Ошибки при бэкапе
Подскажите пожалуйста, при бэкапе базы выдает: Backup, CHECKALLOC, bulk copy, SELECT INTO, and file manipulation (such as CREATE FILE) operations on a database must be serialized. Reissue the statement after the current backup, CHECKALLOC, or file manipulation operation is completed. [SQLSTATE 42000] (Error 3023) Backup or restore operation terminating abnormally. [SQLSTATE 42000] (Error 3013). The step failed. что делать ??? С уважением, Евгений ... |
| 28.01.2002, 07:18 |
start [/forum/topic.php?desktop=1&fid=46&tid=1824170]: |
71ms |
34ms |
| others: | 242ms |
| total: | 402ms |
