XmlDatas
Привет всем!!! Declare @var varchar SET @var = select smth form smwhere for xml auto не работает!! Как сделать что-бы работало? ... |
| 11.09.2002, 18:21:37 |
XmlDatas
Никак BOL - XML and Internet Support - Retrieving and Writing XML Data - Retrieving XML Documents Using FOR XML - Guidelines for Using the FOR XML Clause "The FOR XML clause is valid only in the SELECT statement and is subject to these limitations: FOR XML is not valid in subselections, whether it is in UPDATE, INSERT, or DELETE statements, a nested SELECT statement, or other statements (SELECT INTO, assignment). For example, subselects as shown in these examples are not supported: Example A SELECT * FROM Table1 WHERE ......(SELECT * FROM Table2 FOR XML RAW) Example B DECLARE @doc nchar(3000) SET @doc = (SELECT * FROM Customers WHERE CustomerID = 'ALFKI' FOR XML RAW) " ... |
| 11.09.2002, 18:25:28 |
start [/forum/topic.php?desktop=1&fid=46&tid=1820421]: |
69ms |
59ms |
| others: | 230ms |
| total: | 407ms |
