Не работает операция like в запросе
Запрос такой: select t.tapid, isnull(m.family,'') as family, isnull(m.name,'') as name, isnull(m.ot,'') ot, convert(date, isnull(m.date_bd, '01.01.1901')) as date_db, isnull(se.servicemedicalcode,'') as scode, substring(rtrim(ltrim(isnull(se.ServiceMedicalName,''))),1,250) as sName, isnull(mkb.ds, '') as ds, substring(ltrim(rtrim(isnull(d.DepartmentName,''))),1,30) as DName, isnull(do.FAM_V, '') as fam_v, convert(date, isnull(s.DATE_P,'01.01.1901')) as date_p, substring(isnull(p.NAME,''),1,3) as profit from r_hlt_TAP as t inner join r_hlt_SMTAP as s on s.rf_TAPID=t.tapid inner join r_hlt_mkab as m on m.MKABID=t.rf_MKABID inner join r_oms_department as d on d.DepartmentId=s.rf_DepartmentID left join r_hlt_LPUDoctor as do on do.LPUDoctorID=s.rf_LPUDoctorID inner join r_oms_servicemedical as se on se.servicemedicalId=s.rf_omsservicemedicalId left join r_oms_kl_ProfitType as p on p.kl_ProfitTypeID=t.rf_kl_ProfitTypeID left join r_oms_mkb as mkb on mkb.mkbid=s.rf_MKBID where ((convert (date, s.DATE_P)>@d2 or convert(date,s.date_p)<convert(date,@PrevDate)) and convert(date,t.DateClose)>=@d1 and convert(date,t.DateClose)<=@d2) and se.servicemedicalname like 'D%' and t.IsClosed=1 Не выдает ничего А Запрос в таком виде выдает много строчек, где se.servicemedicalname начинается именно на символ D select t.tapid, isnull(m.family,'') as family, isnull(m.name,'') as name, isnull(m.ot,'') ot, convert(date, isnull(m.date_bd, '01.01.1901')) as date_db, isnull(se.servicemedicalcode,'') as scode, substring(rtrim(ltrim(isnull(se.ServiceMedicalName,''))),1,250) as sName, isnull(mkb.ds, '') as ds, substring(ltrim(rtrim(isnull(d.DepartmentName,''))),1,30) as DName, isnull(do.FAM_V, '') as fam_v, convert(date, isnull(s.DATE_P,'01.01.1901')) as date_p, substring(isnull(p.NAME,''),1,3) as profit from r_hlt_TAP as t inner join r_hlt_SMTAP as s on s.rf_TAPID=t.tapid inner join r_hlt_mkab as m on m.MKABID=t.rf_MKABID inner join r_oms_department as d on d.DepartmentId=s.rf_DepartmentID left join r_hlt_LPUDoctor as do on do.LPUDoctorID=s.rf_LPUDoctorID inner join r_oms_servicemedical as se on se.servicemedicalId=s.rf_omsservicemedicalId left join r_oms_kl_ProfitType as p on p.kl_ProfitTypeID=t.rf_kl_ProfitTypeID left join r_oms_mkb as mkb on mkb.mkbid=s.rf_MKBID where ((convert (date, s.DATE_P)>@d2 or convert(date,s.date_p)<convert(date,@PrevDate)) and convert(date,t.DateClose)>=@d1 and convert(date,t.DateClose)<=@d2) and se.servicemedicalname like '%' and t.IsClosed=1 Где искать причину? ... |
| 31.07.2018, 10:58 |
seg856, вот так попробуйте Код: sql 1. Если что-то выведется, то значит перед D что-то есть И отформатируйте код по правилам - глаза сломать можно ... |
| 31.07.2018, 11:17 |
CrazHunt, '%D%' тоже не выдает строки. '%90%' тоже не выдает строки. ... |
| 31.07.2018, 11:53 |
какого типа ваше поле servicemedicalname в таблице? ... |
| 31.07.2018, 11:54 |
seg856Где искать причину? А таки попробуйте кошерное and se.servicemedicalname like N'D%' ... |
| 31.07.2018, 12:04 |
seg856, попробуй тупо Код: sql 1. ... |
| 31.07.2018, 12:05 |
Konst_One, varchar(500) ... |
| 31.07.2018, 12:48 |
и в итоге окажется, что там О а не D.... какой collation? ... |
| 31.07.2018, 12:51 |
'%d%'? ... |
| 31.07.2018, 12:52 |
Просто перепутал поля: нужно ServicemedicalCode вместо ServicemedicalName ... |
| 31.07.2018, 13:24 |
start [/forum/search_topic.php?author=%40Nik&author_mode=last_posts&do_search=1]: |
173ms |
26ms |
| others: | 1144ms |
| total: | 1408ms |
