Chainiki v bou - 2
Tyt nakopilos' za noch' eche para gemmoroev - speshy podelitstya: vo pervyx , skazhy srazy, chto server y hostinga, a y menya prava dostypa tol'ko na mou database. tak vot, kogda ya stal kachat' svou glavnyu (t.e. samyu bol'shyu tablitsy) iz MS Access v SQL to cherez pol chasa t.e. kogda vce perekachalos' - to mne vidali soobshenie: 'camps' table - Unable to modify table. ODBC error: [Microsoft][ODBC SQL Server Driver][SQL Server]The log file for database 'camps' is full. Back up the transaction log for the database to free up some log space. pri etom account mne sozdali tol'ko vchera, i nikakogo loga tam byt' ne dolzhno. ta-zhe oshibka voznikla iz-pod SQL server Enterpr. Manager. koroche ya cmog skachat' tol'ko razbiv svou tablitsy na tri files , sozdav tri sql tablitsy i potom ob'edenil ix v odny, ( po idee transaction log dolzhen-to byt' eche bol'she ot etogo) Nikakix optsyi po steraniu ili disable transaction log ya ne nashel, a mozhet oni mne ne dostypny. edinstvennoe chto ya nashel eto "truncate Log" - neznau yzh tozhe eto samoe ili net no ono ne pomoglo. vo vtoryx - Identity field - pochemy-to samo iz Autonumbera ne polychaetsta. i update ya ego tozhe ne mogy - iz za etogo gemmora s log file for database 'camps' is full. ya pytalsya cherez SQL Query Analyzer sdelat' chto-to tipa Alter table camps alter column [ID] [int] not Null Identity (1,1) on vce vremya govorit Error near IDentity tazhe oshibka na Alter table camps Add column [ID2] [int] not Null Identity (1,1) polychaetsya opyat' nado razbit' table na kyski , v pervom kyske sdelat' ID Identity i potom ostal'nye insert into ? samoe obidnoe MS Access database zanimala 12 MB a Database Usage na SQL Yzhe 33 mb (pochemy?) ( a package my kypili na 35 mb) eto polychaetsya s ytra users nachnyt ee uzat' i vce ryxnet ;( po etomy please - skazhite - kak mozhno sdelat' chto-to tipa " database compact & repare" s ne "su" pravami i kak mozhno , esli mozhno , disable transaction log. i poslednee, vot eto perestalo rabotat': For each f in rst.Fields if CBool(f.Attributes And adFldUpdatable) then znachit eto normal'noe pole else identity i prochee, t.e. izmenyat' ego nel'zya. end if kakoi bit ( esli on est') v SQL yavlyaetsya ekvivalentom Const adFldUpdatable = &H00000004 ??? Spasibo Bcem DRY_GIN P.S. Tem y kogo xvatilo sil dochitat' do kontsa: ya popytaus' tipa tolknyt' mysl' : Ochen' mnogie SQL programmery zabyvaut pro ' symbol kogda delaut raznye search tipa Select companyname, phonenumber from copmanyes where company like '%slovo_kotoroe_prishlo_iz_web_formy%' eto ochen' opasno t.k. luboi chelovek mozhet vmecto ozhidaemogo "cool company " v slovo_kotoroe_prishlo_iz_web_formy napisat' chto-to podobnoe: a' or 1=1) Union All select Table_Name as companyname chto-nit'_eche as phonenumber from table_schema where 'a'='a vobshem ya syntax ne pomnu - no ideya ponyatna. koroche nado vcegda, po krainei mere picat' chto-to tipa like '%replace(slovo_kotoroe_prishlo_iz_web_formy,"'","''")%' togda vce bydet nishtyak Ydachi ... |
| 06.03.2001, 16:00:53 |
Chainiki v bou - 2
1. Ищи галку типа "Truncate log on checkpoint". Но если идет перекачка, лог должен быть достаточного размера, что бы он не успел вырасти до максимума между чекпоинтами. 2. Я думаю сразу перекачать таблицы из аксеса и тут же с ними работать не получиться. Так не бывает. Радуйся что оно вообще перекачивается. Пусть перекачается как получиться, а создашь таблицы с типами которые нужно и перепишешь уже в них. А вообще - ты или русский учи или поменьше пиши - ну уж больно читать тяжело. ... |
| 06.03.2001, 16:55:52 |
start [/forum/topic.php?desktop=1&fid=46&tid=1827249]: |
175ms |
36ms |
| others: | 231ms |
| total: | 484ms |
