Cumulative Update 13 for SQL Server 2019 (KB5005679)
https://support.microsoft.com/en-us/topic/kb5005679-cumulative-update-13-for-sql-server-2019-5c1be850-460a-4be4-a569-fe11f0adc535 https://download.microsoft.com/download/6/e/7/6e72dddf-dfa4-4889-bc3d-e5d3a0fd11ce/SQLServer2019-KB5005679-x64.exe Replication Enhancements in the SQL Server 2019 CU13 Release Write-write replication with last writer wins conflict resolution. Starting with SQL Server 2019 CU13, in a peer-to-peer replication configuration can participate in an Always On availability group. It is not required that all members of a replication configuration are in an AG. You can mix AG and non-AG databases in a replication configuration. This significantly improves the availability of these configurations. ... |
| 06.10.2021, 10:38:03 |
13 обновление - видимо токсичное. При загрузке документов с отложенной стабильностью появились сбои, которых раньше не было. Date 18.10.2021 12:53:02 Log SQL Server (Current - 18.10.2021 14:11:00) Source spid173 Message SQL Server Assertion: File: <pageref.cpp>, line=2269 Failed Assertion = 'IS_OFF (BUF_MINLOGGED, m_buf->bstat) || pageModifyType != PageModifyType_Contents || GetPagePtr ()->IsTextPage ()'. This error may be timing-related. If the error persists after rerunning the statement, use DBCC CHECKDB to check the database for structural integrity, or restart the server to ensure in-memory data structures are not corrupted. DBCC CHECKDB ошибок не выявило... ... |
| 18.10.2021, 19:27:44 |
start [/forum/topic.php?desktop=1&fid=46&tid=1684189]: |
178ms |
36ms |
| others: | 231ms |
| total: | 490ms |
