powered by simpleCommunicator - 2.0.50     © 2025 Programmizd 02
Форумы / MySQL [игнор отключен] [закрыт для гостей] / Запрос долго отрабатывает
    #40100915
ddfgfg
Здравствуйте. Используем InnoDB (MySQL 5.7.25-28)
bvat.cnf
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
[mysqld]
    query_cache_type = 1
    query_cache_size = 128M
    query_cache_limit = 16M
    innodb_buffer_pool_size = 24576M
    max_connections = 245
    table_open_cache = 18432
    thread_cache_size = 512
    max_heap_table_size = 128M
    tmp_table_size = 128M
    key_buffer_size = 256M
    join_buffer_size = 32M
    sort_buffer_size = 32M
    bulk_insert_buffer_size = 2M
    myisam_sort_buffer_size = 32M
bx_replica.cnf
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
[mysqld]
 server-id = 1
 ## enable logging message
 log-error                       = /var/log/mysql/error.log
## enable slow requests logging
 slow-query-log-file             = /var/log/mysql/slow.log
 slow-query-log                  = 1
 long-query-time                 = 3
 log-slow-slave-statements
## define binlog options for master server
 binlog_cache_size = 128K
 expire_logs_days  = 5
 max_binlog_size   = 100M
 binlog-format     = mixed
 log-bin           = mysql-bin
## enable this options for security, but it decrease performance
# innodb_flush_log_at_trx_commit = 1
sync_binlog = 3000
 relay-log            = relay-bin
 relay-log-index      = relay-bin.index
 relay-log-info-fil
my.cnf
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
[client]
port = 3306
socket = /var/lib/mysqld/mysqld.sock
default-character-set = utf8
[mysqld_safe]
nice = 0
[mysqld]
#skip-grant-tables
# Basic mysql server configuration
user = user
port = 3306
basedir = /usr
datadir = /var/lib/mysql
skip-external-locking
default-storage-engine = innodb
pid-file = /var/run/mysqld/mysqld.pid
transaction-isolation = READ-COMMITTED
max_allowed_packet = 16M
myisam-recover-options = BACKUP
explicit_defaults_for_timestamp = 1
sql_mode = ""
expire_logs_days = 1
# Cache parameters
query_cache_size = 512M
table_open_cache = 4096
thread_cache_size = 32
key_buffer_size = 1024M
thread_stack = 512M
join_buffer_size = 512M
sort_buffer_size = 512M
# Parameters for temporary tables
tmpdir = /tmp
max_heap_table_size     = 32M
tmp_table_size = 32M
# InnoDB parameters
innodb_file_per_table
innodb_buffer_pool_size = 1024M
innodb_flush_log_at_trx_commit = 2
innodb_log_file_size = 1024M
innodb_flush_method = O_DSYNC
innodb_strict_mode = OFF
# Database charset parameters
character-set-server = utf8
collation-server = utf8_unicode_ci
init-connect = "SET NAMES utf8 COLLATE utf8_unicode_ci"
skip-character-set-client-handshake
skip-name-resolve
[mysqldump]
quick
quote-names
[mysql]
[isamchk]
key_buffer = 16M
# Include additional settings
!includedir /etc/mysql/conf.d/
dbconn.php
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
ini_set("memory_limit", "4096M");
define("DBPersistent", false);
$DBType = "mysql";
$DBHost = "";
$DBLogin = "";
$DBPassword = "";
$DBName = "";
$DBDebug = true;
$DBDebugToFile = false;
define("DELAY_DB_CONNECT", true);
define("CACHED_b_file", 3600);
define("CACHED_b_file_bucket_size", 10);
define("CACHED_b_lang", 3600);
define("CACHED_b_option", 3600);
define("CACHED_b_lang_domain", 3600);
define("CACHED_b_site_template", 3600);
define("CACHED_b_event", 3600);
define("CACHED_b_agent", 3660);
define("CACHED_menu", 3600);
define("BX_COMP_MANAGED_CACHE", true);
define("BX_UTF", true);
define("BX_FILE_PERMISSIONS", 0644);
define("BX_DIR_PERMISSIONS", 0755);
umask(000);
@umask(~BX_DIR_PERMISSIONS);
define("BX_DISABLE_INDEX_PAGE", true);
// define("BX_CRONTAB_SUPPORT", true);
define("BC_IB_SETTINGS_ID", 15);
define("BC_IB_CITIES_ID", 17);
define("BC_IB_BRANDS_ID", 9);
define("BC_IB_OFFER_ID", 6);
define("BC_IB_PRODUCTS_ID", 5);
define("BC_IB_NEWS", 1);
define("RECAPTCHA_PUBLIC_KEY", '');
define("RECAPTCHA_SECRET_KEY", '2');
if(!(defined("CHK_EVENT") && CHK_EVENT===true))
define( "LOG_FILENAME", $_SERVER["DOCUMENT_ROOT"]."/log.txt");
//define("CACHED_b_search_tags", false);
define("SBRF_STATUS_NOT_PAYED", 0);
define("SBRF_STATUS_PAYED", 1);
define("SBRF_STATUS_DECLINED", 2);
define("BX_USE_MYSQLI", true);
Код: php
1.
