Проблема с итогами по отчетам
Каким образом можно сделать в отчете итог не по группам, а по странице. Необходим отчет, где на каждой странице сумма по столбцам этой страницы... Как только не пробовал, ну нихрена не получается Pls помогите !!! ... |
| 28.11.2002, 13:52 |
You can use the RunningSum property to calculate record-by-record or group-by-group totals in a report. Such a device is not available if you want to show a total on each page. To sum an item per page, follow these steps: Open the report in Design view. On the View menu, click Code. Create a module and type the following lines in the Declarations section: Option Compare Database Option Explicit Public PageSum as Double Enter the following code in the event procedure for the Print property of the detail section where <report name> is the name of your report, and <field name> is the name of the field you want to sum: Private Sub Detail_Print(Cancel As Integer, PrintCount As Integer) PageSum = PageSum + Reports![<report name>]![<field name>] End Sub Enter the following code in the event procedure for the Format property of the page header: Private Sub PageHeader_Format(Cancel As Integer, FormatCount As Integer) ' reset the counter for each new page PageSum = 0 End Sub Insert a text box control with the following properties in the page footer: Name: txtPageTotal ControlSource: =[PageSum] or Private Sub PageFooterSection_Print(Cancel As Integer, PrintCount As Integer) txtPageTotal = PageSum End Sub Run the report and note that the text box displays the sum of the relevant field for each page. If you want to simulate a running sum for the report, delete the reset line from the page header Format event. ... |
| 28.11.2002, 16:24 |
start [/forum/topic.php?desktop=1&fid=45&tid=1682836]: |
157ms |
31ms |
| others: | 206ms |
| total: | 431ms |
