Обмен опытом
Привет всем. Эта статейка проскочила в рассылке и я думаю, может кому пригодиться... От себя добавлю что это работает также в 2000. Alexander Chigrik chigrik@hotmail.com To get the total row count in a table, we usually use the following select statement: SELECT count(*) FROM This query will perform full table scan to get the row count. You can check it by setting SET SHOWPLAN ON for SQL Server 6.5 or SET SHOWPLAN_TEXT ON for SQL Server 7.0. So, if the table is very big, it can take a lot of time. This is the example of simple table creation and addition of new records into this table: CREATE TABLE tbTest ( id int identity primary key, Name char(10) ) GO DECLARE @i int SELECT @i = 1 WHILE @i <= 10000 BEGIN INSERT INTO tbTest VALUES (LTRIM(str(@i))) SELECT @i = @i + 1 END GO There is another way to determine the total row count in a table. You can use sysindexes system table for this purpose. There is field ROWS in the sysindexes table. This field contains the total row count for each table in your database. So, you can use the following select statement instead above one: SELECT rows FROM sysindexes WHERE id = OBJECT_ID('table_name') AND indid < 2 There are physical read and logical read operations. A logical read occurs if the page is currently in the cache. If the page is not currently in the cache, a physical read is performed to read the page into the cache. To see how many logical or physical read operations were made, you can use SET STATISTICS IO ON command. This is the example: SET STATISTICS IO ON GO SELECT count(*) FROM tbTest GO SELECT rows FROM sysindexes WHERE id = OBJECT_ID('tbTest') AND indid < 2 GO SET STATISTICS IO OFF GO This is the results: ----------- 10000 (1 row(s) affected) Table 'tbTest'. Scan count 1, logical reads 32, physical reads 0, read-ahead reads 0. rows ----------- 10000 (1 row(s) affected) Table 'sysindexes'. Scan count 1, logical reads 2, physical reads 0, read-ahead reads 0. So, you can improve the speed of the first query in several times. This works for SQL Server 6.5 and SQL Server 7.0 as well. ... |
| 21.11.2001, 18:11 |
Обмен опытом
Спасибо. Интересно. А не подскажите адресок сервера рассылки? ... |
| 21.11.2001, 22:28 |
start [/forum/topic.php?desktop=1&fid=46&tid=1824897]: |
158ms |
37ms |
| others: | 231ms |
| total: | 467ms |
