Вставка данных в DBF из sql (DBF file is local, i.e. not on the MS SQL Server)
MS SQL 7.0 SP.#3 Server NT 4.0. SP.#6 Workstation Win98 INSERT INTO OpenDataSource( 'Microsoft.Jet.OLEDB.4.0','Data Source="C:\DbfData";Extended properties=DBase IV')...DBF_TABLE SELECT * FROM DEST_SQLSERVER_TABLE Server: Msg 7306, Level 16, State 2: Could not open table 'OPER' from OLE DB provider 'Microsoft.Jet.OLEDB.4.0'. The provider could not support a row lookup position. The provider indicates that conflicts occurred with other properties or requirements. ... |
| 02.04.2002, 10:50 |
start [/forum/topic.php?desktop=1&fid=46&tid=1823259]: |
147ms |
51ms |
| others: | 245ms |
| total: | 493ms |
