Cannot connect.
На сервере подключаюсь к базе с помощью MSSMS и вылетает сообщение: ------------------------------ ADDITIONAL INFORMATION: A connection was successfully established with the server, but then an error occurred during the login process. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.) (Microsoft SQL Server, Error: 233) ... |
| 11.02.2019, 16:20 |
Cannot connect.
lleopolld1, с китайского агрегатора ... |
| 11.02.2019, 16:23 |
start [/forum/topic.php?desktop=1&fid=46&tid=1688315]: |
167ms |
29ms |
| others: | 259ms |
| total: | 503ms |
