:45 0:00 avahi-daemon: chroot helper root 609 0.0 0.6 61808 13932 ? Ssl 11:45 0:00 /usr/sbin/NetworkManager --no-daemon polkitd 636 0.0 0.6 74952 12376 ? Ssl 11:45 0:00 /usr/libexec/polkit-1/polkitd --no-debug nobody 680 0.0 0.1 3712 2056 ? Ss 11:45 0:00 /usr/local/bin/noip2 root 732 0.0 0.2 10360 5448 ? Ss 11:45 0:00 /usr/sbin/cupsd -l root 742 0.0 0.2 44096 5704 ? SLsl 11:45 0:00 /usr/sbin/lightdm root 824 1.8 1.9 150016 39580 tty1 Ssl+ 11:45 1:17 X -nolisten tcp :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt1 -novtswitch firebird 830 0.0 0.0 6340 300 ? S 11:45 0:00 /opt/firebird/bin/fbguard -pidfile /var/run/firebird/firebird.pid -daemon -forever root 831 0.0 0.2 7808 4436 ? Ss 11:45 0:00 /usr/sbin/sshd -D firebird 845 0.0 0.2 60380 5520 ? Sl 11:45 0:00 /opt/firebird/bin/firebird colord 1046 0.0 0.8 49540 16568 ? Ssl 11:45 0:00 /usr/libexec/colord root 1262 0.0 0.3 14176 6264 ? Ss 11:45 0:00 /usr/sbin/httpd2 -k start vadik 1275 0.0 0.4 157872 9904 ? Sl 11:46 0:00 /usr/sbin/httpd2 -k start vadik 1276 0.0 0.5 238748 10300 ? Sl 11:46 0:00 /usr/sbin/httpd2 -k start vadik 1277 0.0 0.5 238752 10300 ? Sl 11:46 0:00 /usr/sbin/httpd2 -k start root 1306 0.0 0.2 24268 5052 ? S 11:46 0:00 /usr/sbin/nmbd --no-process-group root 1382 0.2 0.7 38684 14352 ? S 11:46 0:10 /usr/sbin/smbd --no-process-group root 1383 0.0 0.2 36408 4928 ? S 11:46 0:00 /usr/sbin/smbd --no-process-group root 1384 0.0 0.3 36860 6356 ? S 11:46 0:01 /usr/sbin/smbd --no-process-group root 1385 0.0 0.4 38680 8672 ? S 11:46 0:00 /usr/sbin/smbd --no-process-group root 1389 0.0 0.0 2312 1676 ? S 11:46 0:00 /sbin/dhcpcd -B -K -L -A -G -c /usr/lib/NetworkManager/nm-dhcp-helper -4 -h k-93-77-81-76 eth0 root 1397 0.0 0.0 0 0 ? S< 11:46 0:00 [cfg80211] root 1519 0.0 0.3 32184 7232 ? Sl 11:46 0:00 lightdm --session-child 12 19 vadik 1529 0.0 0.3 12168 6552 ? Ss 11:46 0:00 /lib/systemd/systemd --user vadik 1531 0.0 0.0 32160 1576 ? S 11:46 0:00 (sd-pam) vadik 1539 0.0 0.2 40312 5424 ? Sl 11:46 0:00 /usr/bin/gnome-keyring-daemon --daemonize --login vadik 1542 0.0 0.6 55120 13552 ? Ssl 11:46 0:00 /usr/bin/mate-session vadik 1586 0.0 0.0 4628 212 ? Ss 11:46 0:00 ssh-agent -u vadik 1601 0.0 0.2 6992 4072 ? Ss 11:46 0:00 /bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation vadik 1650 0.0 0.2 26012 4552 ? Sl 11:46 0:00 /usr/libexec/dconf-service vadik 1656 0.0 1.1 247164 23556 ? Sl 11:46 0:04 /usr/libexec/mate-settings-daemon vadik 1660 0.0 0.8 56020 17780 ? Sl 11:46 0:01 marco vadik 1664 0.0 1.3 305328 26728 ? Sl 11:46 0:01 mate-panel vadik 1668 0.0 0.2 39856 5248 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfsd vadik 1675 0.1 3.9 403372 77972 ? Sl 11:46 0:05 caja vadik 1680 0.0 0.4 232380 9456 ? Sl 11:46 0:00 /usr/bin/pulseaudio --start --log-target=syslog vadik 1681 0.0 1.2 44260 24924 ? Sl 11:46 0:01 /usr/bin/python3 /usr/share/system-config-printer/applet.py vadik 1684 0.0 0.7 56444 15432 ? Sl 11:46 0:00 mate-power-manager vadik 1686 0.0 0.6 55916 13816 ? Sl 11:46 0:00 mate-screensaver vadik 1688 0.1 1.1 74292 22948 ? Sl 11:46 0:07 python /usr/local/bin/daemon_wallpapoz vadik 1689 0.0 0.7 264648 15276 ? Sl 11:46 0:03 parcellite vadik 1694 0.0 0.6 51136 13724 ? Sl 11:46 0:00 /usr/libexec/polkit-mate-authentication-agent-1 vadik 1698 0.0 1.8 368140 37556 ? Sl 11:46 0:00 nm-applet vadik 1706 0.0 2.0 278968 41628 ? Sl 11:46 0:00 krb5-ticket-watcher -i 31 vadik 1707 0.0 1.0 403460 20892 ? Sl 11:46 0:00 mate-volume-control-applet vadik 1708 0.0 0.2 44104 5384 ? Ssl 11:46 0:00 /usr/libexec/at-spi-bus-launcher vadik 1713 0.0 0.1 6484 3076 ? S 11:46 0:00 /bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --print-address 3 vadik 1717 0.0 0.2 30272 5496 ? Sl 11:46 0:00 /usr/libexec/at-spi2-registryd --use-gnome-session vadik 1718 0.0 1.9 277204 38800 ? Sl 11:46 0:00 apt-indicator --autostarted vadik 1728 0.0 0.4 44052 8116 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfs-udisks2-volume-monitor root 1733 0.0 0.3 54980 7828 ? Ssl 11:46 0:01 /usr/libexec/udisks2/udisksd vadik 1743 0.0 0.2 48488 5748 ? Sl 11:46 0:00 /usr/libexec/gvfs/gvfsd-trash --spawner :1.10 /org/gtk/gvfs/exec_spaw/0 vadik 1759 0.0 0.1 36116 3476 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfs-mtp-volume-monitor vadik 1763 0.0 0.2 48072 4712 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfs-afc-volume-monitor vadik 1770 0.0 0.2 36220 4936 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfs-goa-volume-monitor vadik 1774 0.0 1.1 193500 23384 ? Sl 11:46 0:00 /usr/libexec/goa-daemon vadik 1836 0.0 0.1 48816 3868 ? Sl 11:46 0:00 /usr/libexec/goa-identity-service vadik 1848 0.0 0.1 37340 3780 ? Ssl 11:46 0:00 /usr/libexec/gvfs/gvfs-gphoto2-volume-monitor vadik 1854 0.0 1.0 283256 20340 ? Sl 11:46 0:02 /usr/libexec/mate-panel/wnck-applet vadik 1856 0.0 1.0 290852 20520 ? Sl 11:46 0:00 /usr/libexec/mate-panel/clock-applet vadik 1858 0.0 0.7 272200 14552 ? Sl 11:46 0:00 /usr/libexec/mate-panel/notification-area-applet root 1888 0.0 0.1 7216 3856 tty2 Ss 11:46 0:00 /bin/login -p -- root root 1912 0.0 0.3 12168 6392 ? Ss 11:47 0:00 /lib/systemd/systemd --user root 1914 0.0 0.0 32140 1568 ? S 11:47 0:00 (sd-pam) root 1920 0.0 0.1 5124 3284 tty2 S 11:47 0:00 -bash root 2977 0.1 0.0 0 0 ? S 11:50 0:08 [kworker/0:1] root 4855 0.0 0.1 7216 3952 tty3 Ss 12:01 0:00 /bin/login -p -- root root 4874 0.0 0.2 5124 4064 tty3 S 12:01 0:00 -bash vadik 6221 0.0 0.1 27796 3604 ? Ssl 12:03 0:00 /usr/libexec/gvfs/gvfsd-metadata vadik 6242 0.0 1.5 294580 31628 ? Sl 12:04 0:01 pluma /home/vadik/mysql-rest1.txt root 8178 0.1 0.0 0 0 ? S 12:16 0:04 [kworker/0:0] root 8202 0.0 0.2 7692 4620 tty2 S+ 12:16 0:00 /usr/bin/mc -r -P /tmp/.private/root/mc-root/mc.pwd.kuBt4drxnB root 8203 0.0 0.0 1964 288 ? Ss 12:16 0:00 cons.saver /dev/tty2 root 8204 0.0 0.1 5188 3224 pts/0 Ss+ 12:16 0:00 bash -rcfile .bashrc vadik 8749 0.0 0.2 10716 5040 ? S 12:18 0:00 /usr/libexec/gconfd-2 root 15504 0.0 0.0 0 0 ? S 12:51 0:00 [kworker/0:2] root 17392 0.0 0.1 7808 3948 ? Ss 12:56 0:00 sshd: [accepted] root 17589 0.0 0.0 0 0 ? S 12:56 0:00 [kworker/0:3] root 17603 0.0 0.1 7808 3860 ? Ss 12:56 0:00 sshd: [accepted] root 17675 0.0 0.0 3124 1732 tty3 R+ 12:57 0:00 ps -aux В связи с этим буду признателен за любой совет по выходу из сложившейся ситуации. ... |
| 13.07.2020, 14:22 |
Оказывается, удаление файла mysql.sock.lock на время возобновляет запуск сервера СУБД MySQL. ... |
| 14.07.2020, 11:41 |
vadval15 При этом команда # ps -aux показывает, что среди выполняющихся в системе процессов процесса с pid 1326 (содержимым файла mysql.sock.lock ) нет: Есть смысл посмотреть лог ошибок мускуля и системный лог, чтобы отследить, что происходило с этим процессом. Возможно, он был жестоко убит ядром ОС по какой-то причине. ... |
| 14.07.2020, 11:55 |
Спасибо за ответ. Скорее всего, указанный файл при корректном выходе из системы должен удаляться автоматически, но почему-то этого не происходит. Поэтому придётся или восстанавливать процесс завершения работы сервера, или удалять его принудительно. ... |
| 15.07.2020, 10:31 |
Ну да, должен. Только не при выходе из системы, а при завершении работы mysqld. А не удаляется именно при корректном завершении? Т.е. в логах штатная остановка, процесса нет, а файл остался? ... |
| 15.07.2020, 11:08 |
start [/forum/topic.php?desktop=1&fid=47&tid=1828465]: |
44ms |
37ms |
| others: | 247ms |
| total: | 370ms |
