connect to remote SQL server from asp code
Kak podkluchit`sya k ydallenomy SQL servery iz asp coda, t.e. asp code i sql server nahodyatsya na raznux computerah : est` web server local i sql server v internet so svoim ip addresom ... |
| 11.10.2001, 08:54 |
В YourADOConnection.ConnectionString надо поставить Data Source=<Your SQL Server IP address> Вроде так должно работать. ... |
| 19.10.2001, 07:00 |
start [/forum/topic.php?desktop=1&fid=46&tid=1825270]: |
147ms |
41ms |
| others: | 204ms |
| total: | 433ms |
