POMOGITE S WHILE
I NEED TO USE WHILE EXACLY AS MANY TIMES AS IT IS NEEDEt. I MEEN I CAN SET while @z < 3 but if It is nesessary to do loop more than it will be a problem If i will set the loop to do 20 circles than it will be a problem because of memory... SO I NEED TO DESCRIBE WHILE TO DO EXACT NUMBER OF LOOPS AS IT IS NEEDEt. declare @z int set @z = 0 while @z < 3 // Zdes' Pomosh nuzhna BEgin UPDATE UMB_PERSON_ADDRESS SET Expired = 1 FROM UMB_PERSON_ADDRESS JOIN ( SELECT Person_id FROM UMB_PERSON_ADDRESS WHERE IS_MAILING_ADDRESS = 1 AND EXPIRED = 0 GROUP BY (PERSON_ID) HAVING COUNT(*) > 1 ) AS A ON UMB_PERSON_ADDRESS.PERSON_ID = A.PERSON_ID JOIN ( SELECT PERS_ADDRESS_ID = MIN (PERS_ADDRESS_ID) FROM UMB_PERSON_ADDRESS WHERE IS_MAILING_ADDRESS = 1 AND EXPIRED = 0 GROUP BY (PERSON_ID) HAVING COUNT(*) > 1 ) AS B ON UMB_PERSON_ADDRESS.PERS_ADDRESS_ID = B.PERS_ADDRESS_ID set @z = @z +1 end ... |
| 15.06.2001, 00:45:44 |
start [/forum/topic.php?desktop=1&fid=46&tid=1826491]: |
245ms |
42ms |
| others: | 192ms |
| total: | 531ms |
