SQL Server 2016 Service Pack 3 release (KB5003279)
https://support.microsoft.com/en-us/topic/kb5003279-sql-server-2016-service-pack-3-release-information-46ab9543-5cf9-464d-bd63-796279591c31 https://download.microsoft.com/download/a/7/7/a77b5753-8fe7-4804-bfc5-591d9a626c98/SQLServer2016SP3-KB5003279-x64-ENU.exe ... |
| 16.09.2021, 10:38:14 |
KB5007039 - FIX: You encounter error messages 8114 or 22122 when performing change tracking cleanup After you apply SQL Server 2016 Service Pack 3 (SP3) or SQL Server 2017 Cumulative Update 26 (CU26), and you run a change tracking cleanup stored procedure, sp_flush_commit_table_on_demand or sp_flush_CT_internal_table_on_demand, you encounter the following error: Msg 8114, Level 16, State 1, Procedure sp_add_ct_history, Line LineNumber Error converting data type numeric to int. You might also encounter the following errors in the SQL Server error log: DateTime spidNum Error: 22122, Severity: 16, State: 1. DateTime spidNum Change Tracking autocleanup failed on side table of "table_name". If the failure persists, use sp_flush_CT_internal_table_on_demand to clean up expired records from its side table. After you encounter this error, change tracking automatic cleanup can't clean up entries from the side table or syscommittab table. ... |
| 24.10.2021, 16:54:43 |
start [/forum/topic.php?desktop=1&fid=46&tid=1684172]: |
448ms |
41ms |
| others: | 185ms |
| total: | 723ms |
