SQL help
Guys, I have 2 select can I make one? use SQL like: select sum(f1) from (select table1.f1 from table1 ) This is two select wich I want compare togather. Any idea? Thanks a lot. SELECT AreaCd, SMAssigned, SUM(ED) AS ED, SUM(HIV) AS HIV, SUM(ED_OSS) as ED_OSS, SUM(HIV_OSS) as HIV_OSS, SUM(VENT) AS VENT, SUM(CPCA) AS CPCA, SUM(OSS) AS OSS, SUM(PENDED) AS PENDED, SUM(PENDHIV) AS PENDHIV, SUM(PENDNH) AS PENDNH, SUM(PENDOTH) AS PENDOTH, SUM(EDWAIT) AS EDWAIT FROM dbo.vwRptRosterSum GROUP BY AreaCd, SMAssigned CREATE VIEW dbo.vwRptRosterSum AS SELECT AreaCd, SMAssigned, status, ED = CASE WHEN Status=1 THEN 1 ELSE 0 END, HIV = CASE WHEN Status=3 THEN 1 ELSE 0 END, ED_OSS = CASE WHEN Status=37 THEN 1 ELSE 0 END, HIV_OSS = CASE WHEN Status=38 THEN 1 ELSE 0 END, VENT = CASE WHEN Status=2 THEN 1 ELSE 0 END, CPCA =CASE WHEN Status=4 THEN 1 ELSE 0 END, OSS = CASE WHEN Status=24 THEN 1 ELSE 0 END, PENDED = CASE WHEN (CodeClientChoice =3 and (status=26 or status=27)) then 1 ELSE 0 END , PENDHIV = CASE WHEN (CodeClientChoice =4 and status=27) then 1 ELSE 0 END , PENDNH = CASE WHEN (CodeClientChoice <3 and status=27) then 1 ELSE 0 END , PENDOTH = CASE WHEN (CodeClientChoice >4 and status=27) then 1 ELSE 0 END, EDWAIT = CASE WHEN (WaitListCategory='ED' ) then 1 ELSE 0 END FROM dbo.vwRptRosterDetailWaitingList ... |
| 18.04.2002, 14:30 |
SQL help
По английски я не очень... MAIN IDEA SELECT SUM(CASE WHEN Status=1 THEN 1 ELSE 0 END) AS ED FROM dbo.vwRptRosterDetailWaitingList ... |
| 18.04.2002, 15:09 |
SQL help
Thanks a lot, it is working!!!! ... |
| 18.04.2002, 15:36 |
start [/forum/topic.php?desktop=1&fid=46&tid=1823033]: |
| others: | 195ms |
| total: | 256ms |