2.
3.
4.
5.
6.
7.
8.
9.
SHOW GLOBAL STATUS LIKE 'Qcache%';
Qcache_free_blocks    1684
Qcache_free_memory    5784888
Qcache_hits    16292595
Qcache_inserts    6864173
Qcache_lowmem_prunes    1723639
Qcache_not_cached    1249544
Qcache_queries_in_cache    13601
Qcache_total_blocks    40869
Суть проблемы в том, что на некоторых страницах одни и те же запросы занимают разное время, например запрос
Код: plsql
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
SELECT DISTINCT BE.ID as ID,BE.IBLOCK_ID as IBLOCK_ID,BE.CODE as CODE,BE.XML_ID as XML_ID,BE.NAME as NAME,BE.ACTIVE as ACTIVE,IF(EXTRACT(Tov_SECOND
FROM
BE.ACTIVE_FROM)>0, DATE_FORMAT(BE.ACTIVE_FROM, '%d.%m.%Y %H:%i:%s'), DATE_FORMAT(BE.ACTIVE_FROM, '%d.%m.%Y')) as DATE_ACTIVE_FROM,IF(EXTRACT(Tov_SECOND
FROM
BE.ACTIVE_TO)>0, DATE_FORMAT(BE.ACTIVE_TO, '%d.%m.%Y %H:%i:%s'), DATE_FORMAT(BE.ACTIVE_TO, '%d.%m.%Y')) as DATE_ACTIVE_TO,BE.SORT as SORT,BE.PREVIEW_TEXT as PREVIEW_TEXT,BE.PREVIEW_TEXT_TYPE as PREVIEW_TEXT_TYPE,BE.DETAIL_TEXT as DETAIL_TEXT,BE.DETAIL_TEXT_TYPE as DETAIL_TEXT_TYPE,DATE_FORMAT(BE.DATE_CREATE, '%d.%m.%Y %H:%i:%s') as DATE_CREATE,BE.CREATED_BY as CREATED_BY,DATE_FORMAT(BE.TIMESTAMP_X, '%d.%m.%Y %H:%i:%s') as TIMESTAMP_X,BE.MODIFIED_BY as MODIFIED_BY,BE.TAGS as TAGS,BE.IBLOCK_SECTION_ID as IBLOCK_SECTION_ID,B.DETAIL_PAGE_URL as DETAIL_PAGE_URL,BE.DETAIL_PICTURE as DETAIL_PICTURE,BE.PREVIEW_PICTURE as PREVIEW_PICTURE,L.DIR as LANG_DIR, FPEN0.VALUE as PROPERTY_A_STATUSTOVARASPRAVOCHNIKNOMENKLATURAOBSHCHIE_VALUE, FPEN0.ID as PROPERTY_A_STATUSTOVARASPRAVOCHNIKNOMENKLATURAOBSHCHIE_ENUM_ID, FPV0.ID as PROPERTY_A_STATUSTOVARASPRAVOCHNIKNOMENKLATURAOBSHCHIE_VALUE_ID,BE.XML_ID as EXTERNAL_ID,B.IBLOCK_TYPE_ID as IBLOCK_TYPE_ID,B.CODE as IBLOCK_CODE,B.XML_ID as IBLOCK_EXTERNAL_ID,B.LID as LID , CAT_P2.ID as CATALOG_PRICE_ID_2, CAT_P2.CATALOG_GROUP_ID as CATALOG_GROUP_ID_2, CAT_P2.PRICE as CATALOG_PRICE_2, CAT_P2.CURRENCY as CATALOG_CURRENCY_2, CAT_P2.QUANTITY_FROM as CATALOG_QUANTITY_FROM_2, CAT_P2.QUANTITY_TO as CATALOG_QUANTITY_TO_2, 'Цена' as CATALOG_GROUP_NAME_2, 'Y' as CATALOG_CAN_ACCESS_2, 'Y' as CATALOG_CAN_BUY_2, CAT_P2.EXTRA_ID as CATALOG_EXTRA_ID_2, CAT_PR.QUANTITY as CATALOG_QUANTITY, CAT_PR.QUANTITY_RESERVED as CATALOG_QUANTITY_RESERVED, IF (CAT_PR.QUANTITY_TRACE = 'D', 'Y', CAT_PR.QUANTITY_TRACE) as CATALOG_QUANTITY_TRACE, CAT_PR.QUANTITY_TRACE as