Is it true that Stored Pocedures are slower ?
Testiruju performance stored procedure po sravneniju s parametrizirovannym query i prostym RS.Open SQLString Pluchaetsja peredacha SQL zaprosa v vide stroki bez parametrov v metod RS.Open - samyj bystryj metod. Privozhu resul'taty testa i nizhe samu proceduru testa. Mozhet kto to posovetuet kak dobit'sja ot stored procedures ili query s parametrami povyshennoj proizvoditel'nosti .. kak eto zajavljaetsja vo vseh uchebnikah. Test Result (in sec): 200 Cycles Loop : NOT Prepared Command W/O Parameters : 1.66406300 Prepared Command W/O Parameters : 1.92968800 NOT Prepared Stored Procedure Command WITH Parameters : 1.96875000 NOT Prepared Command WITH Parameters : 0.90625000 Prepared Command with WITH Parameters: 1.52343800 Recordset.Open : 0.56250000 VB code : ' Dim gConn AS ADODB.Connection inicializiruetsja v drugom module Public Sub SQLTest(Index As Integer) Dim Rs0 As ADODB.Recordset Dim Param1 As ADODB.Parameter Dim Param2 As ADODB.Parameter Dim Param3 As ADODB.Parameter Dim Rs As ADODB.Recordset Dim SqlStr As String Dim ParamSqlStr As String Dim ConnStr As String Dim MeasureParam As Long Dim TimeParam As Long Dim StudyParam As Long Dim MaxLoop As Long Dim i As Long Dim StartTime As Single Dim StopTime As Single Set Rs = New ADODB.Recordset Set Param1 = New ADODB.Parameter Set Param2 = New ADODB.Parameter Set Param3 = New ADODB.Parameter MaxLoop = 199 '299 InitConnectionCommand Index MeasureParam = Int((3 * Rnd) + 1) TimeParam = Int((3 * Rnd) + 1) StudyParam = Int((3 * Rnd) + 1) sc.Response.Write MaxLoop + 1 & " Cycles Loop : <BR>" SqlStr = "SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=" & StudyParam & ") AND ((TimePeriodLst.TPID)=" & TimeParam & ") AND ((Measure.MeasureID)=" & MeasureParam & "));" gComm.CommandType = adCmdText gComm.CommandText = SqlStr gComm.Prepared = False StartTime = Timer For i = 0 To MaxLoop MeasureParam = Int((3 * Rnd) + 1) TimeParam = Int((3 * Rnd) + 1) StudyParam = Int((3 * Rnd) + 1) SqlStr = "SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=" & StudyParam & ") AND ((TimePeriodLst.TPID)=" & TimeParam & ") AND ((Measure.MeasureID)=" & MeasureParam & "));" gComm.CommandText = SqlStr Set Rs = gComm.Execute Next StopTime = Timer PrintElapsedTime "NOT Prepared Command W/O Parameters : ", StartTime, StopTime gComm.Prepared = True StartTime = Timer For i = 0 To MaxLoop MeasureParam = Int((3 * Rnd) + 1) TimeParam = Int((3 * Rnd) + 1) StudyParam = Int((3 * Rnd) + 1) SqlStr = "SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=" & StudyParam & ") AND ((TimePeriodLst.TPID)=" & TimeParam & ") AND ((Measure.MeasureID)=" & MeasureParam & "));" gComm.CommandText = SqlStr Set Rs = gComm.Execute Next StopTime = Timer PrintElapsedTime "Prepared Command W/O Parameters : ", StartTime, StopTime ParamSqlStr = "pz_test" gComm.CommandType = adCmdStoredProc gComm.CommandText = ParamSqlStr gComm.Prepared = False Set Param1 = gComm.CreateParameter("@StudyID", adInteger, adParamInput, 4, 3) gComm.Parameters.Append Param1 Set Param2 = gComm.CreateParameter("@MeasureID", adInteger, adParamInput, 4, 3) gComm.Parameters.Append Param2 Set Param3 = gComm.CreateParameter("@TPID", adInteger, adParamInput, 4, 3) gComm.Parameters.Append Param3 StartTime = Timer For i = 0 To MaxLoop Param1.Value = Int((3 * Rnd) + 1) Param2.Value = Int((3 * Rnd) + 1) Param3.Value = Int((3 * Rnd) + 1) Set Rs = gComm.Execute Next StopTime = Timer PrintElapsedTime " NOT Prepared Stored Procedure Command WITH Parameters : ", StartTime, StopTime ParamSqlStr = "SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=?) AND ((TimePeriodLst.TPID)=?) AND ((Measure.MeasureID)=?));" gComm.CommandType = adCmdText gComm.CommandText = ParamSqlStr gComm.Prepared = False StartTime = Timer For i = 0 To MaxLoop Param1.Value = Int((3 * Rnd) + 1) Param2.Value = Int((3 * Rnd) + 1) Param3.Value = Int((3 * Rnd) + 1) Set Rs = gComm.Execute Next StopTime = Timer PrintElapsedTime " NOT Prepared Command WITH Parameters : ", StartTime, StopTime gComm.Prepared = True StartTime = Timer For i = 0 To MaxLoop Param1.Value = Int((3 * Rnd) + 1) Param2.Value = Int((3 * Rnd) + 1) Param3.Value = Int((3 * Rnd) + 1) Set Rs = gComm.Execute Next StopTime = Timer PrintElapsedTime "Prepared Command with WITH Parameters: ", StartTime, StopTime Rs.Close StartTime = Timer For i = 0 To MaxLoop MeasureParam = Int((3 * Rnd) + 1) TimeParam = Int((3 * Rnd) + 1) StudyParam = Int((3 * Rnd) + 1) SqlStr = "SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=" & StudyParam & ") AND ((TimePeriodLst.TPID)=" & TimeParam & ") AND ((Measure.MeasureID)=" & MeasureParam & "));" Rs.Open SqlStr, gConn Rs.Close Next StopTime = Timer PrintElapsedTime "Recordset.Open : ", StartTime, StopTime Set Rs = Nothing Set Param1 = Nothing Set Param2 = Nothing Set Param3 = Nothing End Sub Regards, Far Stringer ... |
| 17.11.2001, 03:25 |
Zabyl dobavit', ispol'zuju OLEDB provider dlja konnekta ConnStr = "Provider=SQLOLEDB.1;Persist Security Info=False;User ID=sa;Initial Catalog=TESTDB;Data Source=TESTSERVER" Mogu vyslat' ves' VB proekt esli est' zhelajushie pokopat'sja. Regards, Far Stringer ... |
| 17.11.2001, 03:31 |
Eshe dobavka .. text stored procedure create procedure dbo.pz_test @StudyID int, @TPID int, @MeasureID int as SELECT TResult.TResultID FROM (Study INNER JOIN TGroup ON Study.StudyID = TGroup.StudyID) INNER JOIN (Measure INNER JOIN (TResult INNER JOIN TimePeriodLst ON TResult.TPID = TimePeriodLst.TPID) ON Measure.MeasureID = TResult.MeasureID) ON TGroup.TGroupID = TResult.TGroupID WHERE (((Study.StudyID)=@StudyID) AND ((TimePeriodLst.TPID)=@TPID) AND ((Measure.MeasureID)=@MeasureID)) GO Regards, Far Stringer ... |
| 17.11.2001, 03:57 |
start [/forum/topic.php?desktop=1&fid=46&tid=1824956]: |
157ms |
| others: | 198ms |
| total: | 403ms |
