1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
127.
128.
129.
130.
131.
132.
133.
134.
135.
136.
137.
138.
139.
140.
141.
142.
143.
144.
145.
146.
147.
148.
149.
150.
151.
152.
153.
154.
155.
156.
157.
158.
159.
160.
161.
162.
163.
164.
165.
166.
167.
168.
169.
170.
171.
172.
173.
174.
175.
176.
177.
178.
179.
180.
181.
182.
183.
184.
185.
186.
187.
188.
189.
190.
191.
192.
193.
194.
195.
196.
197.
198.
199.
200.
201.
202.
203.
204.
205.
206.
207.
208.
209.
210.
211.
212.
213.
214.
215.
216.
217.
218.
219.
220.
221.
222.
223.
224.
225.
226.
227.
228.
229.
230.
231.
232.
233.
234.
235.
236.
237.
238.
239.
240.
241.
242.
243.
244.
245.
246.
247.
248.
249.
250.
251.
252.
253.
254.
Select distinct
a.[holeid],
case row_number() over(partition by a.holeid order by geolfrom) when 1 then a.HOLEID end as x_holeid,
(case when a.EventFrom<b.geolFrom Then b.geolFrom Else a.EventFrom end) as [From],
(case when a.EventTo>b.geolTo Then b.geolTo Else a.EventTo end) as [To],
a.[DRILLINGDATE],
b.[VALUE], tab8.[Primary Lithology]
From
(Select holeid,drillingdate,
max( case
when [DRILLINGDETAIL].[NAME] = 'EventFrom' and [Shift]='day' then
[DRILLINGDETAIL].[VALUE]
end)EventFrom
,max( case
when [DRILLINGDETAIL].[NAME] = 'Eventto' and [Shift]='night'then
end)EventTO
FROM
DRILLINGDETAIL
group by HOLEID,drillingdate) a
join [GeoDetails] b
on a.[HOLEID] = b.[HOLEID]
join (
SELECT TOP 100 PERCENT DRILLINGDETAIL.HOLEID,
case row_number() over(partition by DRILLINGDETAIL.holeid order by tab3.geol_from) when 1 then DRILLINGDETAIL.HOLEID end as x_holeid,
DRILLINGDETAIL.DRILLINGDATE, DRILLINGDETAIL.PROJECTCODE, max(tab3.geol_from) as GeolFromMine, max(tab3.geol_to)GeolTOMine,
tab3.[Primary Lithology] , tab3.Lith_RockName
FROM
DRILLINGDETAIL
LEFT Join
( select holeid,Lith_Rockname,
case row_number() over(partition by a.holeid order by a.geolfrom) when 1 then a.holeid end as x_holeid,
case row_number() over(partition by a.holeid,a.geolfrom order by a.geolfrom) when 1 then a.GEOLFROM end as geol_from,
case row_number() over(partition by a.holeid,a.geolfrom,a.geolto order by a.geolfrom) when 1 then a.GEOLTO end as geol_to,
case row_number() over(partition by a.holeid,a.geolfrom,a.geolto,[a].Primary_Lithology_rus_Desc_D order by a.geolfrom) when 1 then [a].Primary_Lithology_rus_Desc_D end as 'Primary Lithology'
from
( SELECT TOP 100 PERCENT * FROM (SELECT * FROM (SELECT TOP 100 PERCENT * FROM (SELECT TOP 100 PERCENT [HOLEID], [PROJECTCODE], [GEOLFROM], [GEOLTO], [PRIORITY],Lith_Rockname, ( CASE WHEN [ACQDERIVEDVIEW].[Lith_RockName_Desc_D] is null THEN '' ELSE [ACQDERIVEDVIEW].[Lith_RockName_Desc_D]
END +
CASE WHEN str([ACQDERIVEDVIEW].[Lith1_pct]) is null THEN '' ELSE '(' + ltrim(str([ACQDERIVEDVIEW].[Lith1_pct])) + '%' + ')'
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Colour_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith_Colour_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Texture_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith1_Texture_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Structure_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith1_Structure_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_RockName_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_RockName_Desc_D]
