Cumulative Update 16 for SQL Server 2016 SP2
https://support.microsoft.com/en-us/topic/kb5000645-cumulative-update-16-for-sql-server-2016-sp2-a3997fa9-ec49-4df0-bcc3-12dd58b78265 https://download.microsoft.com/download/6/0/6/606B3A2E-0EAE-4DCD-930D-178686370921/SQLServer2016-KB5000645-x64.exe ... |
| 12.02.2021, 09:55:05 |
JFY : Note: After you apply CU 16 for SQL Server 2016 SP2, you might encounter an issue in which DML (insert/update/delete) queries that use parallel plans cannot complete any execution and encounter HP_SPOOL_BARRIER waits. You can use the trace flag 13116 or MAXDOP=1 hint to work around this issue. This issue is related to the introduction of fix for 13685819 and it will be fixed in the next Cumulative Update. ... |
| 10.03.2021, 18:44:20 |
start [/forum/topic.php?desktop=1&fid=46&tid=1684976]: |
64ms |
42ms |
| others: | 229ms |
| total: | 384ms |
