про генерацию скрипта и записи на диск. Может кому-то понадобится
CREATE PROCEDURE GenerateSQLScript AS ------ складывает скрипты DECLARE @SPName VARCHAR(255), @PString VARCHAR(4000), @Ptr BINARY(16), @Return VARCHAR(2), @D_Day VARCHAR(5), @D_Month VARCHAR(5), @D_Year VARCHAR(5), @Query VARCHAR (255) SET @D_Day = CONVERT(VARCHAR(5),DATEPART(day,GETDATE())) SET @D_Month = CONVERT(VARCHAR(5),DATEPART(Month,GETDATE())) SET @D_Year = CONVERT(VARCHAR(5),DATEPART(Year,GETDATE())) SET @D_Day = @D_Day + '00' SET @D_Month = @D_Month + '00' SET @D_Day = SUBSTRING(@D_Day,1,2) SET @D_Month = SUBSTRING(@D_Month,1,2) SET @D_Day = REVERSE(@D_Day) SET @D_Month = REVERSE(@D_Month) SET @Query = 'SPADAM_' + @D_Year + '_' + @D_Month + '_' + @D_Day + '.sql' SET @Return = '' --CHAR(13)+CHAR(10) IF OBJECT_ID('SP_Script') IS NULL CREATE TABLE SP_Script (IDRow INT IDENTITY PRIMARY KEY CLUSTERED, _Text VARCHAR(512)) DELETE FROM SP_Script DECLARE Run CURSOR FOR SELECT [NAME] FROM sysobjects WHERE type = 'p' ORDER BY [NAME] OPEN Run FETCH NEXT FROM Run INTO @SPName WHILE @@FETCH_STATUS = 0 BEGIN INSERT INTO SP_Script (_Text) VALUES ('SET QUOTED_IDENTIFIER OFF SET ANSI_NULLS ON '+@Return ) INSERT INTO SP_Script (_Text) VALUES ('GO' + @Return ) INSERT INTO SP_Script (_Text) VALUES ('SET QUOTED_IDENTIFIER OFF SET ANSI_NULLS ON '+ @Return ) INSERT INTO SP_Script (_Text) VALUES ('GO' + @Return ) INSERT INTO SP_Script (_Text) VALUES ('DROP PROCEDURE '+@SPName + @Return ) INSERT INTO SP_Script (_Text) VALUES ('GO' + @Return ) INSERT INTO SP_Script EXEC sp_helptext @SPName INSERT INTO SP_Script (_Text) VALUES ('GO') FETCH NEXT FROM Run INTO @SPName END CLOSE Run DEALLOCATE Run UPDATE SP_Script SET _Text = REPLACE (_Text,CHAR(10),'') UPDATE SP_Script SET _Text = REPLACE (_Text,CHAR(13),'') SET @Query = 'bcp.exe "SELECT _Text FROM Valter.dbo.SP_Script ORDER BY IDRow" queryout \forix\personals\BillGates\' + @Query SET @Query = @Query + ' -SBillGates -Usa -Pdirtynigger -n -c' EXEC master..xp_cmdshell @Query, no_output DROP TABLE SP_Script вызывается из робота. ... |
| 11.07.2001, 13:10 |
Спасибо, Алексей! Скоро, уже совсем скоро, у нас на сайте появится раздел, в который каждый желающий сможет добавить свой скрипт, представив его, таким образом, не всеобщее обозрение и получив возможность прочитать по нему отзывы. Приглашаем Вас размещать примеры своего кода в этом новом разделе. ... |
| 11.07.2001, 14:58 |
start [/forum/topic.php?desktop=1&fid=46&tid=1826221]: |
198ms |
27ms |
| others: | 217ms |
| total: | 478ms |
