Не могу восстановить master ???
Рухнул диск с базой, но есть все бэкапы. восстановил переформатировал диск. Делаю ребьюилд базы мастер этот rebuildm зависает на server configuration в events и логе вот такое сообщение - чтобы это значило 2002-09-03 13:34:39.33 server Microsoft SQL Server 2000 - 8.00.384 (Intel X86) May 23 2001 00:02:52 Copyright (c) 1988-2000 Microsoft Corporation Standard Edition on Windows NT 5.0 (Build 2195: Service Pack 2) 2002-09-03 13:34:39.34 server Copyright (C) 1988-2000 Microsoft Corporation. 2002-09-03 13:34:39.34 server All rights reserved. 2002-09-03 13:34:39.34 server Server Process ID is 1312. 2002-09-03 13:34:39.34 server Logging SQL Server messages in file 'd:\mssql2000db\MSSQL\log\ERRORLOG'. 2002-09-03 13:34:39.34 server SQL Server is starting at priority class 'normal'(2 CPUs detected). 2002-09-03 13:34:39.50 server SQL Server configured for thread mode processing. 2002-09-03 13:34:39.50 server Using dynamic lock allocation. [2500] Lock Blocks, [5000] Lock Owner Blocks. 2002-09-03 13:34:39.64 server Attempting to initialize Distributed Transaction Coordinator. 2002-09-03 13:34:40.20 server Failed to obtain TransactionDispenserInterface: Result Code = 0x8004d01b 2002-09-03 13:34:40.27 spid4 Warning ****************** 2002-09-03 13:34:40.27 spid4 SQL Server started in single user mode. Updates allowed to system catalogs. 2002-09-03 13:34:40.33 spid4 Starting up database 'master'. 2002-09-03 13:34:40.33 spid4 udopen: Operating system error 5(error not found) during the creation/opening of physical device d:\mssql2000db\MSSQL\data\master.mdf. 2002-09-03 13:34:40.33 spid4 FCB::Open failed: Could not open device d:\mssql2000db\MSSQL\data\master.mdf for virtual device number (VDN) 1. 2002-09-03 13:34:40.33 spid4 Error: 5105, Severity: 16, State: 4. 2002-09-03 13:34:40.34 spid4 udopen: Operating system error 5(error not found) during the creation/opening of physical device d:\mssql2000db\MSSQL\data\mastlog.ldf. 2002-09-03 13:34:40.34 spid4 FCB::Open failed: Could not open device d:\mssql2000db\MSSQL\data\mastlog.ldf for virtual device number (VDN) 2. 2002-09-03 13:34:40.34 spid4 Error: 5105, Severity: 16, State: 4. 2002-09-03 13:34:40.39 spid4 Error: 5180, Severity: 22, State: 1. ... |
| 03.09.2002, 13:41:28 |
start [/forum/topic.php?desktop=1&fid=46&tid=1820655]: |
86ms |
29ms |
| others: | 229ms |
| total: | 396ms |
