Как подставить в Select переменные
Hi! Do you know how to use SQL to make an 'indirection'. You remember in the C language, how you can treat the contents of a variable as a pointer to another variable location, or in other 4th generation languages (& some OS stuff), you can use a 'handle' to hold an indirect reference to another variable... I want to do something similar in SQL. I want a column in a table to hold a string that is a column name. I want to create an SQL statement that will use the value of that column name and perform a comparison. For example, there it a table: Table: T_Compare_Columns ( col_name char(50) ) Another table: Table: T_Datastuff ( name_ch char(20), county_ch char(20), salary_dc decimal ( 12,2) ) Insert a line into T_Compare_columns: Insert into T_Compare_columns values ( 'county_cd' ) Then use that to perform an 'indirect reference' comparison. This statement is pure fiction. I know it will not work in this form: select * from T_Datastuff where T_Compare_column.col_name = T_datastuff.COLUMN_NAME and t_datastuff.COLUMN_NAME = 'RICHLAND' Thank you, Alena ... |
| 20.11.2001, 15:23 |
There are 3 things in MSSQL to help to solve the task: 1) Operator "EXEC(string_expression)" for executing a dynamic query. 2,3) System tables "syscolumns" and "sysobjects", where there are columns' and tables' names. It is enough. ... |
| 21.11.2001, 07:23 |
start [/forum/topic.php?desktop=1&fid=46&tid=1824923]: |
177ms |
23ms |
| others: | 234ms |
| total: | 473ms |