END +
CASE WHEN str([ACQDERIVEDVIEW].[Lith2_pct]) is null THEN '' ELSE '(' + ltrim(str([ACQDERIVEDVIEW].[Lith2_pct])) + '%' + ')'
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Colour_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_Colour_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Texture_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_Texture_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Structure_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_Structure_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Comments] is null THEN '' ELSE ', ( ' + [ACQDERIVEDVIEW].[Lith_Comments] + ')'
END
) AS [Primary_Lithology_Desc_D], ( CASE WHEN [ACQDERIVEDVIEW].[Lith_CompRock_rus_Desc_D] is null THEN '' ELSE [ACQDERIVEDVIEW].[Lith_CompRock_rus_Desc_D]+': '
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_RockName_rus_Desc_D] is null THEN '' ELSE [ACQDERIVEDVIEW].[Lith_RockName] + ' - ' + [ACQDERIVEDVIEW].[Lith_RockName_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_pct] = 100 THEN ',' ELSE '(' + ltrim(str([ACQDERIVEDVIEW].[Lith1_pct])) + '%' + '),'
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Colour_Int_rus_Desc_D] is null THEN '' ELSE ' ' + [ACQDERIVEDVIEW].[Lith_Colour_Int_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Colour_rus_Desc_D] is null THEN '' ELSE ' ' + [ACQDERIVEDVIEW].[Lith_Colour_rus_Desc_D] + ' öâåò, '
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Colour2_Int_rus_Desc_D] is null THEN '' ELSE [ACQDERIVEDVIEW].[Lith_Colour2_Int_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith_Colour2_rus_Desc_D] is null THEN '' ELSE [ACQDERIVEDVIEW].[Lith_Colour2_rus_Desc_D] + ' - âòîðîñòåïåííûé öâåò '
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Texture_rus_Desc_D] is null THEN '' ELSE 'ñòðóêòóðà ' + [ACQDERIVEDVIEW].[Lith1_Texture_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Texture2_rus_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith1_Texture2_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Structure_rus_Desc_D] is null THEN '' ELSE ', òåêñòóðà ' + [ACQDERIVEDVIEW].[Lith1_Structure_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith1_Structure2_rus_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith1_Structure2_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_RockName_rus_Desc_D] is null THEN '' ELSE '; ' + [ACQDERIVEDVIEW].[Lith2_RockName] + ' - ' + [ACQDERIVEDVIEW].[Lith2_RockName_rus_Desc_D]
END +
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Colour_rus_Desc_D] is null THEN '' ELSE ', öâåò ' + [ACQDERIVEDVIEW].[Lith2_Colour_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Texture_rus_Desc_D] is null THEN '' ELSE ', ñòðóêòóðà ' + [ACQDERIVEDVIEW].[Lith2_Texture_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Texture2_rus_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_Texture2_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Structure_rus_Desc_D] is null THEN '' ELSE ', òåêñòóðà ' + [ACQDERIVEDVIEW].[Lith2_Structure_rus_Desc_D]
END +
