Как закрыть процессы в Current Activity
Подскажите с помощью какой процедуры можно убить процессы в Managment->Current Activity если это возможно. Или подскажите как можно закрывать не нужные(с моей точки зрения) процессы автоматически . ... |
| 12.08.2002, 12:25:10 |
KILL Terminates a user process based on the system process ID (SPID) or unit of work (UOW). If the specified SPID or UOW has a lot of work to undo, the KILL command may take some time to complete, particularly when it involves rolling back a long transaction. In Microsoft® SQL Server™ 2000, KILL can be used to terminate a normal connection, which internally terminates the transactions associated with the given SPID. In addition, the command can also be used to terminate all orphaned distributed transactions when Microsoft Distributed Transaction Coordinator (MS DTC) is in use. A distributed transaction is orphaned when it is not associated with any current SPID. Syntax KILL {spid | UOW} [WITH STATUSONLY] См далее help там есть таблица и проекция со списком процесов и.т.д ... |
| 12.08.2002, 12:29:36 |
start [/forum/topic.php?desktop=1&fid=46&tid=1821213]: |
48ms |
44ms |
| others: | 214ms |
| total: | 359ms |
