Непонятная ошибка при попытке резервного копирования тразакций
Microsoft SQL Server 2012 (SP3) (KB3072779) - 11.0.6020.0 (X64) При выполнении из джоба резервного копирования транзакций возникает такая ошибка: Date,Source,Severity,Step ID,Server,Job Name,Step Name,Notifications,Message,Duration,Sql Severity,Sql Message ID,Operator Emailed,Operator Net sent,Operator Paged,Retries Attempted 02/05/2018 08:13:38,Backup.Transaction Backup,Error,,BOSS,Backup.Transaction Backup,,,The job failed. The Job was invoked by User sa. The last step to run was step 1 (Transaction Backup).,00:00:02,0,0,Database Administrator,,,0 02/05/2018 08:13:38,Backup.Transaction Backup,Error,1,BOSS,Backup.Transaction Backup,Transaction Backup,,Executed as user: NT Service\SQLSERVERAGENT. Microsoft (R) SQL Server Execute Package Utility Version 11.0.6020.0 for 64-bit Copyright (C) Microsoft Corporation. All rights reserved. Started: 8:13:38 Progress: 2018-02-05 08:13:39.03 Source: {6748D34C-FFDB-4A94-9E71-61896C54C68A} Executing query "DECLARE @Guid UNIQUEIDENTIFIER EXECUTE msdb..sp...".: 100% complete End Progress Progress: 2018-02-05 08:13:39.05 Source: Maintenance Cleanup Task Executing query "EXECUTE master.dbo.xp_delete_file 0<c/>N'E:\MSSQL_Bac...".: 100% complete End Progress Progress: 2018-02-05 08:13:39.14 Source: Back Up Database Task Executing query "EXECUTE master.dbo.xp_create_subdir N'E:\MSSQL_Bac...".: 100% complete End Progress Error: 2018-02-05 08:13:39.14 Code: 0xC002F210 Source: Back Up Database Task Execute SQL Task Description: Executing the query "BACKUP LOG [silo] TO DISK = N'E:\MSSQL_Backup\sil..." failed with the following error: "BACKUP LOG cannot be performed because there is no current database backup. BACKUP LOG is terminating abnormally.". Possible failure reasons: Problems with the query<c/> "ResultSet" property not set correctly<c/> parameters not set correctly<c/> or connection not established correctly. End Error DTExec: The package execution returned DTSER_FAILURE (1). Started: 8:13:38 Finished: 8:13:39 Elapsed: 0.453 seconds. The package execution failed. The step failed.,00:00:02,0,0,,,,0 Данная ошибка возникает раз в неделю, после реиндексации базы: Код: sql 1. 2. 3. Приходится делать полный или разностный бекап, после чего бекап транзакций выполняется уже без ошибок. В чем проблема? ... |
| 05.02.2018, 09:25:41 |
Slon747, А что тебя удивляет? Переведя базу в режим simple ты , по сути, сказал серверу "друже, забудь про всё, что было до этого момента. все полные бэкапы с этого момента - куча никому ненужного мусора". Теперь же, когда ты перевел базу вновь в режим "FULL", ты говоришь, что начинаем всю историю с чистого листа. А первой записью на чистом листе в истории резервного копирования должна быть запись о полном или разностном бэкапе, чтобы было к чему применять твой транзакции из лога. Понимаешь? А полного бэrапа-то и нету... Логично, что после выполнения полного копирования начинает работать копирование журналов... З.Ы. и это, если что, определяется и диктуется документацией, как ни странно... :) ... |
| 05.02.2018, 09:33:03 |
Добрый Э - ЭхSlon747, А что тебя удивляет? Переведя базу в режим simple ты , по сути, сказал серверу "друже, забудь про всё, что было до этого момента. все полные бэкапы с этого момента - куча никому ненужного мусора". Теперь же, когда ты перевел базу вновь в режим "FULL", ты говоришь, что начинаем всю историю с чистого листа. А первой записью на чистом листе в истории резервного копирования должна быть запись о полном или разностном бэкапе, чтобы было к чему применять твой транзакции из лога. Понимаешь? А полного бэrапа-то и нету... Логично, что после выполнения полного копирования начинает работать копирование журналов... З.Ы. и это, если что, определяется и диктуется документацией, как ни странно... :) Да, теперь понял. Когда настраивал джобы, учитывал это. Потом, меняя последовательность их выполнения, забыл про эту особенность. Спасибо. P.S. Правильно ли перед реиндексацией переводить базу в Simple? Вроде как в этой версии MSSQL иначе нельзя? ... |
| 05.02.2018, 09:49:46 |
Slon747P.S. Правильно ли перед реиндексацией переводить базу в Simple? Вроде как в этой версии MSSQL иначе нельзя?В какой этой? Ты с online для Enterprise не попутал случайно? В общем случае, операция перестроения индексов вполне себе успешно отработает, вне зависимости от режима восстановления базы. Другое дело, что при этом создается дополнительная нагрузка на журнальный файл... ... |
| 05.02.2018, 09:58:30 |
Slon747, в целом, по перестройке индексов, зачем их все подряд перестраивать? в интернете слишком много скриптов по "интеллектуальному" отбору индексов на перестройку, чтобы не найти их простым поиском. Как показывает практика, далеко не все индексы нуждаются в перестройке... Зачем создавать лишнюю работу серверу? У вас холодно в серверной? Или запас жестких дисков настолько обременителен, что вы решили по быстрее их все затереть до дыр, чтобы хоть как-то расходовать? ... |
| 05.02.2018, 10:05:03 |
Добрый Э - ЭхSlon747P.S. Правильно ли перед реиндексацией переводить базу в Simple? Вроде как в этой версии MSSQL иначе нельзя?В какой этой? Ты с online для Enterprise не попутал случайно? В общем случае, операция перестроения индексов вполне себе успешно отработает, вне зависимости от режима восстановления базы. Другое дело, что при этом создается дополнительная нагрузка на журнальный файл...тут имеется ввиду кляуза ONLINE в команде перестроения индекса ALTER INDE ... REBUILD ... А то мало ли кто и как поймет его... :) ... |
| 05.02.2018, 10:10:21 |
Добрый Э - Эх, Спасибо. ... |
| 05.02.2018, 10:11:36 |
Slon747P.S. Правильно ли перед реиндексацией переводить базу в Simple? Вроде как в этой версии MSSQL иначе нельзя? Вот вам мнение Пола Рэндала: https://www.sqlskills.com/blogs/paul/sqlskills-sql101-switching-recovery-models/ Он считает, что в SIMPLE базу переводить не надо никогда, в Bulk-logged можно, но осторожно, и осознавая последствия своих действий (последствия он в этой статье и описывает). ... |
| 05.02.2018, 11:07:04 |
Minamoto, Я тут в пятницу с сервером работал, там народ вообще жжет, я такой фигни за все время работы админом не видел. В общем джоб такой, сначала пересчитываем статистику, потом включаем параллелизм (да да, maxdoop стоит 1, хотя на 70% нагрузка OLAP), делаем ребилд (именно ребилд) ВСЕХ индексов, отключаем параллелизм и делаем SHRINK, занавес. ... |
| 05.02.2018, 11:40:23 |
aleksrov, классический набор антипаттернов. Люди начитались "рекомендаций" по обслуживанию, а смысл их не понимают. Вот как раз серия статей Рэндала SQL101 для таких - чтобы разобраться в подобных ошибках. ... |
| 05.02.2018, 13:46:40 |
start [/forum/topic.php?desktop=1&fid=46&tid=1690344]: |
171ms |
46ms |
| others: | 203ms |
| total: | 465ms |
