Зачем MSSQLStudio шлет такие запросы с sys.asymmetric_keys, sys.certificates ?
Я запустил MS SQL Studio, приконнектился к серверу SQL и все. А профайлер показывает, что я постоянно шлю такие запросы из студии. Что это за запросы и зачем ? SELECT u.name AS [Name], u.principal_id AS [ID], CAST(CASE WHEN u.principal_id < 5 OR u.principal_id = 16382 OR u.principal_id = 16383 THEN 1 ELSE 0 END AS bit) AS [IsSystemObject], CASE WHEN N'U' = u.type THEN 0 WHEN N'G' = u.type THEN 1 WHEN N'S' = u.type THEN 2 WHEN N'C' = u.type THEN 3 WHEN N'K' = u.type THEN 4 WHEN N'E' = u.type THEN 5 WHEN N'X' = u.type THEN 6 END AS [LoginType], CAST(CASE dp.state WHEN N'G' THEN 1 WHEN 'W' THEN 1 ELSE 0 END AS bit) AS [HasDBAccess], u.sid AS [Sid], u.create_date AS [CreateDate], u.modify_date AS [DateLastModified], ISNULL(u.default_schema_name,N'') AS [DefaultSchema], ISNULL(ak.name,N'') AS [AsymmetricKey], ISNULL(cert.name,N'') AS [Certificate], ISNULL(suser_sname(u.sid),N'') AS [Login], ISNULL(u.default_language_lcid, -1) AS [DefaultLanguageLcid], ISNULL(u.default_language_name,N'') AS [DefaultLanguageName], u.authentication_type AS [AuthenticationType], CASE WHEN N'C' = u.type THEN 1 WHEN N'K' = u.type THEN 2 WHEN N'S' = u.type AND SUSER_SNAME(u.sid) is null AND u.authentication_type != 2 THEN 3 ELSE 0 END AS [UserType] FROM sys.database_principals AS u LEFT OUTER JOIN sys.database_permissions AS dp ON dp.grantee_principal_id = u.principal_id and dp.type = @_msparam_0 LEFT OUTER JOIN sys.asymmetric_keys AS ak ON ak.sid = u.sid LEFT OUTER JOIN sys.certificates AS cert ON cert.sid = u.sid WHERE (u.type in ('U', 'S', 'G', 'C', 'K' ,'E', 'X'))and(u.name=@_msparam_1) ... |
| 11.07.2018, 14:38 |
start [/forum/topic.php?desktop=1&fid=46&tid=1689427]: |
145ms |
50ms |
| others: | 212ms |
| total: | 459ms |
