Добавление 2-х constraints
Мне нужно добавить 2 CONSTRAINT-a на таблицу. Если делаю так ALTER TABLE [dbo].[tCustomers] WITH NOCHECK ADD CONSTRAINT [CK_tCustomers] CHECK (([cManagedAccount] = 'S' or [cManagedAccount] = 'Y') and [cParent] is null or [cManagedAccount] = 'N') GO ALTER TABLE [dbo].[tCustomers] WITH NOCHECK ADD CONSTRAINT [PK_tCustomers] PRIMARY KEY CLUSTERED ( [cCustCode] ) ON [PRIMARY] GO То все работает, а если так: ALTER TABLE [dbo].[tCustomers] WITH NOCHECK ADD CONSTRAINT [PK_tCustomers] PRIMARY KEY CLUSTERED ( [cCustCode] ) ON [PRIMARY], CONSTRAINT [CK_tCustomers] CHECK (([cManagedAccount] = 'S' or [cManagedAccount] = 'Y') and [cParent] is null or [cManagedAccount] = 'N') GO Получаю ошибки (это не опечатка, их действительно 4): Server: Msg 433, Level 16, State 1, Line 1 Could not find CHECK constraint for 'dbo.tCustomers', although the table is flagged as having one. Server: Msg 433, Level 16, State 1, Line 1 Could not find CHECK constraint for 'dbo.tCustomers', although the table is flagged as having one. Server: Msg 433, Level 16, State 1, Line 1 Could not find CHECK constraint for 'dbo.tCustomers', although the table is flagged as having one. Server: Msg 433, Level 16, State 1, Line 1 Could not find CHECK constraint for 'dbo.tCustomers', although the table is flagged as having one. Поскольку код для добавления CONSTRAINT создал Enterprice Manager а таких таблиц больше 20-ти, и исполнять подобный скрипт нужно регулярно, то каждый Alter разбивать на 2 будет затруднительно ... |
| 11.09.2001, 11:42 |
start [/forum/topic.php?desktop=1&fid=46&tid=1825587]: |
137ms |
| others: | 216ms |
| total: | 418ms |