CASE WHEN [ACQDERIVEDVIEW].[Lith2_Structure2_rus_Desc_D] is null THEN '' ELSE ', ' + [ACQDERIVEDVIEW].[Lith2_Structure2_rus_Desc_D]
END +
END ) AS [Primary_Lithology_rus_Desc_D] FROM ( SELECT TOP 100 PERCENT ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
where FIELDTABLE = 'GEOLOGYCODESECONDARY'
and FIELDNAME = 'Lith_Colour'
and LOOKUP = [DFINDF].[Lith_Colour]
and ACTIVE = 1
) AS [Lith_Colour_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith_RockName'
and LOOKUP = [DFINDF].[Lith_RockName]
and ACTIVE = 1 ) AS [Lith_RockName_Desc_D], ( select LOWER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith1_Structure'
and LOOKUP = [DFINDF].[Lith1_Structure]
and ACTIVE = 1 ) AS [Lith1_Structure_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith1_Texture'
and LOOKUP = [DFINDF].[Lith1_Texture]
and ACTIVE = 1 ) AS [Lith1_Texture_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_Colour'
and LOOKUP = [DFINDF].[Lith2_Colour]
and ACTIVE = 1 ) AS [Lith2_Colour_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_RockName'
and LOOKUP = [DFINDF].[Lith2_RockName]
and ACTIVE = 1 ) AS [Lith2_RockName_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_Structure'
and LOOKUP = [DFINDF].[Lith2_Structure]
and ACTIVE = 1 ) AS [Lith2_Structure_Desc_D], ( select UPPER(LEFT(DESCRIPTION,1))+LOWER(STUFF(DESCRIPTION,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_Texture'
and LOOKUP = [DFINDF].[Lith2_Texture]
and ACTIVE = 1 ) AS [Lith2_Texture_Desc_D], ( select UPPER(LEFT(Reportdesc,1))+UPPER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith_CompRock'
and LOOKUP = [DFINDF].[Lith_CompRock]
and ACTIVE = 1 ) AS [Lith_CompRock_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1
) AS [Lith_RockName_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1)) +LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith_Colour_Int'
and LOOKUP = [DFINDF].[Lith_Colour_Int]
and ACTIVE = 1
) AS [Lith_Colour_Int_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1)) +LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1
) AS [Lith_Colour_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1)) +LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith_Colour2_Int'
and LOOKUP = [DFINDF].[Lith_Colour2_Int]
and ACTIVE = 1
) AS [Lith_Colour2_Int_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1)) +LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith_Colour2'
and LOOKUP = [DFINDF].[Lith_Colour2]
and ACTIVE = 1
) AS [Lith_Colour2_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith1_Texture_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith1_Texture2'
and LOOKUP = [DFINDF].[Lith1_Texture2]
and ACTIVE = 1 ) AS [Lith1_Texture2_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith1_Structure_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith1_Structure2'
and LOOKUP = [DFINDF].[Lith1_Structure2]
and ACTIVE = 1 ) AS [Lith1_Structure2_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith2_RockName_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith2_Colour_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith2_Texture_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_Texture2'
and LOOKUP = [DFINDF].[Lith2_Texture2]
