SQL error 7306
Immetsja MS SQL 7.0 na VB runajetsja prilozhenie kotoroe updaitaet nekotorie polja no pri pri UPDATE Sql vidaet oshibku 7306...opisanija oshibki minimalno...vezde na poljah stoit public permission UPDATE...mozhet kto to stalkivalsja s dannoi problemoi ...pozhaluista milnite na mopo3ko@pisem.net ... |
| 05.04.2002, 20:43 |
SQL error 7306
Error 7306 Severity Level 16 Message Text Could not open table '%ls' from OLE DB provider '%ls'. %ls Explanation This error message is returned if the OLE DB provider does not support the interfaces and OLE DB properties required for the UPDATE, DELETE, and INSERT statements. For example, in the case of Microsoft® SQL Server™, the INSERT, UPDATE, and DELETE statements are not supported on the remote table if the table does not have a unique index defined on it. ... |
| 06.04.2002, 10:20 |
start [/forum/topic.php?desktop=1&fid=46&tid=1823205]: |
163ms |
43ms |
| others: | 211ms |
| total: | 456ms |
