Форумы / Microsoft SQL Server [игнор отключен] [закрыт для гостей] / SQL mail
11 сообщений из 11, страница 1 из 1
SQL mail
    #32024525
slavasl
Ja ispolzuj proceduru
xp_readmail
No ona vivodit na ekran vse postupivsie soobsenija
Kak sdelat' tak ctobi ona.
Citala novoe postupivsee soobsenie.
I klala dannie eto go soobsenija v tabllicu
SQL mail
    #32024602
Glory
IMHO приблизительно так
DECLARE @status int, @message_id varchar(255)
EXEC @status = xp_findnextmsg @unread_only = 'TRUE', @msg_id = @message_id OUTPUT
IF @message_id IS NOT NULL
BEGIN
EXEC @status = xp_readmail @msg_id = @message_id, ...
IF @status <> 0 INSERT ....
END
SQL mail
    #32024634
slavasl
Privet
Sdelal tak
No on daze ne sozdajot tablicu ((
V cjon mozet bit' problema
BEGIN
IF @status <> 0 CREATE TABLE T1 ( column_1 int, column_2 varchar(30))
--BEGIN
-- INSERT T1 VALUES (1, 'Row #1')
--END
END
SQL mail
    #32024646
Glory
Стало быть не выполнются либо IF @message_id IS NOT NULL либо IF @status <> 0.
SQL mail
    #32024650
slavasl
Spasibo esjo raz v takom variante poslo
Kstati ja toze iz Eesti ti otkuda ))
Da i vot takoj vopros poka ti v seti doputim u meja s pismom prihodit n attachment faillov .
Kak mne prosmotret' i polozit' soderzimoe failov v B.d.
Esjo raz spasibo ))
DECLARE @status int, @message_id varchar(255),@message varchar(30),@subject varchar(30)
EXEC @status = master.dbo.xp_findnextmsg @msg_id = @message_id OUTPUT
BEGIN
EXEC master.dbo.xp_readmail @msg_id = @message_id, @message=@message OUTPUT, @subject=@subject OUTPUT
--polja nado delat' odinakovimi s objavleniem odnoj dlini ))
IF @subject<>'SQLtest'
BEGIN
--CREATE TABLE T1 ( column_1 varchar(30), column_2 varchar(30),column_3 varchar(30))
INSERT T1 VALUES (@message_id, @message, @subject)
SELECT @message_id,@subject
--INSERT T1 VALUES (1, @originator)
--EXEC xp_deletemail @msg_id = @message_id
END
END
SQL mail
    #32024651
Glory
BOL
xp_readmail .... [,[@attachments =] 'attachments [;...n]' OUTPUT]
Is the semicolon-separated list of returned temporary paths of the mail attachments for the message. Temporary paths are separated by a semicolon (; ). attachments is varchar(255), with no default.
SQL mail
    #32024769
slavasl
Privet s 8 marta tebja
A tak ctobi dannie pisalis' v tablicu nelzja sdelat'.
I esjo ti ne znaes' est' li stored procedures dlaj sozdanija DTS.
T.e. mne nado sozdat' DTS script i zapustit' na drugoj masine ctobi on sozdalsja.
Ja proboval cerez VB modul sozdaval *.exe fail no nicego ne poslo ((
SQL mail
    #32024818
Glory
Хм, вообще-то мой праздник был 23-го февраля
А в чем проблема. В команде INSERT можно использовать часть VALUES, которая прекрасно понимает переменные. Или вы о чем-то другом ?
DTS script ? Этот вы о чем ? DTS Package - знаю, script - тоже наверное знаю, а вот DTS script. Поподробнее, если можно
Чем больше информации вы обнародуете, тем более правильные ответы/советы вы получите
SQL mail
    #32024923
slavasl
Ups(Nick podvjol) ))))))) Tak s prosedsim 23 Fevralja ))))
T.e. u menja prikrepljon fail s rassireniem cvs(txt) v njom nekotorije dannie.
Vibrat' eti dannie i vstavit' v konkretnie jacejki konkretnij tablici
Script dlja sozdanija DTS Package. Ili sussestvuet li vozmoznos' ispolzovat' stored procedures dlja sozdanija DTS Package
T.e ja proboval sozdat' DTS Package pri pomosi VB no on ne pojavilsja v SQL Server ((
SQL mail
    #32025021
Glory
Вы хотите это проделать на T-SQL, т.е. создать хранимую процедуру и читать из нее содержимое присланного файла?
Документированных возможностей и процедур для переноса DTS Package, которые сохранены в виде Local Packages или Meta Data Service Packages НЕТ.
Можно только при записи DTS Package сохранить его на другом сервере, выбрав сервер в соответствующем диалоге.
Либо скопировать базу msdb, т.к. все DTS Package храняться там. Правда там храниться не только они(например настройки репликации), поэтому такое действие может повлиять на работоспособность другого сервера.(можно конечно "покопаться" в msdb и точно выяснить, какие таблицы используются для хранения DTS Package, но есть ли у вас на это время и желание ?)
http://www.sql.ru/articles/article.php?id=497
SQL mail
    #32025270
slavasl
SPASIBO VSJO SDELAL RBOTU S ATTACHMENT IZ DTS KAK ZAPISIVAT' DTS NASJOL.
BOLSOE SPASIBO
