DTS - JOB Замучил
Не могу врубиться, что не так... При выполнении jobа на DTS всплывает ошибка DTSRun: Loading... DTSRun: Executing... DTSRun OnStart: Create Table M_HW_P Step DTSRun OnError: Create Table M_HW_P Step, Error = -2147467259 (80004005) Error string: The Microsoft Jet database engine cannot open the file ''. It is already opened exclusively by another user, or you need permission to view its data. Error source: Microsoft JET Database Engine Help file: Help context: 5003051 Error Detail Records: Error: -2147467259 (80004005); Provider Error: -534709256 (E020FBF Error string: The Microsoft Jet database engine cannot open the file ''. It is already opened exclusively by another user, or you need permission to view its data. Error source: Microsoft JET Database Engine Help file: Help context: 5003051 DTSRun OnFinish: Create Table M_HW_P Step DTSRun OnStart: Copy Data from MOSCOW_HIGHWAY_PEOPLE to M_HW_P Step DTSRun OnError: Copy Data from MOSCOW_HIGHWAY_PEOPLE to M_HW_P Step, Error =. The step failed. Что не так? Помогите ... |
| 22.05.2002, 07:35:01 |
DTS - JOB Замучил
The Microsoft Jet database engine cannot open the file ''. А файл-то есть ? А у учетной записи SQL Server Agent-а есть права на файл ? ... |
| 22.05.2002, 10:04:25 |
start [/forum/topic.php?desktop=1&fid=46&tid=1822628]: |
176ms |
35ms |
| others: | 205ms |
| total: | 447ms |
