Check each OLE DB status value
MS SQL2000(MSDE)+AccessXP.adp Имею сообщение “Multi-step OLE DB operation generated errors.Check each OLE DB status value,if available.No work was done” . Есть ли какая-либо возможность сделать "check each OLE DB status value" ? ... |
| 19.08.2002, 10:47 |
start [/forum/topic.php?desktop=1&fid=45&tid=1683400]: |
157ms |
29ms |
| others: | 234ms |
| total: | 459ms |
