SQLServerAgent
Можно ли программно настроить под каким аккаунтом будет запускаться SQLServerAgent в SQLServer 7.0? Используется SQLServer authentication. ... |
| 15.11.2002, 10:17:41 |
SQLServerAgent
Есть вот такая инфа: To query and change the execution state of the following services on a local computer a.. Microsoft SQL Server (MSSQLServer) b.. SQL Server Agent (SQLServerAgent) c.. MS DTC (MSDTC) Microsoft uses the w95scm.dll a.. Start the SQL Server (MSSQLServer), SQL Server Agent (SQLServerAgent) or MS DTC (MSDTC) services on the local computer. b.. Pause and continue the MSSQLServer service. c.. Stop a supported service. d.. Query a supported service to determine its current execution state. and provides only this headers (this functions only works with the LOCAL MACHINE. I need a remote SERVER): SQLSCMLocalServiceControlA SQLSCMLocalServiceControlW SQLSCMGetLocalServiceStateA SQLSCMGetLocalServiceStateW Where are the others headers ? SQLSCMChangeServiceConfigA SQLSCMChangeServiceConfigPlatA SQLSCMChangeServiceConfigPlatW SQLSCMControlA SQLSCMControlPlatA SQLSCMControlPlatW SQLSCMControlW SQLSCMEnumClusterSQLServicesW SQLSCMEnumDependentServicesA SQLSCMEnumDependentServicesW SQLSCMGetLocalServiceStateA SQLSCMGetLocalServiceStateW SQLSCMGetServiceStateA SQLSCMGetServiceStatePlatA SQLSCMGetServiceStatePlatW SQLSCMGetServiceStateW SQLSCMLocalSQLServerReady SQLSCMLocalServiceControlA SQLSCMLocalServiceControlW SQLSCMQueryServiceConfigA SQLSCMQueryServiceConfigPlatA SQLSCMQueryServicePlatW ... |
| 15.11.2002, 10:36:51 |
start [/forum/topic.php?desktop=1&fid=46&tid=1818795]: |
37ms |
33ms |
| others: | 207ms |
| total: | 323ms |
