SQL200+XML
Good day! Sorry to trouble you. Excuse me for my bad English . I test XML support for SQL Server 2000. I have already done some routine: 1. I make virtual directories: - SQL2000 is type dbobject - Templates is type template. 2. Allow Settings: - URL Queries (yes) - Template Queryes (yes) - XPath (yes) 3. I run query: http://localhost/SQL2000/SQL2000?sql=select+*+from+MyTable+FOR+XML+AUTO&root=ROOT 4. All OK!! 5. I have written SQL template and saved him to the file (List1.xml) 6. I moved this file in folder "Templates" 7. I run query: http://localhost/SQL2000/Templates/List1.xml I get error 500 in Internet Explorer Browser. Content file List1.xml: <ROOT xmlns:sql="urn:schemas-microsoft-com:xml-sql"> <sql:query> SELECT * FROM sysobjects FOR XML AUTO </sql:query> </ROOT> Best Regards, Alexander Verezhynsky P.S. My configuration: Windows 2000 enterprice edition. MS SQLServer 2000. Send request to Email: alex@asuaes.mk.ua for me,please! ... |
| 26.07.2001, 13:43 |
SQL200+XML
I am not sure, but try insert in your .xml file <? xml version = '1.0' ?> as first line. ... |
| 26.07.2001, 14:45 |
SQL200+XML
Adding information: I installing MS XML 3.0 (Replace MS XML 2.6 is default installing with Windows 2000). My configuration: Windows 2000 enterprice edition. MS SQLServer 2000. Send request to Email: alex@asuaes.mk.ua for me,please! ... |
| 27.07.2001, 08:37 |
start [/forum/topic.php?desktop=1&fid=46&tid=1826061]: |
46ms |
28ms |
| others: | 246ms |
| total: | 363ms |
