Как подменить .dat файл, что бы не было метки suspect?
Мне надо подменить dat-файл, в директории DATA, но лезет suspect. Как с ним бороться? ... |
| 12.04.2002, 09:21 |
Надо делать так: Шаг 1. отсоединить старую базу данных: sp_detach_db [@dbname =] 'dbname' [, [@skipchecks =] 'skipchecks'] Arguments [@dbname =] 'dbname' Is the name of the database to be detached. dbname is sysname, with a default value of NULL. [@skipchecks =] 'skipchecks' skipchecks is nvarchar(10), with a default value of NULL. If true, UPDATE STATISTICS is skipped. If false, UPDATE STATISTICS is run. This option is useful for databases that are to be moved to read-only media. Шаг 2. скопировать файлы Шаг 3. присоединить новую базу данных: sp_attach_db [@dbname =] 'dbname', [@filename1 =] 'filename_n' [,...16] Arguments [@dbname =] 'dbname' Is the name of the database to be attached to the server. The name must be unique. dbname is sysname, with a default of NULL. [@filename1 =] 'filename_n' Is the physical name, including path, of a database file. filename_n is nvarchar(260), with a default of NULL. There can be up to 16 file names specified. The parameter names start at @filename1 and increment to @filename16. The file name list must include at least the primary file, which contains the system tables that point to other files in the database. The list must also include any files that were moved after the database was detached. ... |
| 13.04.2002, 10:51 |
start [/forum/topic.php?desktop=1&fid=46&tid=1823109]: |
152ms |
| others: | 249ms |
| total: | 458ms |