CATALOG_QUANTITY_TRACE_ORIG, IF (CAT_PR.CAN_BUY_ZERO = 'D', 'Y', CAT_PR.CAN_BUY_ZERO) as CATALOG_CAN_BUY_ZERO, CAT_PR.CAN_BUY_ZERO as CATALOG_CAN_BUY_ZERO_ORIG, IF (CAT_PR.NEGATIVE_AMOUNT_TRACE = 'D', 'Y', CAT_PR.NEGATIVE_AMOUNT_TRACE) as CATALOG_NEGATIVE_AMOUNT_TRACE, CAT_PR.NEGATIVE_AMOUNT_TRACE as CATALOG_NEGATIVE_AMOUNT_ORIG, IF (CAT_PR.SUBSCRIBE = 'D', 'Y', CAT_PR.SUBSCRIBE) as CATALOG_SUBSCRIBE, CAT_PR.SUBSCRIBE as CATALOG_SUBSCRIBE_ORIG, CAT_PR.AVAILABLE as CATALOG_AVAILABLE, CAT_PR.WEIGHT as CATALOG_WEIGHT, CAT_PR.WIDTH as CATALOG_WIDTH, CAT_PR.LENGTH as CATALOG_LENGTH, CAT_PR.HEIGHT as CATALOG_HEIGHT, CAT_PR.MEASURE as CATALOG_MEASURE, CAT_VAT.RATE as CATALOG_VAT, CAT_PR.VAT_ID as CATALOG_VAT_ID, CAT_PR.VAT_INCLUDED as CATALOG_VAT_INCLUDED, CAT_PR.PRICE_TYPE as CATALOG_PRICE_TYPE, CAT_PR.RECUR_SCHEME_TYPE as CATALOG_RECUR_SCHEME_TYPE, CAT_PR.RECUR_SCHEME_LENGTH as CATALOG_RECUR_SCHEME_LENGTH, CAT_PR.TRIAL_PRICE_ID as CATALOG_TRIAL_PRICE_ID, CAT_PR.WITHOUT_ORDER as CATALOG_WITHOUT_ORDER, CAT_PR.SELECT_BEST_PRICE as CATALOG_SELECT_BEST_PRICE, CAT_PR.PURCHASING_PRICE as CATALOG_PURCHASING_PRICE, CAT_PR.PURCHASING_CURRENCY as CATALOG_PURCHASING_CURRENCY, CAT_PR.TYPE as CATALOG_TYPE, CAT_PR.BUNDLE as CATALOG_BUNDLE
FROM
b_iblock B
INNER JOIN b_lang L ON B.LID=L.LID
INNER JOIN b_iblock_element BE ON BE.IBLOCK_ID = B.ID
LEFT JOIN b_iblock_property FP0 ON FP0.IBLOCK_ID = B.ID AND FP0.CODE='A_STATUSTOVARASPRAVOCHNIKNOMENKLATURAOBSHCHIE'
INNER JOIN b_iblock_property FP1 ON FP1.IBLOCK_ID = B.ID AND FP1.CODE='MINIMUM_PRICE'
LEFT JOIN b_iblock_property FP2 ON FP2.IBLOCK_ID = B.ID AND FP2.CODE='SHOPS'
LEFT JOIN b_iblock_element_property FPV0 ON FPV0.IBLOCK_PROPERTY_ID = FP0.ID AND FPV0.IBLOCK_ELEMENT_ID = BE.ID
INNER JOIN b_iblock_element_property FPV1 ON FPV1.IBLOCK_PROPERTY_ID = FP1.ID AND FPV1.IBLOCK_ELEMENT_ID = BE.ID
LEFT JOIN b_iblock_element_property FPV2 ON FPV2.IBLOCK_PROPERTY_ID = FP2.ID AND FPV2.IBLOCK_ELEMENT_ID = BE.ID
LEFT JOIN b_iblock_property_enum FPEN0 ON FPEN0.PROPERTY_ID = FPV0.IBLOCK_PROPERTY_ID AND FPV0.VALUE_ENUM = FPEN0.ID
INNER JOIN ( SELECT DISTINCT BSE.IBLOCK_ELEMENT_ID
FROM
b_iblock_section_element BSE
INNER JOIN b_iblock_section BSubS ON BSE.IBLOCK_SECTION_ID = BSubS.ID
INNER JOIN b_iblock_section BS ON (BSubS.IBLOCK_ID=BS.IBLOCK_ID AND BSubS.LEFT_MARGIN>=BS.LEFT_MARGIN AND BSubS.RIGHT_MARGIN<=BS.RIGHT_MARGIN)
