Ошибка SQL
SQL State: 42000 Native: 601 Message: Count not continue scan with NOLOCK due to data movement Что означает данная ошибка и как с ней бороться? ... |
| 05.02.2002, 11:44 |
Ошибка SQL
Error 601 Severity Level 12 Message Text Could not continue scan with NOLOCK due to data movement. Explanation When scanning with the NOLOCK locking hint or with the transaction isolation level set to READ UNCOMMITTED, it is possible for the page at the current position of the scan to be deleted . When this happens, Microsoft® SQL Server™ is not able to continue the scan. Action This error aborts the query. Either resubmit the query or remove the NOLOCK locking hint. ... |
| 05.02.2002, 12:01 |
start [/forum/topic.php?desktop=1&fid=46&tid=1824044]: |
30ms |
| others: | 241ms |
| total: | 324ms |
