Application Role
Есть сервер, в базе master создана роль приложения, как предоставить ей право на доступ к другим базам данного сервера? ... |
| 16.09.2002, 10:12:59 |
Application Role
BOL - Administering SQL Server - Managing Security - Advanced Security Topics - Establishing Application Security and Application Roles "Because application roles are applicable only to the database in which they exist, the connection can gain access to another database only through permissions granted to the guest user account in the other database. Therefore, if the guest user account does not exist in a database, the connection cannot gain access to that database. " ... |
| 16.09.2002, 12:06:27 |
start [/forum/topic.php?desktop=1&fid=46&tid=1820330]: |
63ms |
33ms |
| others: | 198ms |
| total: | 336ms |
