Вопрос по 70-028.
Есть вопрос по экзамену 70-028. Вопрос взяь из дампа по экзамену. \n60. The backup schedule for the Accounting database is shown in the following table. -1:00 A.M. Full database backup -7:00 A.M. Transaction log backup -8:00 A.M. Transaction log backup -9:00 A.M. Transaction log backup At 8.45 A.M. on October 10, 1998 a user runs a now transaction that incorrectly updates data in several tables. The manager of the Accounting department tells you that all updates after that time can be reconstructed from the paper forms. You restore the 1:00 A.M. full database backup. Which set of steps is the best method to use to restore the database to a consistent state closest to what the state was at 8:45 A.M.? A. Restore the 7:00 A.M. transaction log backup by using the WITH NORECOVERY option. B. Restore the 8:00 A.M. transaction log backup by using the WITH NORECOVERY option. C. Restore the 9:00 A.M. transaction log backup by using the WITH RECOVERY option and the STOPAT = 'Oct 10. 1998, 8:44 AM' option. Answer: A Вот в чем проблема. Я не уверен в правильности ответа. Если ответ А то БД будет недоступна для работы. Этот вопрос есть во всех дампах которые есть у меня, и во всех ответ А. Чего я непонимаю. ... |
| 29.03.2002, 12:19 |
start [/forum/topic.php?desktop=1&fid=46&tid=1823315]: |
50ms |
| others: | 210ms |
| total: | 321ms |