and ACTIVE = 1 ) AS [Lith2_Texture2_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and ACTIVE = 1 ) AS [Lith2_Structure_rus_Desc_D], ( select LOWER(LEFT(Reportdesc,1))+LOWER(STUFF(Reportdesc,1,1,'')) from QV_VS_LOOKUP_RO
and FIELDNAME = 'Lith2_Structure2'
and LOOKUP = [DFINDF].[Lith2_Structure2]
and ACTIVE = 1 ) AS [Lith2_Structure2_rus_Desc_D], [HOLEID], [PROJECTCODE], [GEOLFROM], [GEOLTO], [PRIORITY], [Lith_Comments], [Lith1_pct], [Lith2_pct], [Lith_RockName], [Lith2_RockName]
FROM ( SELECT [GEOINTERVAL].[HOLEID], [GEOINTERVAL].[PROJECTCODE], [GEOINTERVAL].[GEOLFROM], [GEOINTERVAL].[GEOLTO], [GEOINTERVAL].[PRIORITY], [GEODETAILS].[Lith_Colour],
[GEOBIGCOMMENT].[Lith_Comments], [GEODETAILS].[Lith_RockName], CAST([GEODETAILS].[Lith1_pct] AS FLOAT) AS [Lith1_pct], [GEODETAILS].[Lith1_Structure], [GEODETAILS].[Lith1_Texture],
[GEODETAILS].[Lith2_Colour], CAST([GEODETAILS].[Lith2_pct] AS FLOAT) AS [Lith2_pct], [GEODETAILS].[Lith2_RockName], [GEODETAILS].[Lith2_Structure], [GEODETAILS].[Lith2_Texture],
[GEODETAILS].[Lith_CompRock], [GEODETAILS].[Lith_Colour_Int], [GEODETAILS].[Lith_Colour2_Int], [GEODETAILS].[Lith_Colour2], [GEODETAILS].[Lith1_Texture2], [GEODETAILS].[Lith1_Structure2],
[GEODETAILS].[Lith2_Texture2], [GEODETAILS].[Lith2_Structure2] FROM [GEOINTERVAL] INNER JOIN (SELECT * FROM [HOLELOCATION]) AS [CollarWSF] ON [CollarWSF].[HOLEID] = [GEOINTERVAL].[HOLEID]
AND [CollarWSF].[PROJECTCODE] = [GEOINTERVAL].[PROJECTCODE] AND [CollarWSF].[HOLETYPE] = 'DRILLHOLE' LEFT JOIN (SELECT [GEODETAILS].[HOLEID], [GEODETAILS].[PROJECTCODE], [GEODETAILS].[GEOLFROM],
[GEODETAILS].[GEOLTO], [GEODETAILS].[PRIORITY], min(CASE when [GEODETAILS].[NAME] = 'Lith_Colour' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_Colour], min(CASE when [GEODETAILS].[NAME] = 'Lith_RockName'
then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_RockName], min(CASE when [GEODETAILS].[NAME] = 'Lith1_pct' then CAST([GEODETAILS].[VALUE] AS FLOAT) ELSE NULL END) as [Lith1_pct], min(CASE when [GEODETAILS].[NAME] = 'Lith1_Structure'
then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith1_Structure], min(CASE when [GEODETAILS].[NAME] = 'Lith1_Texture' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith1_Texture], min(CASE when [GEODETAILS].[NAME] = 'Lith2_Colour' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_Colour],
min(CASE when [GEODETAILS].[NAME] = 'Lith2_pct' then CAST([GEODETAILS].[VALUE] AS FLOAT) ELSE NULL END) as [Lith2_pct], min(CASE when [GEODETAILS].[NAME] = 'Lith2_RockName'
then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_RockName], min(CASE when [GEODETAILS].[NAME] = 'Lith2_Structure' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_Structure], min(CASE when [GEODETAILS].[NAME] = 'Lith2_Texture' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_Texture],
min(CASE when [GEODETAILS].[NAME] = 'Lith_CompRock' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_CompRock], min(CASE when [GEODETAILS].[NAME] = 'Lith_Colour_Int' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_Colour_Int], min(CASE when [GEODETAILS].[NAME] = 'Lith_Colour2_Int'