WHERE
((BS.ID IN (2177))) ) BES ON BES.IBLOCK_ELEMENT_ID = BE.ID
left join b_catalog_price CAT_P2 on (CAT_P2.PRODUCT_ID = BE.ID AND CAT_P2.CATALOG_GROUP_ID = 2) and ((CAT_P2.QUANTITY_FROM <= 1 OR CAT_P2.QUANTITY_FROM IS NULL) AND (CAT_P2.QUANTITY_TO >= 1 OR CAT_P2.QUANTITY_TO IS NULL))
left join b_catalog_product CAT_PR on (CAT_PR.ID = BE.ID)
left join b_catalog_iblock CAT_IB on ((CAT_PR.VAT_ID IS NULL OR CAT_PR.VAT_ID = 0) AND CAT_IB.IBLOCK_ID = BE.IBLOCK_ID)
left join b_catalog_vat CAT_VAT on (CAT_VAT.ID = IF((CAT_PR.VAT_ID IS NULL OR CAT_PR.VAT_ID = 0), CAT_IB.VAT_ID, CAT_PR.VAT_ID))
WHERE
1=1 AND ( (((BE.DETAIL_PICTURE IS NOT NULL))) AND ((((BE.IBLOCK_ID = '5')))) AND (EXISTS ( SELECT IBLOCK_ID
FROM
b_iblock_site
WHERE
IBLOCK_ID = B.ID AND (((SITE_ID='s1'))) )) AND ((((B.ACTIVE='Y')))) AND (((BE.ACTIVE_TO >= now() OR BE.ACTIVE_TO IS NULL) AND (BE.ACTIVE_FROM <= now() OR BE.ACTIVE_FROM IS NULL))) AND ((((BE.ACTIVE='Y')))) AND ( 1=1 ) AND ((( FPEN0.VALUE IS NULL OR NOT (FPEN0.VALUE LIKE 'Не выгружать')))) AND (((FPV1.VALUE_NUM IS NOT NULL))) AND (((NOT(FPV2.VALUE IS NULL OR length(FPV2.VALUE)<=0)))) AND ((((FPV1.VALUE_NUM > '0')))) ) AND (((BE.WF_STATUS_ID=1 AND BE.WF_PARENT_ELEMENT_ID IS NULL)))
ORDER BY
FPEN0.VALUE asc ,BE.SORT asc ,BE.NAME asc
LIMIT 0, 24
на некоторых страницах отрабатывает за 0,003 сек, а на некоторых за 2 сек, а то и за 5 сек. И как результат где-то время загрузки страницы 0,5 сек, а где-то 6 сек. Вопрос простой, можно ли оптимизировать и если да, то как mysql (не на уровне запросов, а на уровне сервиса mysql), что бы сделать запросы быстрее? Да и собственно почему такая разница? Заранее спасибо за ответ.
    #40101082
AndrewS
ddfgfg,
вы можете получить план выполнения:
- для некоторых страниц, которые отрабатывают быстро
- для некоторых страниц, которые отрабатывают медленно?
Задача не выглядит, как решаемая на форуме, т.к. совершенно неясно распределение данных по таблицам, наличие индексов и куча всего разного.
Давайте начнем с execution plan
И как общий совет: постепенно упрощайте запрос, пока не локализуете участок, который показывает разную скорость на разных страницах
    #40101256
ddfgfg
AndrewS,
Это nexplain когда запрос отрабатывает быстро.
    #40101257
ddfgfg
AndrewS,
А это когда медленно
    #40101407
AndrewS
На первый взгляд особых проблем не видно в обоих планах.
