dsoDim.Update - ошибка?
Вот сэмпл-код из Books Online (раздел - Add Dimensions and Levels). Последняя строка, а именно "dsoDim.Update" дает ошибку "Object doesn't support property or method". Что делать? Кстати еще и Set dsoDim.DataSource = dsoDS дает ошибку типов... 'Create Product Dimension and Levels Set dsoDim = dsoDB.Dimensions.AddNew("Products") Set dsoDim.DataSource = dsoDS 'Dimension DataSource dsoDim.FromClause = "product" 'Related Table dsoDim.JoinClause = "" 'Used in snowflake schema 'Product Brand Level Set dsoLev = dsoDim.Levels.AddNew("Brand Name") dsoLev.MemberKeyColumn = """product"".""brand_name""" dsoLev.ColumnSize = 255 dsoLev.ColumnType = adWChar dsoLev.EstimatedSize = 1 'Product Name Level Set dsoLev = dsoDim.Levels.AddNew("Product Name") dsoLev.MemberKeyColumn = """product"".""product_name""" dsoLev.ColumnSize = 255 dsoLev.ColumnType = adWChar dsoLev.EstimatedSize = 1 'Update the dimension dsoDim.Update ... |
| 31.01.2001, 14:50:44 |
start [/forum/topic.php?desktop=1&fid=46&tid=1827418]: |
431ms |
51ms |
| others: | 201ms |
| total: | 733ms |