then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_Colour2_Int], min(CASE when [GEODETAILS].[NAME] = 'Lith_Colour2' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith_Colour2], min(CASE when [GEODETAILS].[NAME] = 'Lith1_Texture2' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith1_Texture2],
min(CASE when [GEODETAILS].[NAME] = 'Lith1_Structure2' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith1_Structure2], min(CASE when [GEODETAILS].[NAME] = 'Lith2_Texture2' then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_Texture2], min(CASE when [GEODETAILS].[NAME] = 'Lith2_Structure2'
then [GEODETAILS].[VALUE] ELSE NULL END) as [Lith2_Structure2] FROM [GEODETAILS] GROUP BY [GEODETAILS].[PROJECTCODE], [GEODETAILS].[PRIORITY], [GEODETAILS].[GEOLTO], [GEODETAILS].[GEOLFROM], [GEODETAILS].[HOLEID])[GEODETAILS] ON [GEOINTERVAL].[PROJECTCODE] = [GEODETAILS].[PROJECTCODE]
AND [GEOINTERVAL].[PRIORITY] = [GEODETAILS].[PRIORITY] AND [GEOINTERVAL].[GEOLTO] = [GEODETAILS].[GEOLTO] AND [GEOINTERVAL].[GEOLFROM] = [GEODETAILS].[GEOLFROM] AND [GEOINTERVAL].[HOLEID] = [GEODETAILS].[HOLEID] LEFT JOIN (SELECT [GEOBIGCOMMENT].[HOLEID], [GEOBIGCOMMENT].[PROJECTCODE],
[GEOBIGCOMMENT].[GEOLFROM], [GEOBIGCOMMENT].[GEOLTO], [GEOBIGCOMMENT].[PRIORITY],
min(CASE when [GEOBIGCOMMENT].[NAME] = 'Lith_Comments'
then [GEOBIGCOMMENT].[VALUE] ELSE NULL END) as [Lith_Comments] FROM [GEOBIGCOMMENT] WHERE [GEOBIGCOMMENT].[NAME] IN ('Lith_Comments')
GROUP BY [GEOBIGCOMMENT].[PROJECTCODE], [GEOBIGCOMMENT].[PRIORITY], [GEOBIGCOMMENT].[GEOLTO], [GEOBIGCOMMENT].[GEOLFROM], [GEOBIGCOMMENT].[HOLEID])[GEOBIGCOMMENT]
ON [GEOINTERVAL].[PROJECTCODE] = [GEOBIGCOMMENT].[PROJECTCODE] AND [GEOINTERVAL].[PRIORITY] = [GEOBIGCOMMENT].[PRIORITY] AND [GEOINTERVAL].[GEOLTO] = [GEOBIGCOMMENT].[GEOLTO]
AND [GEOINTERVAL].[GEOLFROM] = [GEOBIGCOMMENT].[GEOLFROM] AND [GEOINTERVAL].[HOLEID] = [GEOBIGCOMMENT].[HOLEID] WHERE ([Lith_Colour] IS NOT NULL OR [Lith_Comments] IS NOT NULL
OR [Lith_RockName] IS NOT NULL OR [Lith1_pct] IS NOT NULL OR [Lith1_Structure] IS NOT NULL OR [Lith1_Texture] IS NOT NULL OR [Lith2_Colour] IS NOT NULL OR [Lith2_pct] IS NOT NULL
OR [Lith2_RockName] IS NOT NULL OR [Lith2_Structure] IS NOT NULL OR [Lith2_Texture] IS NOT NULL OR [Lith_CompRock] IS NOT NULL OR [Lith_Colour_Int] IS NOT NULL OR [Lith_Colour2_Int] IS NOT NULL
OR [Lith_Colour2] IS NOT NULL OR [Lith1_Texture2] IS NOT NULL OR [Lith1_Structure2] IS NOT NULL OR [Lith2_Texture2] IS NOT NULL OR [Lith2_Structure2] IS NOT NULL) ) [DFINDF]) [ACQDERIVEDVIEW]) [ACQTMP] ) AS [TMPVIEW915]) [TMPSQLSHEETVIEW]) a
)tab3 on
tab3.holeid=DRILLINGDETAIL.HOLEID where [DRILLINGDETAIL].[holeid] = 'makh-17-005' and
cast(DRILLINGDETAIL.DRILLINGDATE as datetime)= '16-jul-2017'
group by DRILLINGDETAIL.HOLEID, DRILLINGDETAIL.PROJECTCODE, tab3.[Primary Lithology] ,DRILLINGDETAIL.DRILLINGDATE,tab3.geol_from,tab3.geol_to,tab3.x_holeid ,tab3.holeid,Lith_Rockname
ORDER BY cast(DRILLINGDETAIL.DRILLINGDATE as datetime),tab3.holeid,tab3.x_holeid desc,geol_from)tab8 on tab8.HOLEID=a.HOLEID and tab8.Lith_RockName=b.VALUE and b.[NAME] = 'Lith_RockName'
and a.EventFrom<b.GEOLTO
and a.EventTo>b.GEOLFROM
Where a.[DRILLINGDATE] = '16-jul-2017'
order by [from]
