hint OPTION(FORCE ORDER) in user-defined function:compilation error
How to use hint OPTION(FORCE ORDER) in user-defined function? create table a(i int ,val char ) create table b( i int, data char) go create function my_func (@v char) returns table as return ( select b.* from b JOIN a ON a.id=b.id OPTION(FORCE ORDER) ) go Output: Server: Msg 156, Level 15, State 1, Procedure my_func, Line 5 Incorrect syntax near the keyword 'OPTION'. ... |
| 12.11.2002, 21:33:43 |
Choose in QA - Query - Show Execution Plan and check this script Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. ... |
| 12.11.2002, 22:02:25 |
Thanks, but ... 1) I want to hide this hint from users , which will use this function, it means I want keep hint in the body of function. 2) interesting point is that other hints, like NOLOCK, can be embedded in user-defined function without any problem. Thanks again ... |
| 12.11.2002, 22:24:32 |
You can use several table hints in same query (for each table, join, ect.) but only one OPTION clause. For example you can't create a view with OPTION clause. But you can create a view with several table hints. So a think it's the feature. OPTION hint(s) should be used throughout the entire query . So it's impossible that something in FROM Clause (inline UDF, view) already contains OPTION hint(s). ... |
| 12.11.2002, 22:47:45 |
start [/forum/topic.php?desktop=1&fid=46&tid=1818866]: |
23ms |
30ms |
| others: | 199ms |
| total: | 287ms |
