Помогите найти утилиту, которая из SQL Server 7.0 возвращает XML
Помогите найти утилиту для SQL Server 7.0, которая результаты селекта будет возвращать не в виде рекордсета, а в XML-формате... ... |
| 17.10.2001, 11:19 |
А она у тебя под рукой. Метод Save у объекта ADODB.Recordset ... |
| 17.10.2001, 13:08 |
Можно еще использовать SQLXML 2.0 (XML for SQL Server 2000) Microsoft® SQL Server 2000 introduced several new features for querying database tables and receiving the results as an XML document. Web release 1 of SQLXML (XML for SQL Server) added Updategrams and XML Bulk Load functionality, as well as a host of other features to the SQL Server 2000 base. Continuing the Web Release strategy, SQLXML 2.0 adds support for XSD mapping schemas, Client-Side XML functionality, a new SQLXML OLEDB provider, a tool to convert XDR mapping schemas to XSD, and significant performance improvements. SQL Server 2000 users can use client-side XML functionality to move XML processing to the middle tier for better scalability or to wrap SQL Server Stored Procedures with the Transact-SQL FOR XML clause. SQLXML 2.0 also introduces a set of SQLXML Managed Classes that allows .NET developers to access SQLXML functionality. Client-side XML functionality - по описанию должна работать с MS SQL 7.0 ... |
| 18.10.2001, 07:45 |
start [/forum/topic.php?desktop=1&fid=46&tid=1825282]: |
168ms |
44ms |
| others: | 242ms |
| total: | 504ms |
