which SQLServer group my current login is coming through ?
Using integrated security for SQL 2000 on Windows 2000, I have established several requested login groups which can access the databases. I can connect to the SQL Servers using trusted connection , is there a way to see which SQLServer group my current login is coming through ? Thanks ... |
| 09.10.2002, 02:24:12 |
start [/forum/topic.php?desktop=1&fid=46&tid=1819759]: |
60ms |
| others: | 222ms |
| total: | 335ms |
