Applications can perform bulk update, delete, fetch, or insertion operations on
Applications can perform bulk update, delete, fetch, or insertion operations on the underlying table at the data source with a call to SQLBulkOperations. Calling SQLBulkOperations is a convenient alternative to constructing and executing an SQL statement. It lets an ODBC driver support positioned updates even when the data source does not support positioned SQL statements. It is part of the paradigm of achieving complete database access by means of function calls. SQLBulkOperations operates on the current rowset and can be used only after a call to SQLFetch or SQLFetchScroll. The application specifies the rows to update, delete, or refresh by caching their bookmarks. The driver retrieves the new data for rows to be updated, or the new data to be inserted into the underlying table, from the rowset buffers. The rowset size to be used by SQLBulkOperations is set by a call to SQLSetStmtAttr with an Attribute argument of SQL_ATTR_ROW_ARRAY_SIZE. Unlike SQLSetPos, which uses a new rowset size only after a call to SQLFetch or SQLFetchScroll, SQLBulkOperations uses the new rowset size after the call to SQLSetStmtAttr. Because most interaction with relational databases is done through SQL, SQLBulkOperations is not widely supported. However, a driver can easily emulate it by constructing and executing an UPDATE, DELETE, or INSERT statement. To determine what operations SQLBulkOperation supports, an application calls SQLGetInfo with the SQL_DYNAMIC_CURSOR_ATTRIBUTES1, SQL_FORWARD_ONLY_CURSOR_ATTRIBUTES1, SQL_KEYSET_CURSOR_ATTRIBUTES1, or SQL_STATIC_CURSOR_ATTRIBUTES1 information option (depending on the type of the cursor). Ну что вставлять данные используя bcp_init, bcp_sendrow это понятно, а вот что они хотели сказать про bulk update? Что действительно можно обновлять без записи в лог? Кто нибудь делал это? И если это работает то возникает вопрос КАК БЫСТРО? Мне просто приходилось обновлять поле большой таблицы и хотелось бы сделать это побыстрее. ... |
| 05.07.2002, 17:26:08 |
Note : The ODBC SQLBulkOperations function has no relationship to the SQL Server bulk copy functions. Applications must use the SQL Server-specific bulk-copy functions to perform bulk copy operations ... |
| 05.07.2002, 17:33:35 |
Кто нибудь делал update? ... |
| 05.07.2002, 17:41:34 |
start [/forum/topic.php?desktop=1&fid=46&tid=1821975]: |
34ms |
| others: | 206ms |
| total: | 293ms |
