Pomogite chainiky
Y menya v asp na MS Access bylo query, v kotorom tipa sortirovalis' rezyl'taty po printsipy , snachala te, v kotoryx textovoe pole sovpadaet c slovom poiska a potom vce ostal'nye vot ya eto delo perevel v MSSQL a tam takoi fint ne proxodit Please pomogite. V Access rabotalo tak Select ... Where ... Order by ... , ' ' & [some_textfield] = ' slovo' desc i tipa vce rabotalo , dazhe esli some_textfield is null a v MS SQL rygaetsya , zamenyal = na Like - nifiga ne pomoglo ;( chego delat' ? P.S. ya konechno mogy na Union ALL zamenit' tipa Select ... where .. and [some_textfield] = 'slovo' union all select .. where .. and [some_textfield] <> 'slovo' no eto zhytko medlenno t.k. togda mne nado 8 union All t.k. v Order by eche odin parameter. ;( P.P.S. v krainem slychae priidetsya sortirovat' po abs([Code_of_Test_Field] - code_Slova) Asc no eto kraine nezhelatel'no. Vsem bol'shoe Cpasibo DRY_GIN ... |
| 06.03.2001, 09:51:39 |
Pomogite chainiky
Ну это же просто ... order by case when [some_textfield] = ' slovo' then 0 else 1 end, ... ... |
| 06.03.2001, 11:23:05 |
start [/forum/topic.php?desktop=1&fid=46&tid=1827255]: |
155ms |
26ms |
| others: | 198ms |
| total: | 413ms |
